Old 05-31-2012, 02:36 PM   #426
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Seems to be the lash between gears that widens and therefore cause more force applied to a smaller area. Now what is the cause of the shaft alignment moving is the question.
Seems to be case flex
dirtslayer is offline   Reply With Quote
Old 05-31-2012, 03:09 PM   #427
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Question in red, answer in green. The more force that is applied through the trans causes that shaft to move. When that shaft moves it spreads the teeth apart, when the teeth spread apart, their is less surface area contact and then gears break.......this is what I have heard in the past from speaking with people who know about subaru transmissions. Take it for what its worth... dont launch or white knuckle shift/slam gears and u should be fine. Transmission break because of users, not themselves.
shamrock 05 is offline   Reply With Quote
Old 05-31-2012, 03:17 PM   #428
dirtslayer
Member#: 242550
olive drab
Correct. But what the bracing is designed to do is keep the case/bearing cradles more indexed which keeps the shaft straight and gears meshed.
So it could work.
I'm worried even tho I don't slam shifts and no launches. 400tq is love/hate
Old 05-31-2012, 04:30 PM   #429
shamrock 05
Member#: 120057
^^^^400 wheel Tq= a sti 6 speed or a PPG gearset, not a "I hope my stock 5 speed will last" but more like it will for sure......if ur gonna build your car to be that fast, u have to think of more than just motor. 400 whtq will snap teeth during normal acceleration man. Good luck man.
Old 05-31-2012, 04:32 PM   #430
vicious_fishes
Member#: 158864
2003 SOHC destroker
but we're talking about preventing the case from breaking, not the gears.
vicious_fishes is online now   Reply With Quote
Old 05-31-2012, 04:53 PM   #431
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
You do know that a helical gear is much stronger than a straight cut gear right? That's why the ppg's are successful in holding much more power/torque in the 5spd's. The problem with a helical gear is that as well as transferring power, there is also side loading generated from the slight angle of the gears when they are meshing. This is what creates the case flex. Once the case is flexing and its arms t-rexing.... The clearances of the gear mesh go out the window.
It gets more complicated as to why a helical ppg gearset is stronger than an OEM. Pressure angles, tooth radi and so on...
But making sure that the side loading from a helical gearset doesn't cause case "flex" is one of the best things you can do, aside from going straight cuts. That's why Moore performance is offering this product, its not the end all be all of transmissions, but an affordable compromise that will be applicable to more of the market share than an all out straight cut dogged gear set.
bettner12 is offline   Reply With Quote
Old 05-31-2012, 04:55 PM   #432
bettner12
Member#: 56179
05 LGT 407hp/372tq
This product is to increase the power holding capabilities of your gears, not to prevent the transmission case from cracking, even though that is a by-product of its design. You by doing one, you acccomplish the other.
Old 05-31-2012, 05:25 PM   #433
dirtslayer
Member#: 242550
olive drab
Agreed to all.
By any chance, does anyone have the bolt specs to be used?
I need to buy some high grade case bolts and make my plates up.
Old 05-31-2012, 09:19 PM   #434
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
I have spoken to the guys at AndrewTech and they have said the case flex is nonsense. But whatever makes u sleep better at night
Hey there are smarter more experience people out there I'm just saying that the case could flex without splitting the case at the bolt together seam.
I make no clam to have info that the case does flex.
R-
labcoat is offline   Reply With Quote
Old 06-01-2012, 11:11 AM   #435
shamrock 05
Member#: 120057
Buy what u want man, but ppg's are offered in helicle and straight cut. The ppg straight cut are stronger (better tooth engagement) than the helicle. It also comes down to what material the gears are made of. its like comparing stock pistons to forged pistons
And yes their are probably smarter people, but I would not knock the people and products at AndrewTech or PPG. They know what they are doing.
Old 06-01-2012, 11:16 AM   #436
bettner12
Member#: 56179
05 LGT 407hp/372tq
no, you buy you want. I know how this stuff works.
Old 06-01-2012, 12:57 PM   #437
shamrock 05
Member#: 120057
Wishful thinking never hurt anyone, but do u have a BOV and cold air intake on ur car as well......cause I heard those do wonders also
Old 06-01-2012, 01:51 PM   #438
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Lollollol
CobbWRX is offline   Reply With Quote
Old 06-02-2012, 12:45 PM   #439
bettner12
Member#: 56179
05 LGT 407hp/372tq
"the use of helical gears is indicated when the application involves high speeds, large power transmission, or where noise abatement is important. The speed is considered to be high when the pitch line velocity exceeds 25 m/s.[7]
A disadvantage of helical gears is a resultant thrust along the axis of the gear"
"Strength: For same tooth size (module) and equivalent width, helical gears can handle more load than spur gears because the helical gear tooth is effectively larger since it is diagonally positioned."
"Helical gearing is machined to have angled teeth, then hardened and ground to achieve an efficient gear mesh. The teeth angle enables the gears to gradually mesh. Thus, two or three teeth of each gear are always in contact with other gears. This configuration lessens the load on each tooth and creates a smooth transition of forces from one tooth to the next. The result: less vibration, wear, noise, and a longer life.
Helical gear reducers come in many shapes, sizes, and configurations, helping you eliminate high wear and high maintenance parts such as belts, pulleys, chains, and sprockets.
There are two common quality indicators in gearing—high noise and vibration—which result in low precision and limited life.
Rotating machines that generate high noise and high vibration can have any number of quality issues. Rotating components may not be balanced properly, which causes vibration. Mating components may be machined to tolerances that are not precise regarding perpendicularity, concentricity, and true position. Or, components may not be rigid enough, flexing under load, which can result in misalignment. "
Old 06-02-2012, 10:37 PM   #440
vicious_fishes
Member#: 158864
2003 SOHC destroker
and here i thought it was the other way around. intredasting.
either way i want one.
Old 06-02-2012, 10:39 PM   #441
vicious_fishes
Member#: 158864
2003 SOHC destroker
all this said... why would they even bother to offer straight cuts then? i mean helical would be both stronger AND quieter if what you're saying is true... making straight cuts inferior in every way except thrust pressure.
Old 06-03-2012, 12:51 AM   #442
stephens
Member#: 124581
With those sentences together (start and finish of your post), wouldn't it make sense as to why the straight gears have a higher life expectancy with them having a better chance of meshing when rotating?
It also makes sense that they are better when most heavy machinery (lathes) use straight cut gears rather than helical. Watching videos of straight cut gears in a wrx should explain why subaru wouldn't mass produce a product that sounds like a jet taking off all the time.
stephens is offline   Reply With Quote
Old 06-05-2012, 12:15 PM   #443
sorrowfulkiller
Member#: 170439
I <3 Lamp
All this talk between the pros and cons of helical vs straight cut is pointless... basically it boils down to this, the wrx 5 speed case is ****, it flexes so much that the gears should be straight cut if you want to hold any decent power for long periods, whereas in the sti 6 speed or better designed transmissions they should use helical since they are stronger with a non-flexing case.
Discussing this any further is just wasting time.
sorrowfulkiller is offline   Reply With Quote
Old 06-07-2012, 04:43 PM   #444
Moore Performance
Member#: 231489
Just to update everyone, we have hardware, we have sets that have gone out and here's a pic from a customer that did his install last week.
I've contacted the 6-10 group of guys about the plates that are ready to go (please check emails) and the remaining plates are ready to ship next week after we return from Wicked Big Meet. Keep eyes out for emails and pm's!
Moore Performance is offline   Reply With Quote
Old 06-07-2012, 09:32 PM   #445
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Are you selling any of these @ WBM?
skimobile is offline   Reply With Quote
Old 06-08-2012, 08:20 AM   #446
Moore Performance
Member#: 231489
We will be taking orders at WBM. Our first priority is to fulfill the group buy orders, but we will have a demo set on hand for viewing, etc.
Old 06-08-2012, 09:02 AM   #447
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
When are these going to be available?
Ian @ Performance Auto Solutions
rexworx is offline   Reply With Quote
Old 06-08-2012, 08:16 PM   #448
skimobile
Member#: 92114
03 WRX (NAVY Camo)
Can this be installed with the tranny in place or will you have to drop the transmission to permit installation of fasteners, etc....
Old 06-09-2012, 01:23 AM   #449
vicious_fishes
Member#: 158864
2003 SOHC destroker
you'll have to drop it.
Old 06-09-2012, 02:15 PM   #450
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Do you know for a fact the transmission needs to be dropped?
Any posts I have seen on this product give the supposition that it needs to be dropped, but nothing that it absolutely has to be dropped.
From what I've seen, the only ones who have installed this so far already had the transmission out for other reasons. Even Ryan Moore said in the Group Buy thread that the engineers believe that the transmission needs to be dropped, not that is has to be dropped.
I've looked closely and it looks like I may be able to do this on my WRX without moving the transmission. I won't know exactly until I try it, but there appears to be enough room to remove the bolts completely out, and re-install.
Samurai Jack is offline   Reply With Quote
Feeler: Developing a reinforcement for the 5mt case jhargis Transmission (AT/MT) & Driveline 36 09-24-2008 08:18 PM
The power switch is going out in my case. bomber991 Off-Topic 9 02-05-2008 04:54 PM
What is going on with my '99 legacy GT LTD 5MT jw5216 Electrical & Lighting 1 11-24-2007 10:54 AM
WTB: 5MT case Starkiller New England Impreza Club Forum -- NESIC 6 09-21-2005 12:04 PM
v6 STi RA gearset in 5MT case, motor, and VF22 BoostdScubaru Private 'For Sale' Classifieds 42 10-22-2004 06:15 PM
