Alaskan Impreza Club
Old 03-16-2002, 05:09 PM   #1
RawCode
Member#: 3115
2002 Impreza 2.5RS
Default Tie Rod Problem, I think?
Ok.. if I am correct, the tie rods are the ones up and a little to the rear of the front disk brakes. I think that because of the joint and such blah blah blah...
Well both the driver side AND the passenger side Tierods are touching my disk brakes... Like they are actually planted on the face of the inboard disks.
I have never heard of such a problem before, let alone seen it.
I found out that this was a problem once I got a mile or so away from my house when I heard screeching. I stopped to check it out and nothing seemed to be caught in the brakes so I continued on.
Still screeching...
So now I pull over on the Highway and take a closer look, and it is my tie rods! AUGH!
Anyone have any idea what could have happened?
I have not hit a single curb, or anythign at all since I have had the car. Last thing I did in the car was the night before, I went on a long drive at 3am down a highway and back. Just enjoying the car around a few twisties... It worked fine last night... but not today?
RawCode
RawCode is offline   Reply With Quote
Old 03-16-2002, 06:20 PM   #2
AKGC8
Member#: 1305
2000 Impreza
Is this what you're talking about? If so I'm not sure. They mount to a point on the hub don't they. So they should be stationary, and not possible to rub the disk. Which makes me think the problem is with the rotors themselves. Maybe they're warped, do you feel any shaking while braking? This should be under warranty, so I'd just let Subaru deal with it.
AKGC8 is offline   Reply With Quote
Old 03-16-2002, 07:30 PM   #3
WRXnFX
Alaskan Mafia
Member#: 10398
Mike, take a picture and post it for our enjoyment. Maybe, we'll be of better assistance.
Winslow
WRXnFX is offline   Reply With Quote
Old 03-16-2002, 08:44 PM   #4
RawCode
Member#: 3115
2002 Impreza 2.5RS
Well it is at Subaru's lot right now so I will hafta take a picture tommorow. Didn't even think of that! lol....
But yes Eby is correct, it is that tire rod. It seems to be in contact with the back of the disk which is really stange. I do not see why it would be doing that, as it would be a rather large problem like a cracked knuckle or something... hrrmmm...
All I know for a fact, it that it had that metal on metal screech coming mainly from the front right. Brake pads do not make that sound unless they are totally worn down, but I just had my 15k inspection a little bit ago and I had 85% left.
Will take pictures tommrorow...
RawCode
Old 03-17-2002, 12:24 AM   #5
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Unhappy
uh oh... mine does that too i can really hear when the windows are open. i hear it when driving slow and it is coming from the front right. damn this sucks.
bus somedays i don't hear it at all.
AK_2002_WRX is offline   Reply With Quote
Old 03-17-2002, 04:11 AM   #6
WRXnFX
Alaskan Mafia
Member#: 10398
Both sides, huh? Keep us informed.
Winslow
Old 03-17-2002, 02:04 PM   #7
KapaFool
Member#: 2679
2010 WRX4FD
Cool
Maybe it was the spirited driving. Kris had a suspension problem in his old prelude. The torsion or sway bar broke or sumthing. Drove fine except for tight turns or hard drivin and then you can hear something bottom out. I think he was trying to keep up with porsches at the driving class.
KapaFool is offline   Reply With Quote
Old 03-18-2002, 04:10 PM   #8
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Question
any updates rawcode?
Old 03-18-2002, 11:42 PM   #9
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Any pics of the car??
Yep I shredded the rear suspension bushings on my Prelude. And yes....it was trying to keep up with Porsches at the driving school. That is what happens when you take too many fast corners on a crappy surface!
Kris
RallyX13 is offline   Reply With Quote
Old 03-19-2002, 04:31 AM   #10
RawCode
Member#: 3115
2002 Impreza 2.5RS
Welll I couldn't get any pictures yet as it was covered in all that awsome SNOW! But I did get the car back and they said they found no problem. And the car seems fine , as I have been rallying it ALL DAY driving around tonw. It is GREAT!
RawCode
Will get pictures tommrorow!
Old 03-19-2002, 04:36 AM   #11
AKGC8
Member#: 1305
2000 Impreza
Hmm, maybe you just had some ice built up somewhere that was causing it.
Old 03-20-2002, 01:45 AM   #12
RallyX13
Member#: 1543
2007 Jetta GLI
Yellow
Glad to hear that your car is OK!
I would really be interested in knowing what might have been causing it though.
Kris
Old 03-20-2002, 05:29 AM   #13
WRXnFX
Alaskan Mafia
Member#: 10398
FM man FM. Somethings work like that.
I'm down with Eby's hypothesis. Warm brakes melt snow. Water seeps into cracks, crevices, seals then refreezes. A night in the garage and Voila!!! F***ing Magic.
Funny you had this problem. After I got stuck that day, I had an ABS light on the way home. Everything in the wheel well was covered in snow. Turned up the temp in the garage. Next day, dry car and ABS light gone. I wasn't too worried about it because I figured it had to do with all the colorful comments I was giving the car when I was STUCK!!!! Sorry, baby.
Winslow
Bad/loose inner tie rod idioteque1025 Brakes, Steering & Suspension 4 06-06-2010 10:12 AM
Who can solve my mystery tie-rod problem? electricpork Brakes, Steering & Suspension 14 10-28-2007 10:14 AM
MOOG Inner Tie Rods (Ball Joints and Outer Tie Rods also mentioned) Kostamojen Car Part Reviews 7 01-13-2007 01:49 PM
turning Right is tighter than turning Left. tie rod problem? affinity1 Brakes, Steering & Suspension 1 05-19-2006 01:47 AM
is there any aftermarket inner tie rods and tie rod ends for subaru? Track Assassin Brakes, Steering & Suspension 2 01-28-2004 12:39 PM
