Old 03-01-2012, 08:02 PM   #426
iainmsti
Member#: 310133
1996 WRX STI V3
Really helpful thanks
iainmsti is offline   Reply With Quote
Old 03-01-2012, 11:50 PM   #427
04rallysti
Member#: 310946
2004 sti
Nice write up!
04rallysti is offline   Reply With Quote
Old 03-03-2012, 12:51 AM   #428
dannyngnX
Member#: 303207
2012 Wrx
Pearl freakin white
good stuff... learned alot
dannyngnX is offline   Reply With Quote
Old 03-04-2012, 11:08 PM   #429
ScoobyDoobyBlue
Member#: 312503
Subaru Stars thanks!
Thanks for this! Really informative and its nice to know the truth about BOV's.
ScoobyDoobyBlue is offline   Reply With Quote
Old 03-07-2012, 08:28 AM   #430
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I thought this real world scenario was relevant
http://forums.nasioc.com/forums/show...post&t=2316513
Old 03-09-2012, 07:11 AM   #431
561wrx
Member#: 166427
03 wrx
damn. i didnt know i thought the engine ran lean, because as i put on my intake it was building a lot of back pressure and it started making poping sounds.
561wrx is offline   Reply With Quote
Old 03-09-2012, 11:44 AM   #432
subman11
Member#: 312995
2011 wrx
obsidean black
omg! how do i post a thread to sell my car
subman11 is offline   Reply With Quote
Old 03-13-2012, 11:43 AM   #433
rally_boss04
Member#: 313411
2002 Impreza WRX
wow this thread has answered questions I have had for a while
rally_boss04 is offline   Reply With Quote
Old 03-13-2012, 08:37 PM   #434
cskoglund2
Member#: 313471
I had a bov for about 2 years never leaked but had friends almost ruin their cars
cskoglund2 is offline   Reply With Quote
Old 03-15-2012, 02:38 PM   #435
MeNUrMom
Member#: 313100
2012 WRX Limited
Dark Gray Metallic
Nice Read.
MeNUrMom is offline   Reply With Quote
Old 03-25-2012, 06:36 AM   #436
HawkEyeDelight
Member#: 312052
Ok so I don't want to be another making a thread about my POS BOV so I figure I'll go straight to the Guru, I have a turbo xs BOV on my 06 WRX and occasionally my car will die when I coast. I pulled the valve off and it had 2 washers in it already and seeing as i didnt have any washers laying around i threw in 2 quarters and the problem continues. I dont get any compressor surge at any boost level and im thinking/hoping that i just need to throw in some more spacers and the problem will go away... any suggestions?
HawkEyeDelight is offline   Reply With Quote
Old 03-26-2012, 11:15 AM   #437
SubaruWrxNewb
Member#: 236017
Remove it and put the stock BPV on. That's the easiest solution.
SubaruWrxNewb is offline   Reply With Quote
Old 03-26-2012, 11:59 AM   #438
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
i would try spacing it out some more, but if that doesn't work, you will need to get a different valve. turboxs valves are fairly notorious for leaking and causing idle/clutch-in issues so...
amalgrover is offline   Reply With Quote
Old 03-29-2012, 12:09 AM   #439
HawkEyeDelight
Member#: 312052
thanks guys i appreciate the help, i wish i had the money to buy a stock valve but thats just not an option right now. one more question though, if i just continue spacing until i get compressor surge and then back off till it stops surging, have i fixed my problem or could it still be leaking?
basically im just trying to fix my issue with out spending an money ha...
Old 03-29-2012, 11:43 AM   #440
amalgrover
Member#: 183480
2009 Forester XT
it may or may not still be leaking...kinda hard to say. those valves are just known for having some unfixable leaks sometimes. not all of them do, but alot of people have had issues that no matter what they did it wouldn't go away. i will say though, it is ALOT less likely to be leaking if it is properly adjusted. even if it is a hair towards the over-tight side, it is better than being a hair towards the under-tight side. basically, if the valve opens at 1psi instead of 1inhg, you aren't going to hurt anything. crawford performance has stated multiple times that they remove the valve completely and just cap it off on most builds they do, whether street or race. so having your valve sitting just a hair too tight isn't going to hurt anything at all.
Old 03-29-2012, 11:43 PM   #441
kyle91
Member#: 287383
2008 WRX
Grey
do i need to buy a flange kit for my 2008 wrx? im buying the ssqv bov need help..
kyle91 is offline   Reply With Quote
Old 03-30-2012, 12:55 AM   #442
Lil_Hayne
Member#: 314840
2002 Impreza WRX
Thanks for the great FAQ.
Lil_Hayne is offline   Reply With Quote
Old 04-01-2012, 12:02 AM   #443
03boostin
Member#: 314109
very helpful, thank you
03boostin is offline   Reply With Quote
Old 04-02-2012, 01:39 AM   #444
HawkEyeDelight
Member#: 312052
Ok so this is my first turbo'd car so I am new to this but I guess I have a Turbo xs BPV or a 50/50? I deffinatly hear the whoosh of a bov but there is a large hose coming off the bottom of the valve Im guessing thats going to the intake like a BPV. Should I be having these issues with a BPV or could something else be the problem?
Old 04-02-2012, 03:50 AM   #445
amalgrover
Member#: 183480
2009 Forester XT
if it is a 50/50 valve, then it still would need to be adjusted/installed properly to not have issues. if it is a BPV and not a 50/50 bov, then you shouldn't have any adjusting to do or anything, and you shouldn't be having issues with it at idle.
Old 04-02-2012, 09:07 AM   #446
Vsquared
Member#: 315435
Blitz bov vent to atmosphere for almost a year. A little surge but running perfect! Great FAQ!
Vsquared is offline   Reply With Quote
Old 04-02-2012, 09:18 AM   #447
Vsquared
Member#: 315435
Old 04-02-2012, 10:14 AM   #448
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Video of the GFB Hybrid BOV on my car:
I took it easy on the shifting, so you could hopefully hear the valve better. I also did plenty of partial boost shifts so you could hear that it doesn't flutter (like I've had problems with). Unfortunately I had the driver's window up (and the other 3 cracked), so you can't really hear it as well as you could if they all were open. We'll see if I get tired of it or not. Right now I really like it. It seems very responsive, and really isn't all that loud.
xluben is offline   Reply With Quote
Old 04-03-2012, 05:31 PM   #449
HawkEyeDelight
Member#: 312052
Yeah so will I hear compressor surge still with a 50/50? I must have a 50/50 since Im hearing the woosh at higher boost levels I guess? Sorry for all the questions just new to all this ha.
Old 04-03-2012, 05:40 PM   #450
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Look at it with your eyes. It should be very obvious if you have a 50/50 valve or not.
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 59 08-18-2015 03:36 PM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
