Old 09-18-2008, 08:09 PM   #1
crazycanasian
Member#: 129554
03 WRX
Angry Oil Gallery Adapter Help
I'm in the middle of installing my prosport oil pressure gauge. I managed to get the nut off where i'm supposed to install the adapter for the sender. However it seems like they are different thread, the adapter will not screw in at all.
Anybody else have this problem or and ideas to solve this?
Thanks in advance,
Viet
crazycanasian is offline   Reply With Quote
Old 09-18-2008, 08:21 PM   #2
socomcaptain05
Member#: 168979
2004 WRX Stage 0
take off the intercooler. Go get some jb weld to put around the galley plug in case of leaking. I hope you havent stripped it. YOU MUST REMOVE INTERCOOLER
socomcaptain05 is offline   Reply With Quote
Old 09-18-2008, 08:32 PM   #3
steverx05
Member#: 128269
That's terrible advice...why would you use JB weld to permanently attach a sensor adapter to the engine block? If the adapter is installed properly, it shouldn't be leaking.
To the OP...are you using the Subaru adapter that screws into the top of the engine under the intercooler? If so, it is threaded to take gauges with a BSPT pitch thread. If I'm not mistaken, Prosport gauge senders have an NPT pitch thread and won't screw into the Subaru adapter properly. Hope that helps.
steverx05 is offline   Reply With Quote
Old 09-18-2008, 08:43 PM   #4
Mechie3
Member#: 120152
The adapter won't thread into the block or the sender won't thread into the adapter? Wrap your adapter with teflon tape, put it in the hole, rotate it backwards slowly until it drops a little bit (when the threads match). Turn it in my hand the first few turns. If it doesn't go in easily, try putting the plug back in. If this doesn't go in either, you damaged the threads on the block. You'll need to get a helicoil kit if this is in fact what you did (I did this and had to drill/tap/helicoil the block). If the plug goes in fine, the adapter is wrong (though I've never heard of anyone having a different thread on the block side).
If the sender won't fit, the prosports are in fact NPT while Subaru plugs are BSPT.
Mechie3 is offline   Reply With Quote
Old 09-18-2008, 08:49 PM   #5
WRXEcho
Member#: 96372
2002 WRX Wagon 4EAT
I believe you need to get a BSP/T to NPT adapter in addition to the galley plug for it to work. The inner threads on the adapter should be NPT (where the sender screws in), and the outer threads should be BSP/T (so it can screw into the galley plug). I think prosport has a package of them for sale on their website (metric adapter kit).
And I also agree with wrapping the threads in teflon tape...or whatever. There are different kinds for fuel and such.
WRXEcho is offline   Reply With Quote
Old 09-18-2008, 11:36 PM   #6
crazycanasian
Member#: 129554
03 WRX
I finally got everything to work out, thanks guys!
Old 09-19-2008, 12:33 AM   #7
socomcaptain05
Member#: 168979
2004 WRX Stage 0
Really? Hmmm funny. Cause I remember when I installed my sensor to the galley plug, even though it was on there properly, oil still leaked somehow. And when I did a search and asked around, other members said they had the same problem. So I put JB weld around it, and guess what? No more leaks. Oh! and guess what else? The sensor came right off when I took the oil pressure gauge out a few months later. Yep, thats right, can you beleive it...it wasn't on there permanently! k thanks bye.
Old 09-19-2008, 12:49 AM   #8
Mechie3
Member#: 120152
^^ Did you use the brass or copper gasket that came with it?
Old 09-19-2008, 12:52 AM   #9
socomcaptain05
Member#: 168979
2004 WRX Stage 0
I didnt get a gasket. Just the plug replacement in which has the hole on the top to screw in the sensor.
Old 09-19-2008, 08:59 AM   #10
steverx05
Member#: 128269
Uh huh, I'm sure. Sounds like BS to me, but OK!
It would be much better advice to tell the OP how to install the sensor properly using some teflon tape on the threads instead of installing it wrong and coming up with an unreliable fix. There should be no reason to use something like JB weld on an adapter like that.
Oil gallery plug or sandwich adapter? infinite012 Mid Atlantic Impreza Club -- MAIC 22 03-11-2010 02:56 PM
Oil Pressure/Oil Temp/Oil Gallery plug WRenXhaven Electrical & Lighting 28 05-28-2009 01:54 PM
subaru oil gallery plug adapter $15 Wannascooby Accessories & Misc 0 11-30-2006 02:12 AM
oil gallery plug adapter size? subaruisme Electrical & Lighting 6 03-08-2004 01:11 PM
Defi Oil Pressure, adapter for gallery??? dan avoN7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-14-2004 11:05 AM
