Old 09-01-2011, 11:00 PM   #351
SubieUUAREX
Member#: 269191
2011 Impreza WRX
Originally Posted by Abadu16
Hey guys, I was wondering if any of you knew how I could make my BOV go off sooner I'm pretty new to this stuff but I'm sure there is some way I could get it to go off at less than 5 grand.This might have already been answered but I haven't seen it and I got tired of looking.
-Thanks
Buy a new BPV and change the spring. You can't modify the stock one from what I understand. Even then your car might die. I could be wrong thou.
SubieUUAREX is offline   Reply With Quote
Old 09-01-2011, 11:17 PM   #352
jeremy1992
Member#: 258312
02 wrx
psm
just got on my type h and when i get into boost it makes an god awful, loud whining noise, almost sounds like a supercharger :/, whats goin on
jeremy1992 is offline   Reply With Quote
Old 09-06-2011, 11:51 PM   #353
wrsex02
Member#: 293681
great write up!
wrsex02 is offline   Reply With Quote
Old 09-07-2011, 03:27 PM   #354
Jondoe1980
Member#: 291697
2013 WRX STI Limited
Ice Silver Metallic
Angry
I have a feeling that I need to take the HKS blow-off valve off that the previous owner installed.
Jondoe1980 is offline   Reply With Quote
Old 09-17-2011, 03:49 PM   #355
L37
Member#: 294655
2011 WRX 5 door
Default Noob here..
I am new with Subaru's...just got my '11 WRX. Before I ask any questions related to installing BOV's, I was wondering what does Subaru have in a stock WRX to deal with compressor surge (if anything)? I heard they have some sort of recirculating system, but I wanted to check.
Thanks
L37 is offline   Reply With Quote
Old 09-18-2011, 03:26 PM   #356
slamdspec
Member#: 267863
1998 Outback
My 02 had a greddy bov on it when I bought it. It ran like crap but I spent some time tuning it and now it runs great with out any problems.
slamdspec is offline   Reply With Quote
Old 09-19-2011, 03:13 PM   #357
SubieUUAREX
Member#: 269191
2011 Impreza WRX
Thanks
Its called a By Pass Valve. Leave you Rex the way it is. Unless your pushing 350+ WHP with 20+ PSI of Boost then the stock unit will be just fine. You'll kill your car before you ever really had it going to a BOV being stock!
Old 09-19-2011, 08:13 PM   #358
Subieeeeeeee
Member#: 294820
2002 Bugeyeeeeeeeeee
WRB <3
love my turboxs rfl
anyway great post. really straightened out some stuff.
Subieeeeeeee is offline   Reply With Quote
Old 09-22-2011, 03:10 AM   #359
dking240sx
Member#: 290425
2004 WAGON/SRT4 NEON
hey guys just got my subbie and i guess who had it left the oem bov open so it swhosshes out and the block the recuircutlatory hose up with a battery???? is that ok or should i get that fixed??
dking240sx is offline   Reply With Quote
Old 09-23-2011, 03:14 AM   #360
mrandmrslaw
Member#: 295305
2008 STI
BLACK
Hi everyone ,
It seems i have to start it from some where , i just bought the STI 2008 and i installed HKS III BOV , Here what i got : It didnt surge any noise when i shifting 1st gear to 2nd gear. it didn't surge on any lower RPM below 3000. It does surge on high rpm.
Did i install it properly ? , I put TurboXS blanking hose , tighten vacum lines.
Is this suppose the BOV running ?
As i remember long time ago , A wrx like surging bov on lower RPM when it change the gears.
mrandmrslaw is offline   Reply With Quote
Old 09-23-2011, 03:47 AM   #361
dking240sx
Member#: 290425
will an aftermarket bov give u a rough idle?
Old 09-23-2011, 07:25 AM   #362
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
How much power you're making has absolutely nothing to do with anything. And a properly working valve won't "kill" anything.
Originally Posted by Subieeeeeeee View Post
love my turboxs rfl
RFLs are highly leak prone.
Stalling or unstable idling, it can.
Byzantium is offline   Reply With Quote
Old 09-27-2011, 06:10 PM   #363
rex1502
Member#: 295847
Default BoV
If you inner Rice boy soul need to here the sound of a atmoshere BoV, CoBB sells a 50% Recirculating 50% Atmosphere BoV it recirculates just enugh for the Mass air Flow sensor and 50 for just a nice whoosh. Hope this helps
rex1502 is offline   Reply With Quote
Old 09-28-2011, 07:19 AM   #364
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
[quote=Byzantium;35187375]RFLs are highly leak prone.
quote]
I often times wonder who comes up with this stuff? I was at IAG Performance and they told me this too, with little to no proof.
Leak? How? Like leak around the gasket? Around the intercooler flange? Or around the piston? If the spring pressure is adjusted for your car to keep it shut during idle and high boost, How does an RFL leak? Lets see a video or pictures before misleading members. Thank you.
MY EJ20TTTTTT is offline   Reply With Quote
Old 09-28-2011, 01:58 PM   #365
hi-revs
Member#: 233229
2007 sti
wrb
Wondering if a BOV should be venting/blowing off when revving in neutral, or JUST under boost?
Thanks.
hi-revs is offline   Reply With Quote
Old 09-28-2011, 02:16 PM   #366
BHutch
Member#: 220434
04 WRX
When you rev in neutral it still creates boost. The only difference is your car is not under load like being in gear. So yes if you rev it high enough it will vent.
Thanks.
BHutch is online now   Reply With Quote
Old 09-28-2011, 11:24 PM   #367
scooby_st
Member#: 268496
2005 wrx sedan
stage 2 pro tune
fwiw i installed a turbo xs rfl bov it works great no leaking or idle issues. Also im fully catless and the "backfires" are far and few between. When i was getting my car tuned my ots map was acually running a tad lean...go figure?
scooby_st is offline   Reply With Quote
Old 10-06-2011, 05:51 PM   #368
dking240sx
Member#: 290425
i just installed a aps 50/50 bov...im ok with it i didnt see or hear a difference!! any one have one of these
Old 10-07-2011, 12:23 AM   #369
jesseber
Member#: 293509
2004 WRX STI
I have a GFB deceptor on my 05 stage 2 STI and I have it set to full volume because I love the sound. I recently heard that venting all of the air out like that can cause turbo lag between shifts under heavy boosting. Is this true?
Thanks
jesseber is offline   Reply With Quote
Old 10-07-2011, 12:43 AM   #370
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Set it to full recirc, drive it for a few days, decide for yourself.
I don't think it affects spool/lag one way or another but the rich stumble was a big enough annoyance that I went back to BPV.
Old 10-09-2011, 07:23 PM   #371
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
if you haven't noticed a difference in the sound between the stock bpv and an APS 50/50, you either have it setup with the block off plate, or something isn't working right...the two valves sound completely different in terms of actual volume...
amalgrover is offline   Reply With Quote
Old 10-10-2011, 12:05 PM   #372
MartinDrummer
Member#: 297332
2011 Impreza WRX
satin white pearl
Ok so I read all your post and I thought it was very good, thanks! But here's the thing.. I just bought a 2011 WRX and Im not really interested in increasing boost or doing a lot of things to the car... Maybe full exhaust, bov, intake and some basic/cosmetic changes.. I'm not interested at all in chips or computers or nitro or any of that.. I want my car to feel GOOD and SAFE and also its my everyday car and I drive around 30 to 35 miles per day.. So here's is my question to you Davenow:
I want to add a BOV because I enjoy the sound, I dont really care about getting any attention or w.e. I could care less about people seeing my car lol But the thing is that I want a GOOD quality BOV and that wont mess my engine since is very new and I'm thinking about doing more than 3 o 4 things to it.... So what do you think about the:
Subaru Recirc Blow Off Valve
Price:
Part #: $299.99
PSP-INT-610
This one is for 2011+ WRX which is perfect for me since I have a 2011.... So what do you think about this BOV is it any good? will it damage my engine or w.e. ? Thanks again for the post and for responding(hopefully lol)
MartinDrummer is offline   Reply With Quote
Old 10-10-2011, 12:48 PM   #373
amalgrover
Member#: 183480
2009 Forester XT
if google served me correctly, that is the perrin recirc blow off valve which is actually just a bypass valve like the stock one is. so getting this will do nothing for the sound really. i've heard that the perrin increases the sound slightly, but honestly, it is going to be a waste of money for the setup you have. the tial valves are definitely quality VTA blowoff valves, and although some tuners have had issues with them, most the sequential valves on the market are pretty decent. basically, BOV's aren't as bad as everyone in the subaru community make them out to be, and as long as the valve isn't leaking and is adjusted and installed properly, it shouldn't give you any trouble really. just in case you were wondering, i run the HKS SSQV-I and i have ZERO issues with it...no stalling when coming to a stop, no surging at idle, no overly rich conditions, and my subaru didn't spontaneously combust when i installed it...go figure ...been running it for a little over 50,000miles now (30,000miles on my stock motor and a little over 20,000 miles on the built motor)
Old 10-11-2011, 12:59 AM   #374
MartinDrummer
Member#: 297332
2011 Impreza WRX
satin white pearl
Well that is really helpfull and shocking lol I was honestly ABOUT to be the Perrin BOV before I saw your respond, thanks man really apriciated!! im gonna look into the HKS bov and look for a shop were they can set it up correctly and not do anything wrong... Any other tips available? Thanks again for responding !
Old 10-11-2011, 01:55 AM   #375
KingKoopa
Member#: 189066
2015 wrx
white
boost leak, check everywhere from compressor outlet to throttle body.
KingKoopa is offline   Reply With Quote
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 59 08-18-2015 03:36 PM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
