Old 12-03-2009, 09:30 PM   #126
Organic_MK
Member#: 190464
1998 ej205 coupe
obp
bovs make my subie unhappy.
this is reason enough not to run one.
Organic_MK is offline   Reply With Quote
Old 12-03-2009, 10:41 PM   #127
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Originally Posted by Defiant Autospeed View Post
3 stickies in the newbie forum and they still wont make me a mod here
You know why? I'll tell you why- It's because you haven't sent me any free crap yet
Audiosavvy is offline   Reply With Quote
Old 12-05-2009, 11:40 AM   #128
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
BTW just to make it clear, this isnt a "everyone go buy a bov!" thing. Im not saying everyone should have one, its a personal choice. Im just saying, if you dont want to run one, make sure you dont want to run it for the right reasons.
Defiant Autospeed is offline   Reply With Quote
Old 12-05-2009, 02:10 PM   #129
Penguin_02
Member#: 180460
02 WRX
really good info in here. where it said it was bad for cats. i thought it was bad for felines.
Penguin_02 is offline   Reply With Quote
Old 12-05-2009, 03:19 PM   #130
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I mean its not particularly great for them, but its no worse than running an overly rich off the shelf map, which MANY of them are.
Actually its not as bad for them as an overly rich map. An overly rich map will be rich constantly. A bov has tiny rich spots only on vent.
Old 12-15-2009, 10:03 AM   #131
tomofo
Member#: 230978
2002 VF43 Stg III
Nice write up and discussion Dave.
tomofo is offline   Reply With Quote
Old 12-15-2009, 10:31 AM   #132
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
I blame all my life problems on my BOV. It makes a good scapegoat for everything.
Dirty25RS is offline   Reply With Quote
Old 12-15-2009, 02:37 PM   #133
Davenow
Member#: 23676
I just got a paper cut.
$&^#@ BOV. Had I gone with a recirc this would never have happened.
Old 12-15-2009, 03:31 PM   #134
lowrider89
Member#: 143022
2005 modded S4
this is interesting.... supposidly it is only rich for a BRIEF moment.... yet some people's car run terrible with BOV's and others claim there car runs fine...
lowrider89 is offline   Reply With Quote
Old 12-15-2009, 03:50 PM   #135
marchetta070
Member#: 183705
2010 S4
NICE POST! I will laugh everytime I read BOV posts. I will just send them here. I feel like more posts need to be simple and to the point. Some of unabombers posts should be made into some simplified versions. not hating on his at all I just think more people would read them if they were a bit shorter and to the point
marchetta070 is offline   Reply With Quote
Old 12-15-2009, 09:24 PM   #136
steeze
Member#: 214394
03 Wrx
Psm
Thanks to this post, I've mad my decision on BOVs. +1
steeze is offline   Reply With Quote
Old 12-15-2009, 11:58 PM   #137
sleserginekolog
Member#: 231958
interesting... i come from ms3, and it's a different story. 1. you can't run VTA (unless you are modded to the teeth) 2. I had RKM SSQ valve, that i found to be very effective. 3. Forge (ninja sword), was a nice bpv. It did the same exact function as a stock one, but just made a ninja sword sound (kind of like a bov sound).
aftermarket bpv's made a difference in ms3's. ms3's would loose power after 5500rpm, if you had a CAI and DP (which made the car run a little higher boost and push more power in general), on a good bpv the car would hold boost for a lot longer. i did an experiment, stock bpv vs rkm. at 6000rpm on stocker my boost dropped to 5psi. with rkm it would drop only to 10-12psi. test was done the same day, 30 minutes in between. Aftermarket BPV did not add any power, but it helped to hold stock power a lot better....
So you are saying it's not the case with STI's?
sleserginekolog is offline   Reply With Quote
Old 12-16-2009, 09:45 AM   #138
Dirty25RS
Member#: 56731
STI's hold their stock boost levels to redline (maybe 2 psi drop) which would put you at 12psi like u were saying. At least that's my experience. 5 psig sounds horrible.
Old 12-17-2009, 09:27 AM   #139
stlscoobydoo
Member#: 221261
2004 sti
wrb
awesome write up man
stlscoobydoo is offline   Reply With Quote
Old 12-17-2009, 12:06 PM   #140
seekndestroy19
Member#: 209358
06 Sti
Originally Posted by Davenow View Post
Ricer is a state of mind. You can have an F50 and still be a ricer if you do ricey crap to it and behave in a ricer kind of way.
BOVs make you a ricer just like owning an SRT-4 makes you a retard.
Its not that the valve or car are ACTUALLY linked to being a ricer or a retard. Its just that the majority of people WITH them, are ricers and retards. So it gets a whole bad stigma. Plus ricers, the first word out of their mouth when they think of a turbo car is "bov"
I just lol'd in the middle of class. excellent write up though. short and to the point. the only thing i didnt see you mention is "will getting a tune after BOV install help the car run better with it or it doesnt matter?" i could only assume that it will but would like your opinion
seekndestroy19 is offline   Reply With Quote
Old 12-17-2009, 08:07 PM   #141
RayN
Member#: 135789
2005 STi
CGM
i think people get confused with the term tuning in regards to a BOV. you CAN NOT tune for a blow off valve.. there is 2 things that may be related in sorts which can be thought of as tuning. 1 being that you have to adjust your BOV so that it works properly, maybe during a tune when boost is raised, you have to adjust it for added pressure.. 2 going with a blow thru maf setup, you would get your maf rescaled for the different location its in which in point lets you run a VTA blow off valve with out the negitive side effects. if you think of it this way. when a BOV vents, its when the motor is on its way back to an idle state. the maf is looking for air being recirc'd back into the intake which its not seeing. hence the lil spike in AFR. for anything to be possibly tuned for a VTA blow off valve would be like tuning the car at idle. hence why it cant be done with just a normal setup.
RayN is offline   Reply With Quote
Old 12-17-2009, 09:01 PM   #142
Clark Turner
Member#: 178047
02 WRX STI Spec C
Huh?
My maps have a totaly different MAF table for BOV and recirc valves for a reason.
Clark Turner is offline   Reply With Quote
Old 12-17-2009, 10:55 PM   #143
RedefinedTR
Member#: 149848
2011 Honda CRZ
Performance White Pearl
This is very very good info!
RedefinedTR is offline   Reply With Quote
Old 12-20-2009, 02:12 PM   #144
dalhedian
Member#: 186513
nice....
dalhedian is offline   Reply With Quote
Old 12-20-2009, 09:34 PM   #145
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
This is a sticky now? Hot damn, this might save a few unnecessary new threads if you know what I mean.
Smoke is offline   Reply With Quote
Old 12-21-2009, 09:26 AM   #146
not2fast
Member#: 230574
2015 MB C300
This thread is very good...
Its funny how a psshshhshshs sound can sound so sexy on a your car, and so annoying on a garbage truck.
It seems that no BOV is just less headache. If its one less place for possible leaks, I am all for not having it.
If there was any gain, I would be saying something else.
not2fast is offline   Reply With Quote
Old 12-24-2009, 04:31 PM   #147
Dragonfueled
Member#: 224941
09 Wrx
Rally blue
So is it true that the 09' s bov is weak? i'm stage 2 And about to do injectors a better top mount and a Bcs. I'm now wondering if I should invest in a Perrin recirc valve and be done with it. It should be around 19 or 20 psi when done. I'll take the abuse for being a subby nube but that's how we learn. 09 wrx TBE catted with aem intake and protuned.
Dragonfueled is offline   Reply With Quote
Old 12-24-2009, 05:07 PM   #148
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Yes, I would definitely recommend an aftermarket BPV.
Old 12-26-2009, 12:56 PM   #149
Davenow
Member#: 23676
Yeah the 08-09 plastic valve (also the plastic valves that came on the LGT years before that) are garbage, and typically leak anywhere above stock boost. On a "stage 2" car, imo, a replacement valve is an absolute must. If you dont want the noise or somehow are still not understanding the entire concept about a valve not making you "run rich", there are many 100% recirculating options on the market
Old 12-27-2009, 01:00 AM   #150
Dragonfueled
Member#: 224941
09 Wrx
Rally blue
Are there any recirc valves that are like stock only don't leak? I don't want something with a 100 adjustments. Or can I just get a Perrin recirc and not touch it. Sorry for questions but I'm about to use perrins sale for a top mount ebcs and bpv to add to my stage 2. Just wanna get all the info I can before I pull the trigger and regret it.
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 59 08-18-2015 03:36 PM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
