Old 09-21-2008, 05:46 PM   #1
stamps31757
Member#: 189810
2002 WRX Sedan
Default wiring
I own a 2003 wrx that is in great shape. I am getting a 2004 sti that has been wrecked. I am looking to swap the engine and transmission over to the wrx. In the process i will be rebuilding the whole car. Wouldn't it be easier for me to remove all the wrx wires and just install the STI wires and just splice the connectors where they go for all the accessories? I'm new to the whole conversion deal so i am wondering what will be my best rought.
stamps31757 is offline   Reply With Quote
Old 09-21-2008, 06:20 PM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
I believe you can merge the harnesses, But if you want everything just use all the STI wiring, im just bumping your thread also, How much for the WRX stuff?
parkes is offline   Reply With Quote
Old 09-21-2008, 07:08 PM   #3
stamps31757
Member#: 189810
2002 WRX Sedan
i'll have to get everything put in the wrx and it running before i sell anything. I have to make sure everything will work as i want it to
Old 09-26-2008, 12:42 AM   #4
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
What you're going to do is merge all the wrx non engine/tranny management wiring into the sti ecu while leaving all the sti wiring alone. Since you have the whole car, if the dash and everything else will fit into the wrx, that's probably a quicker/easier route.
It's easiest just to think about what you're changing when you go through each wire in the ecu. Make sense of what you're doing with each wire and it will be easy.
You'll also have to wire in the new fuel pump (I think, I'm not sure about wrx to sti on that one) and your OBDII might need to be rewired too. Just compare the diagrams.
It amazes me how much I forgot since I finished my swap in June
mannac is offline   Reply With Quote
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
FS: WA, 2 AMP Wiring Kit GOOD wires, BIG 3 wire kit 4bangers4life Interior/Dressup/Audio & Security 1 12-21-2009 02:33 PM
Wiring... shielding speaker wire from power wire badkid Car Audio, Video & Security 3 11-14-2003 06:53 PM
wiring question- keep the amp power, speaker wires away from input wire? garie Car Audio, Video & Security 5 06-20-2003 06:25 PM
Need wiring color for stock WRX rear speaker wires. GDA Car Audio, Video & Security 0 06-10-2001 11:29 PM
