Old 09-20-2008, 01:33 AM   #1
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
Subaru Banner FLI Tuned 320wtq/325whp Built Hybrid w/4Krpms power band!
STI 2.5L block w/100mm bore (supertech pistons, coated race main/rod bearings, cometic HG)
Stage 2 ported WRX heads
Jun 256 Cams, Supertech +1mm SS intake/Iconel exhaust valves
PE 800cc injectors
Blouch TD-05 20g Turbo
Link G3 ECU
COBB Intake and Cold Air Box
Custom Cusco catch can
Act flywheel and 6-puck race clutch
GrimmSpeed ported/coated headers and uppipe
GrimmSpeed 3mm phenolic spacers and coated intake manifold
APS TMIC (coated by GrimmSpeed) w/recirc BOV
APS Turbo Intake
Tuned by Miles at Fine Line Imports in Santa Rosa, CA. This is the Cliff's Notes version of this engine build since we had some issues at first, but I won't get into it in this thread.
Power comes on fast and smooth and pulls all the way to redline. 300whp at 3200rpms is pretty nice!! The blue/green base lines are my current tune. The other 'test' lines are with the stock WRX ecu, so he was able to put a bit more area under the curve with the Link G3.
This is on a mustang dyno, ambient air temp on the 'test' pull was around 75 degrees, temp on the current base pull was a bit hotter (about 10 degrees), which is why it drops at the end a bit.
Obviously big thanks to Miles, Steve and Ryan at FLI.
Also, to Trey Cobb for the intake and airbox, and Mike at Blouch for the turbo!!
And of course the rest of my sponsors!! Grimmspeed, L&E Fabrication, Metropolitan Motors, Project Solo Gear, Redline Oil (SF)
UP2MTNS is offline   Reply With Quote
Old 09-20-2008, 11:53 AM   #2
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
i get a red x
Paul is online now   Reply With Quote
Old 09-20-2008, 12:23 PM   #3
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Very nice, what CR did you get with that piston/head gasket combo?
slowmike is offline   Reply With Quote
Old 09-20-2008, 12:26 PM   #4
JohnnyChimpo
Member#: 187411
Love those guys at FLI, they do a great job. Good to see your build came out so well...
JohnnyChimpo is offline   Reply With Quote
Old 09-20-2008, 12:44 PM   #5
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
seems like good parts were used, but also seems like alot of effort for mediocre #s
SSFWRX is offline   Reply With Quote
Old 09-20-2008, 12:50 PM   #6
wrxhard
Member#: 108091
He's not looking for numbers, he's looking for a huge powerband. UP2's car is a rally car, not a 1320 car.
Edit: Yeah, the red x doesn't do your dyno sheet justice.
wrxhard is offline   Reply With Quote
Old 09-20-2008, 12:57 PM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
i don't even see the red x.
Old 09-20-2008, 01:51 PM   #8
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Originally Posted by Paul View Post
i get a red x
strange, I can see it....here my blog with a longer story. scroll down a tiny bit and click on the smaller graph:
http://psgrallywrx.blogspot.com/
Old 09-20-2008, 01:58 PM   #9
UP2MTNS
Member#: 112405
2004 WRX Rally Car
thx...yeah, remember its a dyno sheet....comparing dyno's between cars is silly. I'll put this car up against anyone with bigger numbers (but similar mods) on a non-mustang dyno anyday. The main point here being super fast spool up (td-05 hotside and GrimmSpeed coated everything) and a flat, predictable power band.
And yes, the final application will be an open class rally car (on schedule for mid next year), so I was looking for a built 'reliable' race engine...but it doesn't need to make huge numbers because it'll get a 34mm restrictor next year and that's bring torque up a little, but drop total HP.
In the meantime, I just wanted a fun street car I'm also currently on DMS 50mm's, which are fun!
OK, I just re-hosted this on imageshack, lets see if it works:
Old 09-20-2008, 02:14 PM   #10
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
how much boost? i agree seems like too much went into the car just for that kinda power level (not talking about dyno numbers, talking about what a 20g is capable of)
godforbid67 is offline   Reply With Quote
Old 09-20-2008, 02:22 PM   #11
UP2MTNS
Member#: 112405
2004 WRX Rally Car
i need to double check with Miles, but they were custom pistons for lower CR with the hybrid set up and stock WRX gasket thickness. I think it was around 8.2.
Old 09-20-2008, 02:23 PM   #12
UP2MTNS
Member#: 112405
2004 WRX Rally Car
yeah, its a safe tune for sure. peak boost is only 18.5lbs. afr's at wot is ~10.9. And I like the fact that the engine is 'overbuilt' for 320wtq...hopefully it'll last a while under harsh conditions on the stages.
Old 09-20-2008, 04:04 PM   #13
Galen
Member#: 156753
Nice build Jon, this is the first time I'v got to read a full write up on the engine. +1 for building it for reliability and longevity. That power ban is AWESOME!!!
Galen is offline   Reply With Quote
Old 09-20-2008, 06:49 PM   #14
Paul
Member#: 56203
00 RSTI Coupe
I know this isnt a 1320 car but why do the "test" pulls make better power pass 6250?
Old 09-20-2008, 10:18 PM   #15
urfsin
Member#: 128975
2005 Outback XT
Golden Thunder
I don't know if you race your car or not (and I am not talking about on the street you knuckle head ), but when you do, you will find that it is not about peak #'s. Its about powerband and reliability. It's better to have an overbuilt engine that will get you through the race and give you a chance to win in the end.
urfsin is offline   Reply With Quote
Old 09-21-2008, 12:17 AM   #16
outback2.5HO
Member#: 15135
95 GF WRX
Nice fat torque and hp curve..
Those heads sound very similar to a set I had on my car for a bit. They were sweet.
300wtq/whp is good power at 3200 rpm. But once that restrictor is in, most of all the power over 5k will be lost. Usually about 5200 is when the choke happens on the hp #s w/ a 34mm. Basically the top 2k of that powerband will be gone or cut drastically. That's the crappy part about the restrictor. Now you need to gravel tune it with Miles in the right seat. The afr's change drastically with the wheelspin on gravel.
Is that a pump or race gas map? If pump, there's more power on the table. Now you need to hang on to the 300wtq on a stage.. It's going to take quite a bit of practice on gravel to get used to it, and a rally x isn't long enough to tap it out in 5th.. do you still have a stock 5 speed in there?
Better get that cage in sooner than later for "testing"..
outback2.5HO is offline   Reply With Quote
Old 09-21-2008, 01:28 AM   #17
godforbid67
Member#: 137168
06 Built SGM WRX
i am such a knuckle head. how did you know that i was going to think of street racing when you asked that???? real funny.
and racing is about powerband and reliability? i did not know that........
anyway to the op, good luck with your car.
Old 09-21-2008, 07:44 AM   #18
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Is everyone not seeing the tdo5 ? That is as small 20G most likely with a 7cm hot side. While not ideal for top end power it is perfect for his application. I had this set up on my hybrid for a few weeks. It was very strong on just the break in map. Spooled instantly but ran out of steam up top on the break in map. Boost was hard to control too. Sometimes I wish I had just gone EWG , cams, tune and kept that turbo.
Tenacious Bee is offline   Reply With Quote
Old 09-21-2008, 01:15 PM   #19
UP2MTNS
Member#: 112405
2004 WRX Rally Car
^^That's it exactly^^ 8cm option would have been a waste...
Old 09-21-2008, 01:20 PM   #20
UP2MTNS
Member#: 112405
2004 WRX Rally Car
+1....you read it perfect, Barrett...and you should know . Yes, Miles already told me about the AFR's changing w/wheel spin. that'll all happen next year with when the restrictor goes in.
And yes, its pump gas, I won't move up to race gas for a while, until I learn to control it all better and actually finish a few rallies. Right now, its a lot to handle on gravel (with snow tires, no less) but I'm getting better at it.
and yes, still w/the stock 5MT. I actually had him pull the the boost a little in 1st gear cause the torque hit so hard, I didn't want to break anything. I'll runny the stock tranny through all of next year, or until something breaks (crosses fingers).
Old 09-25-2008, 03:12 PM   #21
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Fun Bump
Old 09-25-2008, 03:18 PM   #22
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
where did you buy your JUN cams? I'm looking to get a set of 272's!
domestic_abuser is offline   Reply With Quote
Old 09-25-2008, 04:57 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
that stuff down there is called torque
Old 09-25-2008, 05:44 PM   #24
ftnjun2x
Member#: 107096
04 WRX
I keep hearing a lot of good things about Miles from FLI but how 'bout that dude Ryan? I guess he's just the secretary(joke). I hope to deal with these guys again in the near future.
ftnjun2x is offline   Reply With Quote
Old 09-25-2008, 06:11 PM   #25
UP2MTNS
Member#: 112405
2004 WRX Rally Car
they came with the heads that FLI already had setup, so I didn't personally source them, sorry.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
JR Tuned / TURBOTRIX Racing Built / [email protected] @25psi DRAG STi OVeRBOOSTn Proven Power Bragging 1727 03-24-2013 11:19 PM
Built hybrid - GT35R - 92octane + meth - dyno tune CoolRex Proven Power Bragging 62 01-31-2010 07:38 PM
MD: Built 30r STi, Advans, V-Band turbo Kit ect... tdiesel Private Vehicle 'For Sale' Classifieds 60 01-01-2010 10:27 PM
the great debate built ej207 or built hybrid? waldo Built Motor Discussion 21 07-01-2009 12:12 AM
