Old 09-22-2008, 06:11 PM   #26
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
is E85 readily available everywhere but cali? I keep seeing these threads but i've never once seen it at the pump.
Old 09-22-2008, 07:03 PM   #27
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Seems to be so, they're everywhere in Vegas.
Infamous1 is offline   Reply With Quote
Old 09-22-2008, 08:16 PM   #28
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Its spotty as to where E85 is available. I have two stations with E85 within 2 miles of my house, but I work 50 miles away. From work, the closest station are the two near my house. I wish it were consistently available. Alcohol is a great fuel...
thefoos is offline   Reply With Quote
Old 10-10-2008, 06:35 PM   #29
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
I live close in Culver City and there is an E85 station 10 mins from my crib and when im in SD. i know where there is a E85 station 10 mins from Coronado
Boxer112 is offline   Reply With Quote
Old 10-10-2008, 07:38 PM   #30
rewt
Member#: 60794
2007 Solstice GXP
You should really start tuning in terms of lambda. Makes it easier to switch between fuels. However since your using AFR (and I'm assuming it's calibrated for E85), you should be able to run leaner than 11.0 (I think I played around at 12.1-12.2 when I tested it), and it'll buy you a bit more head-room. You'll still run out of injector, but it should get you a bit more power.
IMHO, running two pumps and/or increasing fuel pressure will not solve your problem. Bottom line is: you need more injector. Then you'll probably need more fuel pump
rewt is offline   Reply With Quote
Old 10-11-2008, 05:51 PM   #31
swiftwrx1
Member#: 72352
06 E85 v-mount
wht/bronzse WFC#555
What turbo is being used?
swiftwrx1 is offline   Reply With Quote
Old 10-12-2008, 04:18 PM   #32
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
i thought this also.. whats good kid??
Max power out of 800cc injectors on E85? reddevil Built Motor Discussion 1 09-01-2008 05:05 PM
Emanage Ultimate and 800cc Injectors - Are these too big? MY99 2.5GT Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-15-2006 12:28 PM
FS:PSM trunk and 800cc injectors Abe Froman Mid Atlantic Impreza Club -- MAIC 15 01-12-2006 07:27 AM
Utec and 800cc injectors raucky Engine Management & Tuning 15 05-07-2004 12:25 PM
UTEC and 800cc injectors hobbzz Engine Management & Tuning 2 07-02-2003 10:24 AM
