Old 09-21-2008, 04:44 AM   #1
fastwrx25
Member#: 126441
03 bugeye
Default easiest way disconnecting cruise control cable from TB, cruise control removal 02-03
For those who have removed your cruise control on your drive by wire cars, how did you remove the cable from the TB assembly? Do I push out the rod that holds the wire to the assembly? whats the easiest way to do that and how did you guys keep the CC rotating plate thing from flopping around after the cable is removed?
I never ever use cruise control and I'd like to get rid of it and sell it. I've searched but no luck in finding solid info or DIY for this.
thanks
fastwrx25 is offline   Reply With Quote
Old 09-21-2008, 03:42 PM   #2
Arctic Penguin
Member#: 119532
2006 WRX
taking this apart is just about the most straightforeward, uncomplicated thing you could ever do.
it it isnt plain as day
god help ya
Arctic Penguin is offline   Reply With Quote
Old 09-21-2008, 05:01 PM   #3
fastwrx25
Member#: 126441
03 bugeye
sorry I meant drive by cable, not dbw.
Old 09-21-2008, 05:18 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
and I meant
iF it isnt plain as day after looking at it for a second or 2
god help ya
i removed the tb for porting
taking off/apart the cables from the tb took a minute or so
VERY simple
VERY easy
Old 09-21-2008, 07:30 PM   #5
GeneralTJI
Member#: 152680
It is indeed very simple...
there are two jam nuts holding the cable onto the intake manifold... take one nut loose, slide the cable out of the bracket, this will now allow enough slack to unhook the end of the cable from the TB. Then remove the actual cruise control unti, just a couple bolts if I remember correctly.... and the plug... thats about it... takes 5 minutes in all....
GeneralTJI is offline   Reply With Quote
04 WRX Interior for 02/03 Interior or WRX TR Interior cartwheels4amile SCIC Private Classifieds 5 06-04-2010 11:53 AM
Easiest way to remove rear axles from R180? 2005 Transmission (AT/MT) & Driveline 8 03-13-2007 05:27 PM
Easiest way to create a DVD from AVIs? Neek Off-Topic 6 09-23-2005 10:10 AM
What's the easiest way to run cables? ZenerDiode Car Audio, Video & Security 9 02-11-2004 12:40 AM
easiest way to extend battery cable to optima loudsubbie Car Audio, Video & Security 3 06-16-2003 06:37 PM
