Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 03-23-2001, 12:06 AM   #26
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post
kris i also found when i was out at bondurant school for the blind. that you need to find the right pair of shoes that you own.. notice that i always wear my low cut hiking boots when i auto-x.. just because the shape of the sole makes it easier for me than my running shoes.. you want flat soles. hope this helps. but you have a WRX thse are supposed to be fast in fast out, no? learn to pitch it on the tar and you will be much happier plus it looks cooler than ultra smooth faster than everyone KC techniques...
bill harvey is offline   Reply With Quote
Old 03-23-2001, 05:57 AM   #27
ttoversteer
Member#: 465
2012 GTI
Gray
Post
Marc, not quite.
If you are using threshold braking, you are at the limit, which means that if you brake harder you will lock a wheel and in your situation will probably spin the car.
You are actually thinking about trailing throttle oversteer (hehe..TTOversteer.) If you trail the brakes into the turn, meaning that max braking is done before the turn with less and less brake pressure applied up to the turn apex, the car will rotate; hopefully in a nice, smooth, controlled manner. At the apex is where you want to roll off the brakes and onto the gas, then apply more and more gas until the end of the turn where you should be at full throttle.
Typically, you want to have your shifting done BEFORE the turn, or in as much of a straigh line as possible, as shifting during the turn will upset the delicate balance of the car... I believe Paul said above that it's important not to upset the suspension in any way. He's right.
All this needs to be done in one smooth motion. There are no sudden movements (Ideally.)
Also in your situation you mention rev matching at 3k? I'll asume that's just an example. You can rev match at any rpm (up to redline), and in a racing situation will probably match at the high end of the dial.
Drive smooth
-Tom
ttoversteer is offline   Reply With Quote
Old 03-23-2001, 09:23 AM   #28
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Post
Hee hee..
I still can't do any of this though. I spun my car at the ice race on an upshift from 1st to 2nd! Ha..
Paul G.
paultg is offline   Reply With Quote
Old 03-23-2001, 10:27 AM   #29
ttoversteer
Member#: 465
2012 GTI
Gray
Post
That's okay, Paul. We all know you just got carried away with the happy pedal.
Old 03-23-2001, 01:32 PM   #30
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Post
Wait a second....you can do clutchless shifting!? Not that I have a manual...but that sounds cool!
kevinsUBARU is offline   Reply With Quote
Old 03-23-2001, 04:35 PM   #31
ttoversteer
Member#: 465
2012 GTI
Gray
Post
KevinSubaru: Yeah, you can shift without a clutch. But if you screw it up, you'll destroy your tranny. I've tried it on a couple of occasions successfully, but I've also tried it and got the irksome: CRUNCH!
I guess it comes in handy in certain rally situations, but I'm really good at heel and toe so I don't know that it'll be an advantage for me. Plus, I'm not very good at left foot braking yet. (I guess I need to go to rally school!)
Drive smooth
-Tom
Old 03-23-2001, 07:41 PM   #32
webkris
Member#: 70
I sold WRX to buy
Dodge Neon Rally Car
Lightbulb
Ooh left foot braking - now that I can do. Since I had the slushbox, I learned to modulate the brake pedal with my left foot - instead of just mashing it, like a clutch in manuver. Wayne can chime in here to - as we were both practicing it at the Ice Races. Helps curb understeer, wheelspin, and a host of other things when used properly. Especially in a low friction environment.
Practice daily by approaching a stop, clutch in and drop car in neutral. Brake with the left foot. - It feels strange at first but you want to get used to the sensation. (don't try this at first in traffic )When you can smoothly stop the car with the left foot - you will then feel comfortable applying a small ammount of braking force while modulating power through turns. The last thing you want to do is make the car lurch forward when you begin to lft foot brake... Smooth.
It's a constant dance of oversteer and understeer - steering and countersteering that allows rally drivers to be in control. While they are riding the edge of that control. Anticipate the car.
"The force is strong in this one."
Now back to the original topic - I'm starting to get it. I did it correctly 4 times tonight while picking up some groceries, and messed it up twice. If I position my foot far right under the gas - instead of between the gas and brake, I can brake and blip. It's my clutch timing that's throwing me off - so I've been learing where to rev match the car before doing a heel toe.
Again - the clutch for me is not an automatic respoce yet. I know how to do it - but I have to concentrate on it.
"rex on.... rex off...."
*bow. "I am ready master."
- Kris
webkris is offline   Reply With Quote
Old 03-23-2001, 08:45 PM   #33
Pilot
Member#: 513
Post
If ti makes you feel any better when I taught myself how to heel/toe double D it took me nearly two straight months to get it right and two more years to get proficient at it.
patience kristofer san, let the force flow through you
Pilot is offline   Reply With Quote
Old 03-24-2001, 10:46 AM   #34
dirk.gecko
Member#: 3141
2007 Scion tC
Blue or something
Post
Mmm, clutchless shifting.
I've done that with all the manuals I've owned. Of course, none of them had any serious horsepower.
Did that on my motorcycle, too. Fiiiiirst gear (snick) second-gear (snick) third! (snick) fourth! (snick) fifth! (snicker-snicker-tickety-tickey) Aw crap.
When your bike produces max power @ 9,000k and you upshift @ 10,200k, guess where your next gearshift puts you:
Yep. 9 grand. I stripped the 5th gear dogs right off. Didn't help that Honda Sabres had badly milled 2nd & 5th...
Dirk
PS: So yeah. You can do it, just don't make a habit of it at full throttle.
[This message has been edited by dirk.gecko (edited March 24, 2001).]
dirk.gecko is offline   Reply With Quote
Old 03-25-2001, 03:33 PM   #35
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Post
You might try what I am doing. I have 2k miles on my new 01 Coupe, and one autocross. I learned to double-clutch the car because of this huge hill on the way to work. Entering the hill at the bottom in 5th gear at 70mph makes the engine bog and you are at 2k rpms by the top of the hill at 50mph or so. Next, I tried shifting into 4th as I was halfway up the hill. This would allow me to maintain speed better, although I'd lose a bit during the shift. The problem was this would produce a huge *JERK* as the driveline reengaged, even when I tried going easy on the clutch and throttle, due to the steep hill I guess.
So, I learned to shift into neutral, engage clutch, blip throttle, reengage the clutch and shift to 4th right at the bottom to climb the hill. Double clutching before entering the hill allows the driveline to reengage silky smooth, and since the revs want to match for 4th gear at about 4200rpms, I'm right in the meat of the powerband and can actually accelerate up the hill if I like.
I can now double-clutch downshift to any gear (1st still a bit troublesome ) so adding heel/toe should hopefully be easy.
Added note: Some of you might find double-clutch downshifting useful for dropping into go-fast mode when a Honda rolls up next to ya. It's smoother on the driveline and they get to hear the one warning growl when you blip throttle before you disappear in front of them.
Xio is offline   Reply With Quote
Old 06-04-2002, 11:29 AM   #36
Nitro Soda
Member#: 19299
1997 Impreza Wagon
i sometimes shift clutchless from 2nd into 1st as i'm rolling up to a light or stop sigh. this is obviously not for performance reasons...it's more of a lazyness issue but if done right it will slip right in to gear... i've pulled off 4th into 3rd pretty well too...
i'm still a bit confused when to reengage the cluth (the 1st time) when double Din'. i only double D when the car won't go into reverse
Nitro Soda is offline   Reply With Quote
Old 06-04-2002, 12:13 PM   #37
sorbee711
Member#: 14259
OT, we're a-holes
b/c we are bored at work
Smile
I learned heal - toe by going to skip barber. I recommend that to everyone.
Also I used to be able to go 1-2-3-4-5 in my Ford Pickup w/out clutch after getting used to it. I'm used to my integra now also, but its worth a lot more than $3500... so i won't be risking it.
sorbee711 is offline   Reply With Quote
Old 06-04-2002, 12:18 PM   #38
DustinR
Member#: 8264
2001 Impreza 2.5 RS
95 Impreza 1.8 Coupe
WARNING: this thread has entirely too much content for NESIC
So me and my size 9 shoes just get the heal() right over and tap the gas. Ever since my first autox where i attempted it and had the instructor look over at me like what the hell was that i decided i had to practice. So for the last month or so every time i think of it when coming to a stop i heel toe all the way into first. I know its really excessive but it gets me the most practice. Now im starting to use it approaching corners on my spirited drives. Once again its a little excessive cause im not really going that fast (usually 5 to 10 over) but it gets me in the habit and gets me more practice. with that i can't wait for the next autox to see if i can sucessfully use what i have hopefully learned, under pressure. Once i have that going well im going to attack the left foot breaking beast. That will prolly be more interesting seeing as my left foot has the coordination of an elephant on ice. (read if your approaching a light behind a silver rs in a couple weeks...... back off)
as far a clutchless shifting... it hurts me to think of it. I know there are those out there that can do it. but they are a whole lot better than me at something and i don't think i would ever try.
NitroSoda: its actually quite a simple matter(double clutching) so don't let yourself think that its complicated. to make it REALLY simple you have three rotating pieces in your car Your engine, your transmition and your drive shaft. they rest in that order. Between the engine and the tranny is the clutch and between the tranny and the drive shaft is the shifter. The basic idea is that when you attach any of these pieces you want them to be going the same speed. So say you are rolling down the road your drive shaft is a given you can't change the speed of that but you want to down shift so you take the car out of gear(press the clutch shift into neutral and release the clutch) Thats the easy part. at this point your engine and tranny are connected but your drive shaft is not. Now you rev the engine till it is going about the same seed as it would be if you were in the gear that you want to be in then you press the clutch shift into gear and release the clutch. if this is done right the shifter it self should go into gear faster and easier(because the syncros have to do less work) and the car won't jerk around because everything is already moving at the correct speed. hope that helped rather than confuse you as much as it did me as i re read it
-Dustin
DustinR is offline   Reply With Quote
Old 06-04-2002, 01:13 PM   #39
jamz
Member#: 8725
2013 Black Company
Annalist
IggDawg is cool
jamz is offline   Reply With Quote
Old 06-04-2002, 02:00 PM   #40
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
There are 3 ways (that I know of) to heel and toe downshift.
1: Right foot on brake and roll it over to the gas to blip it.
2: Right ball of foot on brake and use heel to blip the gas.
3: Right heel on brake and use the toe to blip the gas.
A student of mine at NHIS in group 2 was using #1, which seems very common. He commented that he had a really hard time with pedal placement on his BMW 3 series...especially in turn 3. A light bulb went off in my head. Fortunately, I was wearing sunglasses.....oops. Anyways, I commented that I have used #3 technique from day 1 for some unknown reason. I usually have to drive a student's car first at a school and have yet to find any car that I've been unable to use this technique with. From a Shelby GT350 to my old CRX, it works everywhere for me. I'll also add that I use some very small shoes. Reebok walking shoes now. I think my karate shoes or wrestling shoes would also work great. I also have size 8, so can't comment on the big sizes.
I am very scared of coming into turn 3, doing the downshift and slipping off the brake using #1 technique. For me, being very, very solid on the brake pedal is of prime concern.
Also on double clutch heel and toe downshift. I do this, but not in competition. The double clutch portion saves the synchros in the tranny. The rev matching keeps wheel speed and engine speed similar when you let the clutch back out. I'm not Mario Andretti, so if I'm on the clock, another chance to botch a shift isn't going to help my time.
I like this thread here. NE seems to have a more intelligent crew.
jack
Old 06-04-2002, 04:04 PM   #41
jsnow
Member#: 14335
Originally posted by webkris
Now - next question... Do you have to match revs if you double clutch?? Still need to blip the throttle? I'm a little confused about this technical part.
If the revs aren't matched, it will never be smooth.
As for heel-toeing, my feet are 10.5" and I have a hard time understanding how it would be more difficult with bigger feet, assuming your feet increase in width proportionally with their length.
Heel-toe is indeed a misonomer, at least for everyone I've spoken too. For me it's left-side-of-foot and right-side-of-foot. With bigger feet, I'd think that those contact patches would increase and bridge the gap more easily.
And lastly, I don't grok this double-clutching thing. Seems like wasted motion to me, and doesn't produce any affect that I can feel. (Except maybe for making reverse less argumentative.)
jsnow is offline   Reply With Quote
Old 06-04-2002, 04:31 PM   #42
touch
Member#: 12678
...since this thread was started a couple months ago now, we can ask...
how's it going kris? ...getting much faster i assume.
touch is offline   Reply With Quote
Old 06-04-2002, 05:40 PM   #43
jamz
Member#: 8725
2013 Black Company
Annalist
I actually do it quite a bit going into first- I have no problem shifting from second to first at 20 MPH by double clutching- it makes a less-precise rev match work more easily- i.e. double clutch+rev-match more or less.
Old 06-05-2002, 11:28 AM   #44
Nitro Soda
Member#: 19299
1997 Impreza Wagon
Default Thanks!!
yep that clears it up. i've been rev matching for ever but i never really understood the double d theory's... so thanks to Dustin and everyone else as they all helped me out!
Old 06-05-2002, 01:03 PM   #45
Siper2
Member#: 1134
2007 BMW 328xi wagon
My feet don't seem to be able to twist enough, without rotating my hip in the seat, and that obviously ain't good.
I have very low mobility in my whole ankle/foot joint. Really weird.
Gotta be a way I can do this, though.
-S2-
Siper2 is offline   Reply With Quote
Old 04-15-2014, 07:29 AM   #46
memosrex
Member#: 378653
thanks Tom and Rez. your tips are great. i wear a size 15 so its a real pain in the ass.
memosrex is offline   Reply With Quote
Old 04-15-2014, 07:57 AM   #47
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
I think... That is officially the largest gap for bringing a thread back from the dead!!
CONGRATS!!
Loyale93 is offline   Reply With Quote
Old 04-15-2014, 08:18 AM   #48
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
My hat is off to this guy and his elite search skills. It puts most of the members to shame that can't find a thread from yesterday.
vogun16 is offline   Reply With Quote
Old 04-15-2014, 08:45 AM   #49
Thatskipkid
Member#: 362399
04 STI
Satin Black
Epic bump lol
Thatskipkid is offline   Reply With Quote
Old 04-15-2014, 09:09 AM   #50
Dayglow
Member#: 211395
0000 4wfp Flintstone
Mobile made of stone+wood
Dang what a bump.
Dayglow is offline   Reply With Quote
heel-toe shifting rocketeer Newbies & FAQs 39 01-27-2010 02:25 PM
Big Turbo Need Help WjRgX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-14-2004 04:36 PM
So how do you heel-toe shift? That Guy General Community 18 04-27-2003 09:10 PM
Explaination of heel-toe shifting JGard General Forum Archive 23 01-19-2001 08:58 PM
benefits of heel-toe shifting Racer X General Forum Archive 6 01-19-2001 08:06 AM
