Old 05-22-2014, 11:17 PM   #676
Modzilla
Member#: 388006
I'm running the GFB hybrid on my '13 wrx with a process west tmic, holds boost great as would the stock unit, around 22psi. I like the sound of the partial atmospheric dump under medium load, reminds me of my 04' sti's fully atmospheric bov. Can't hear anything under heavy load due to my ewg. Had a Forge recirc and I could hear it recirculating under light load which the GFB doesn't do which I like better, less sounds under light driving.
Modzilla is offline   Reply With Quote
Old 06-19-2014, 01:54 PM   #677
drumdude1978
Member#: 393933
2015 Subaru STi
Thanks for the tips.. Very helpful
drumdude1978 is offline   Reply With Quote
Old 06-25-2014, 07:08 PM   #678
Jakvortex
Member#: 394605
1998 Impreza WRX
Silver, gold rims
Thanks for the info man!
Jakvortex is offline   Reply With Quote
Old 06-29-2014, 02:21 AM   #679
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
Originally Posted by Davenow View Post
I made FAQs long before him.
And his FAQs are so out of date, its not even funny. Unfortunately he is just too busy to keep them updated, and as new things are discovered, and things change over the years, they become less and less useful. The other problem is that his FAQs are based on a compliation of posts on nasioc, AND his own knowledge. The unfortunate reality is that much of the stuff in his FAQs, is based on things that were never correct to begin with, because a lot of the threads the info came from, were wrong to begin with.
If his FAQs were working, there wouldnt be nearly the problems that there are. The problem is that his FAQs dont get straight to the point, and dump out a bunch of tech info that many people just dont understand or take the time to bother reading. This FAQ was made for ONE purpose. To get straight to the point, and try to squash some of the myths.
Not to mention that I know more about it the things I write FAQs on. 20 years automotive experience teaches you a few things
I've heard from a subaru tech that the ecu will learn that the car is running rich and then take fuel away at the wrong times causing a lean mixture. Any truth to what he said or was he wrong?
patrickrobare is offline   Reply With Quote
Old 07-17-2014, 11:34 PM   #680
Chrissarg425
Member#: 389002
2002 Wrx
Red
Let's hope with people reading this they'll be less posts titled "should I get a BOV? I like the sound"
Chrissarg425 is offline   Reply With Quote
Old 07-19-2014, 03:15 PM   #681
sukwoo21c
Member#: 352452
FYI Greddy Type-s BOV flange for 08+ wrx is hard to find these days
sukwoo21c is offline   Reply With Quote
Old 07-19-2014, 03:33 PM   #682
Rogue_P
Member#: 371737
2003 **** Your
Fake Parts
Save yourself the headache. Just buy TiAL. :]
Rogue_P is offline   Reply With Quote
Old 07-27-2014, 10:35 PM   #683
bpaverill
Member#: 397010
2014 Impreza WRX
Dark Grey Metallic
Default loudness
How much louder is an aftermarket BPV vs. Stock BPV? I am running 22psi and I am looking into aftermarket BPVs so I can be safe with more power gains. Are there any aftermarket BPVs that are as loud or around the same loudness as stock?
bpaverill is offline   Reply With Quote
Old 07-30-2014, 11:26 AM   #684
wrxnh
Member#: 393998
/// WRx ///
Pretty loud; assuming the WRX that's parked not too far from my work drives by all the time and can hear it from a good block away (but without buildings in between).
Grrrrrwwrrrrr PSSSSHSHSHSSHSHSSSWAAAAA.
wrxnh is offline   Reply With Quote
Old 07-31-2014, 02:31 AM   #685
Cton93
Member#: 393112
Default Leaky BOV
Yeah my Tial 50mm has had issues with leaking. So I bough a HKS SSQV 4, is there an adapter/flange that can go tial to hks?
Cton93 is offline   Reply With Quote
Old 07-31-2014, 04:30 PM   #686
chuckmccoy
Member#: 361872
2013 WRX Limited
Crystal Black Silica
my gfb bov has no leaks it is awesome!!
chuckmccoy is offline   Reply With Quote
Old 08-01-2014, 12:17 PM   #687
scoobysquad1
Member#: 397866
random and off the note will a wrx intercooler and piping fit on a ej22t
scoobysquad1 is offline   Reply With Quote
Old 08-05-2014, 02:28 PM   #688
Kyle.wallace33
Member#: 398226
2009 Wrx
Finally a decent list to go by! Hopefully this helps everyone
Kyle.wallace33 is offline   Reply With Quote
Old 08-09-2014, 08:52 PM   #689
Aaronfox147
Member#: 398539
1999 Subaru Impreza
tan
thanks loads
Aaronfox147 is offline   Reply With Quote
Old 08-09-2014, 09:12 PM   #690
BB2006LGT
Member#: 367150
Anyone have a Turbosmart kompact? Mine is like 2 months old and already leaking. I talked to turbosmart and they just keep trying to avoid warranting it. They suggested I rebuild it and told me I need the O ring kit. Why would I buy a O ring kit for a 3 month old BOV?
BB2006LGT is offline   Reply With Quote
Old 08-20-2014, 11:31 PM   #691
Blakewrxlimited
Member#: 399559
Good to know
Blakewrxlimited is offline   Reply With Quote
Old 08-30-2014, 11:54 AM   #692
ShaneRichards01
Member#: 400335
whats the best brand of bov's?
ShaneRichards01 is offline   Reply With Quote
Old 09-05-2014, 02:39 PM   #693
SCwrx85
Member#: 340328
04 WRX
Seriously? Read the first freaking post he outlines which valves have been known to leak and which ones don't.
SCwrx85 is offline   Reply With Quote
Old 09-08-2014, 04:53 AM   #694
BobbyDUBRX13
Member#: 378890
So I'm curious about some things when performing a leak test.. it seems alot of people say valves leak especially the venting bias ones.. when really I've done a little research and found that they tend to leak because people testing them are pressuring the plumb back tube as well which if I'm not mistaken is always under vacuum so if this is so wouldn't the correct way to smoke test a bov would be to disconnect the plumb back and plug it off?
Sent from my SM-N900V using NASIOC mobile app
BobbyDUBRX13 is offline   Reply With Quote
Old 09-08-2014, 06:37 AM   #695
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
by "plumb back" do you mean the manifold reference?
If so, the assumption that that point is always under vacuum is wrong.
Sent from my SCH-I545 using NASIOC mobile app
Old 09-08-2014, 06:47 AM   #696
BobbyDUBRX13
Member#: 378890
I mean the tube that recirculates the air back to the manifold.. I got this info from a video that GFB posted about smoke testing bov's and the correct way to do it on YouTube so I'm trying to figure out basically if GFB is doing that and showing that for marketing or if tuning shops are doing it wrong I really don't know who's right that's what I'm trying to learn
Old 09-08-2014, 10:41 AM   #697
BB2006LGT
Member#: 367150
I personally pressurize my intercooler pipe coming off the turbo, so no , the recirc hose is not pressurized, but the intercooler/intake manifold and vac lines all are
Old 09-09-2014, 04:34 PM   #698
Springs
Member#: 401180
Default 2005 Subaru legacy touring wagon
Hey I'm on the verge of importing a 2005 Subaru legacy touring wagon right hand drive to the US. Can someone tell me the steps in doing so and if it's a legal car to import? I live in Brooklyn Ny
Springs is offline   Reply With Quote
Old 09-09-2014, 09:13 PM   #699
BB2006LGT
Member#: 367150
How is that related to BOV's?
Old 09-10-2014, 11:39 AM   #700
Next_Gen
Member#: 304811
2006 WRX
RED
I am running a stage 1 cobb tune 2006 WRX...I want to put a BOV on my car but I don't have one right now. Is there a BOV that will be similar to stock or any suggestions for a BOV that will go well with a stage 1?
Next_Gen is offline   Reply With Quote
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 59 08-18-2015 03:36 PM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
