Old 07-05-2011, 02:13 PM   #326
RCMS
Member#: 287517
2005 Impreza WRX
Obsidian Black Pearl
Thanks for the huge info in this topic! I'm completetly blown away with it! It helped me A LOT!
RCMS is offline   Reply With Quote
Old 07-10-2011, 09:21 AM   #327
wrx904
Member#: 97365
2015 Mustang PP SC
This is a really good post and I think more people on here should read it. There are too many sheep on here that thing a BOV will hurt your engine.
wrx904 is offline   Reply With Quote
Old 07-10-2011, 10:34 AM   #328
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by michael_cano View Post
why don't people ever talk about recirculating their vta bov's? it takes away from the "clunky" feeling that you're going to stall. all this hate for bov's, recirc them, and you're car runs fine.
Because a properly adjusted and working VTA won't give you that feeling.
i_c_the_light is offline   Reply With Quote
Old 07-13-2011, 11:52 AM   #329
cam07
Member#: 284006
2007 Wrx Tr Stage 2
What's the opinion on the turboxs hybrid? I keep hearing the turboxs RFL makes them run like **** at idle and the hybrid works the same while driving but fixes the idle issues
cam07 is offline   Reply With Quote
Old 07-14-2011, 08:57 AM   #330
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Originally Posted by Soobahrue View Post
Someone told me turbosmart dual port was good. But I don't know! Someone else confirm and some other good brands too please!
I personally didnt like the Turbosmart. Upon every shift it would sound like a shotgun blast, when the afterlight would occur. Was annoying as hell. I was running it 50/50 and no matter how I would adjust it, it always had a rediculous afterlight.
Just my .02
I will sell you my Dual Port if youd like. CHEAP.
2Fast4U1DAY is offline   Reply With Quote
Old 07-14-2011, 04:11 PM   #331
itzroger13
Member#: 286251
2003 Bugeye
Sonic Yellow
I have an RFL and I have NO problems. It idles perfectly and I like how it sounds.
itzroger13 is offline   Reply With Quote
Old 07-20-2011, 10:31 PM   #332
Frederico514
Member#: 285226
Nice write up Dave..,supr helpful info.
I personally have a drop in filter n deleted the airbox snorkus, decent sound(not too obnox...)and i dont have to worry about my stock BPV leakn!
But like u said, it all dependa on wut u want?!
Frederico514 is offline   Reply With Quote
Old 07-26-2011, 12:40 PM   #333
Strider327
Member#: 131280
2004 Impreza WRX
With all the BOV's out on the market today, here is what I have learned. Diaphragm BOV's usually tend to leak over time or actually do not close all the way. Piston type BOV usually work a lot better. As far as which one is the best for venting to atmosphere without causing problems (taken into consideration you have chosen the CORRECT spring and did the correct adjustments to the BOV) it would hands down TIAL, APS and last but not least the HKS Racing Valve. Others just leaks like crazy over time.
Strider327 is offline   Reply With Quote
Old 07-26-2011, 01:37 PM   #334
wrx904
Member#: 97365
2015 Mustang PP SC
I have never heard of a bov effecting idle. And how could it? It would be closed at idle.
Old 07-26-2011, 06:34 PM   #335
johnathanb24
Member#: 289541
2004 STi
is it worth it on a completely stock setup?
johnathanb24 is offline   Reply With Quote
Old 07-26-2011, 08:33 PM   #336
AFReese09
Member#: 276722
2006 WRX STI
Crystal Grey Metallic
Thanks for the info Dave.
AFReese09 is offline   Reply With Quote
Old 07-27-2011, 08:56 AM   #337
quazimoto
Member#: 70395
Well what do you think happens when it's not completely closed or sealed? It's called a vacuum leak and it happens all the time with a crappy or defective valve.
quazimoto is online now   Reply With Quote
Old 07-28-2011, 09:36 PM   #338
Strider327
Member#: 131280
2004 Impreza WRX
No it is not worth it on a stock car unless you are running a huge turbo or just enjoy the sound of one. A lot of bov leak like crazy at idle because of things such as a weak diaphragm and such. Of all the bov's I've seen, Tial has still been the only one to work perfectly when using the CORRECT spring to make the idle vacuum.
Old 07-29-2011, 05:20 PM   #339
Supercheech
Member#: 159178
07 blk N blu STi
Invidia -> Helix, AP stg2
So...unless you get a bigger turbo or like upgrade, a BOV on a stock STi is just going to give more sound? agreed?
absolutely no more power or benefit UNLESS you got a bigger turbo?
Supercheech is offline   Reply With Quote
Old 07-29-2011, 05:35 PM   #340
ardevas09
Member#: 164710
05 440whp STi
2014 Evo X
it's not the size of the turbo, but the psi at which your specific turbo is running
Moreover, you are not going to gain ANY power from a bov, none what so ever.
ardevas09 is offline   Reply With Quote
Old 07-31-2011, 05:26 PM   #341
zohh_amaze
Member#: 158592
2004 4Runner V8
I got a brand new TurboXS hybrid for sale
zohh_amaze is offline   Reply With Quote
Old 08-03-2011, 12:25 PM   #342
PhillyWReX10
Member#: 253625
2010 WRX
Dark Grey Metallic
Great article, cleared a lot of things up.
PhillyWReX10 is offline   Reply With Quote
Old 08-05-2011, 05:38 AM   #343
dundunskeert
Member#: 184151
2000 STI RA Limited
Took my recirculating tube for my stock BOV off and found that the stock one leaks a ton. Like you could feel the air on you hand the the car idled at 300rpm
dundunskeert is offline   Reply With Quote
Old 08-05-2011, 12:48 PM   #344
Clark Turner
Member#: 178047
02 WRX STI Spec C
Not good.
This is the one thing that a pressure test wont find. The reason is the pressure pushes the BOV closed. The only way to test the BOV from leaking under vac, is to test like you did.
C
Clark Turner is offline   Reply With Quote
Old 08-18-2011, 08:40 AM   #345
05 scooby roo
Member#: 291317
2005 Legacy GT LTD
ok so being I am new to subaru's and this is my first turbo car, after you install a GFB 50/50 hybrid bpv, do you have to re-tune your whole system or can you leave it alone? I bought the car with a catless uppipe and the rest is stock.
05 scooby roo is offline   Reply With Quote
Old 08-21-2011, 07:45 PM   #346
raggedoutsti
Member#: 255714
2005 STi
psm
i currently have on old school hks ssq valve and im worried its not venting fast enough, i have two meth nozzles installed in my charge pipe, and while i was getting it tuned my tuner said the methline would pop off under boost, he wasnt sure if it was due to bad meth line push clamps or the bov not venting fast enough. this topic wasnt really covered. my concern is that it was working before, since then i installed a 20g, used to have a 18g. and eversince this problem has been occuring. is there anything besides a bad valve that could cause this. id hate to fork over the cash for another valve and still have the same problem. if i do buy another valve i have a turbo xs type h valve in line to be purchased. i just want to be sure this is the right move.
raggedoutsti is offline   Reply With Quote
Old 08-28-2011, 01:38 AM   #347
TheZulu
Member#: 292720
07 Impreza WRX
UGM soon to be CGM
I would like to setup a Re-circulatory valve.
noob question, but what does it mean to "Run Rich"? sorry, just wondering.
TheZulu is offline   Reply With Quote
Old 09-01-2011, 10:00 PM   #348
05aru
Member#: 293207
2005 STI
Good info to know.I don't want to be challenged at every light and I'm running stock turbo so no performance gain means I don't need it.
05aru is offline   Reply With Quote
Old 09-01-2011, 10:03 PM   #349
05aru
Member#: 293207
2005 STI
Running rich means you're burning too much fuel in the fuel/air mix
Old 09-01-2011, 10:29 PM   #350
Abadu16
Member#: 291747
2003 WRX
Default Making Bov go off sooner.
Hey guys, I was wondering if any of you knew how I could make my BOV go off sooner I'm pretty new to this stuff but I'm sure there is some way I could get it to go off at less than 5 grand.This might have already been answered but I haven't seen it and I got tired of looking.
-Thanks
Abadu16 is offline   Reply With Quote
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 59 08-18-2015 03:36 PM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
