Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 02-21-2009, 04:31 PM   #276
silver-duck
Member#: 130710
Where is this product now?
silver-duck is offline   Reply With Quote
Old 02-23-2009, 01:55 AM   #277
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
I have 4 plates still available. silver-duck - I PM'd you.
The bad news is that due to recent economy-related happenings at my primary job, I will have to take on a lot of added responsibilities and that will make for some very long work days. Unfortunately, this means Nighthawk will continue on, but only focusing on a simplified product line-up that is not as intensive on fabrication work. With the added work-load, I'm not so sure that I will be able to maintain a steady level of production on the braces, but I'm still working on solid shifter bushings and since I already have a source on bolts, I'll still keep a full class 10.9 bolt kit available for the Subaru 5mt which would be a great option for folks who are rebuilding a 5mt and want better hardware to keep everything clamped together.
The good news: I just took delivery of a rather nice new Miller plasma-cutter, as well as a very handy mill/lathe combo machine that I'm planning on converting to full CNC operation, so I'm not giving up on the business that easy.
This is not necessarily the end of the 5mt reinforcements, but I won't be able to produce them quite as quickly as I had originally planned until the economy recovers a bit and I'm a relieved of some of my interim duties at work. Though I will still be producing them slowly and in small numbers to sell them as I have free time to make them available.
The plan: I have put together a list of potential customers by order in which they requested pricing/availability either through this thread, through PMs or through e-mails to my Nighthawk e-mail address. I will be going down the list and contacting these customers (in this same order) to give interested parties first dibbs on the 4 plates that I currently have left based on how early on they contacted me. That seems to be the most fair way in which to go about things. I really apologize for inconveniencing or disappointing anybody, but the current state of the economy is actually starting to really hit home.
As I produce more reinforcements in smaller lots, subsequent orders will still likely be handled through DS1.
jhargis is offline   Reply With Quote
Old 02-25-2009, 11:17 AM   #278
jackansi
Member#: 23894
'07 3.2L Audi A4
Can I buy one of these yet? You sold me on the second page
jackansi is offline   Reply With Quote
Old 02-27-2009, 03:58 PM   #279
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
me too
Vlad is online now   Reply With Quote
Old 03-01-2009, 12:51 PM   #280
thereplacement
Member#: 183624
also interested
thereplacement is offline   Reply With Quote
Old 03-01-2009, 01:35 PM   #281
Daggah
Member#: 152077
2002 Integra Type R
Championship White
How complicated will these be to install?
Daggah is offline   Reply With Quote
Old 03-03-2009, 12:57 AM   #282
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
Originally Posted by Vlad View Post
me too
Originally Posted by thereplacement View Post
also interested
Noted... I'm in the process of going back through my various PMs and e-mails, as well as folks who have posted their interest on this thread. I'm compiling a "waiting list" of sorts...
I can only pump out about 2 plates and 2 diff braces or so per week tops right now, so I'll still be making them (just made 2 more diff braces tonight, in fact), but it'll be slow. Once I get a little free time to do some negotiation, I'm interested in finding a 3rd party fabricator to relieve me of some of the work as well, so that could speed things up a bit.
The diff brace will be pretty easy, maybe about an hour or so with the trans in the car for any mechanically inclined person (It's in a pretty accessible spot). Loosen 2 nuts/bolts, thread an already factory-drilled hole in the trans with a cheap 8mm/1.25 tap found at your local autoparts store, slap the brace on and re-torque the nut and bolts.
The plate is very easy with the trans out of the car. But it's pretty tight with the trans in the car. If you remove the driveshaft, shift linkage, and trans cross-member, you *MIGHT* be able to drop the trans down a little bit and get enough space for the top bolts to clear the trans tunnel, but I'm not sure on that one... It's tight in there and the top rear bolt with the plate is 200mm long. I'd recommend doing the job with the transmission out of the car... A clutch change or other repair that requires the tranmission to come out would be a great opporunity to install that reinforcement plate as a "while-yer-in-there" item.
Old 03-06-2009, 02:43 AM   #283
piddster
Member#: 144285
1993 UHEV Legacy
Rectangular supports are not going to provide significant reinforcement on a case constructed as is. When proper gears fix the inherent problem, this leads most to believe that the problem was in fact the gears, not a flexing case. Notice how most gears shear: at the base of the tooth. If the teeth were actually separating a significant amount, the shear stress on the tooth would rise significantly at the point of contact as it moved away from the base of the gear tooth. The bending moment on the tooth would go down as the teeth moved further apart if the case was actually flexing.
How about someone's opinion on case flex who has inside out and upside down with these these boxes?
http://bbs.legacycentral.org/viewtop...+flex&start=25
piddster is offline   Reply With Quote
Old 03-06-2009, 08:27 AM   #284
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
that guy already has several things wrong....so I won't be listening to that link. I also from a personal opinion this is designed nor will it be the end all of breaking 5-spd trannies...they will still fail but I think at a higher level. You can almost reason that having no case flex will put more direct load (force spike) on the gears and cause a quicker failure as the case no longer flexes as a dampner to the force seen by the gear.
Think progressive spring vs linear spring.
Old 03-06-2009, 12:39 PM   #285
carnz-pj-410
Member#: 110994
1998 2.5 RS
1995 2.5 RS Clone
im interested in this, the thread has been a good read so far
i've torn these 5mts apart many times, but since theyre all customer jobs here i've never looked into reinforcements or case flex. thanks for all the good info
carnz-pj-410 is offline   Reply With Quote
Old 03-06-2009, 01:06 PM   #286
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
Hey, you're definitely entitled to your own opinion. Remember however, that gear teeth are not a perfect triangle... They are machined with a rounded profile, so actually the heaviest load is usually placed somewhere near the middle of the tooth... As a gear seperates and you move that load out toward the tip of the tooth, the drive tooth has a larger leverage advantage on the root of the driven tooth. That's also why gear teeth tend to pop off at their base when you rebuild a transmission and set the gear lash too wide. That posts also doubts shaft flex. My product does little to prevent flex in the long portion of the input shaft ahead of the front input shaft bearing, but I can tell you that the input shaft is FAR more flexible than one would think, and I'd bet input shaft flex is the biggest problem of all in the equation.
A)In regards to the plate. My experience shows that the case flexes torsionally in that area. But I guess Subaru spent a good bit of money changing the case castings for no reason ... I suppose they found no flex in that area of the case, but decided "Hey, let's stregnthen up the top and bottom of the case, and get longer more expensive bolts in there for the heck of it." That was a stop-gap fix for a weak transmission case on Subaru's part, the point of my plate is to further reinforce that part of the transmission. Ever tried to twist a 4.75" wide 1/4" thick cold-rolled steel plate? It takes some effort, quite a few tons in a press-brake. I can put a 1" thick piece of cast aluminum in a press-brake on the same die and tear it into 2 pieces at the same tonnage.
B)And as for the diff brace, I'd say there's some flex, Look below:
I agree completey that my braces are not anywhere near being the end-all for 5mt failure. I do think the diff brace helps prevent the problems pictured above in higher hp cars. They just provide a better foundation. There is flex in the case, no doubt, and it can't be good. I'd think that minimizing gear speration and preserving gear alignment during heavy load would be far more advantageous than allowing the flexible case to absorb shock in the procees of allowing the gears to seperate so much.
Old 03-06-2009, 01:12 PM   #287
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
On another note, I will be suspending production for about a month. Just got a deal I couldn't refuse on some more sq. footage for my shop through a family member, so I will be moving tools/machinery over there in the next couple of weeks. Got the new monthly forecasts at the day job, and let's just say it looks like I'll have more free time in the next couple of months, so I should be able to find much more time for my own business (mixed blessing, I guess?).
Old 03-13-2009, 02:53 PM   #288
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
Very interesting info here. I've been thinking of doing something similar but never got around to it due to lack of time.
You can put me on that waiting list as well please.
Thanks,
Alex...
amelnikov is offline   Reply With Quote
Old 03-19-2009, 05:01 PM   #289
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
+1 Ill wait.
srREXed is offline   Reply With Quote
Old 04-22-2009, 11:05 PM   #290
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
So how well is your part working now? I am considering this or a 6mt. As I am told that my case may have caused the 2nd gear sound and damage I am experiencing on my ppg gears.
Old 05-10-2009, 09:39 PM   #291
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
Any news on that brace?? And how is it helping your RA gears?
Regards
Ferraz is offline   Reply With Quote
Old 05-11-2009, 08:14 AM   #292
05Scooby
Member#: 153216
2005 WRX stage 3
CGM
Damn.. I just cracked my trans.... Apparently I caused enough distortion to lock up the trans, and cause a nice crack in the case...
05Scooby is offline   Reply With Quote
Old 05-11-2009, 11:03 AM   #293
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
That sucks! I realy want to know if that brace can help... We don't get STI trannys around here... I need any other option to help my tranny...
Old 05-14-2009, 06:22 PM   #294
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
Sorry for the delay guys, I was hoping to have the shop together in the new location by mid april, but I suppose I underestimated the amount of work needed. The new place is now completely re-wired from the ground up, even got myself some air conditioning for the hot weather!
Most of my machines are set up, and the newest additions (plasma cutter & bigger metal lathe) are tested and running flawlessly, so I'm hoping to be back in business in the next couple of weeks.
Old 05-17-2009, 01:25 PM   #295
slo07wrx
Member#: 151076
2007 Impreza
UGM
PM me when u have a few of these things sitting on the shelf.. money in hand waiting to buy...
slo07wrx is offline   Reply With Quote
Old 05-18-2009, 04:16 AM   #296
cubuff
Member#: 38345
2004 WRB WRX
But according to BAC5.2 case flex is a myth!!??? huh, thats weird!
cubuff is offline   Reply With Quote
Old 05-20-2009, 12:06 AM   #297
06Limited
Member#: 118112
2006 WRX Limited
DO WANT!!! PM me with a price and an expected date for manufacturing.
06Limited is offline   Reply With Quote
Old 05-20-2009, 04:06 PM   #298
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
interested let me know a price please
Thom is offline   Reply With Quote
Old 05-20-2009, 06:23 PM   #299
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
Out of curiosity, where on the case did a crack appear?
The shop is pretty much done and ready to go. I'm buying materials for the next run this Sat. so I should have some ready to go, I'll say within a couple of weeks roughly. Business is pretty slow for my bolt supplier so they're a bit sluggish these days, last time I ordered bolts, it took almost 2 weeks for them to come in, so that may be my biggest limiting factor. Overtime at the day job is pretty much grinding to a halt as well, so I'm finding myself with a lot more free time to get this stuff done!
As a note: I'll be deleting the cross bracing on the plate in subsequent runs. The plate itself is pretty strong, and based on some testing done in solid works by Dylan & Jeff a while back, it's kind of overkill. That will speed up production time, and lower cost a bit, so I'll be re-working the price of the plate a bit (lower). The diff brace will remain pretty much the same for the time being.
BTW, sorry my PM box is full, I'm trying to hold on to messages from nasioc folks that contacted me earlier on in the design process so I can be as fair as possible for the first-come-first-serve crowd. As soon as I get some free time, I'll archive those messages to free up my inbox.
Also, again, I really apologize for the huge delay in moving the shop... It's been quite a set-back and a heck of a project, but it will definitely pay off in the long run on all counts. It's just easier to built things for a reasonable price, at a better level of quality, and more quickly when I have room to move around with a better layout for all of my machines/tools . I wanted to get Nighthawk Autmotive set up the right way, and having the appropriate sq. footage makes things much much easier. And thanks again to all of you for your support and interest.
Old 06-17-2009, 12:31 AM   #300
charliew
Member#: 125304
So are there any parts for sale?
charliew is offline   Reply With Quote
Feeler: Developing a reinforcement for the 5mt case jhargis Transmission (AT/MT) & Driveline 36 09-24-2008 08:18 PM
The power switch is going out in my case. bomber991 Off-Topic 9 02-05-2008 04:54 PM
What is going on with my '99 legacy GT LTD 5MT jw5216 Electrical & Lighting 1 11-24-2007 10:54 AM
WTB: 5MT case Starkiller New England Impreza Club Forum -- NESIC 6 09-21-2005 12:04 PM
v6 STi RA gearset in 5MT case, motor, and VF22 BoostdScubaru Private 'For Sale' Classifieds 42 10-22-2004 06:15 PM
