Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-27-2010, 11:30 AM   #51
Snowmadic
Member#: 215871
Default Seized Axle/Hub BS
Very detailed thread, thanks to everyone for the info.
I'm replacing the front drive shafts on my 03 WRX wagon and am having trouble with my passenger side axle. It seems to be seized to the hub and will not budge. The driver's side axle came out with a little persuasion from an axle puller, but the passenger side axle has broken/bent 2 pullers and survived repeated assault from a 6pd sledge. At this point I'm ready to take the entire hub off the vehicle and get someone with a hydraulic press to press the axle out of the hub.
Has anyone else encountered a problem like this? Any suggestions?
Thanks, and Stay Awesome!
Snowmadic is offline   Reply With Quote
Old 09-27-2010, 12:34 PM   #52
vwbugpilot
Member#: 254120
2004 sti
black
air chisel with a punch bit in the middle of the axle will drive it out
vwbugpilot is offline   Reply With Quote
Old 03-19-2011, 01:00 PM   #53
tungsten
Member#: 109573
2005 STI
Originally Posted by scoobdude View Post
i would recomend if you do not have to, do NOT undo the carrier bearing adjuster. It not only adjust backlash but also pinion depth. If the gears start riding in a different place bad things will happen. And iff backlash is not set to .00051 to .00071 (on 04 wrx) you will have clunks and whines and all other sorts of poo.
For the people who have stubless, if i remember correctly i think you can pull them out directly without removing that part. Its been awhile (last clutch change a few years ago) since i did this. However i will be getting the seals in this weekend and tackling it on the fresh trans. Sad part is last time i was able to get the part off an older impreza model at the parts store. But no more . Seems like part is dealer item only.
I found both fronts for my 04 for $7.xx for the pair from flat iron tuning. I am doing the rear as well which were $12.xx for the pair but the rear diff is off a 07 FXT (just replaced 1-2 with LGT, upgraded to dual cone 1st syncro, ring and pinion, center diff and rear diff to put 4.444s in)
What is "stubless" and how do I know if I have stubless? I have a 2005 STI, no spring pins holding in my front axles. My drivers side seal is leaking and after being on the highway any residual on the exhaust stinks. I want to fix this but I would rather not mess with backlash. BTW the dealer wants 3hrs and 360$ plus parts. On top of that I am doubtful they check backlash.
tungsten is offline   Reply With Quote
Old 04-25-2011, 09:27 PM   #54
rex2002
Member#: 236494
2002 wrx
black
has anyone else beside the tread creator done this project. so far ive chipped two teeth when trying to take off the outer seal.any special tools that i can buy??
thanks
rex2002 is offline   Reply With Quote
Old 04-25-2011, 09:32 PM   #55
full of dents
Member#: 181717
12 sti hatch
w r b
i have. i just used a large regular screw drive to remove the ring. i went from one to another and didnt beat on just one (not saying you did or are doing that)
you could try a spanner wrench if you can find one that fits
full of dents is offline   Reply With Quote
Old 04-25-2011, 10:06 PM   #56
AREA1320
Member#: 112508
thanks
Did you remove the lock bolted to it?
AREA1320 is offline   Reply With Quote
Old 04-26-2011, 05:24 AM   #57
rex2002
Member#: 236494
2002 wrx
black
yep sure did. i have another tranny thats off the car and i was able to get that one off with no problem.im thinking it may be the angle that im trying to take it off again.my buddy works for nissan and hes going to see if theres any special tool that we can use to take it off with.
Old 04-27-2011, 09:54 PM   #58
rex2002
Member#: 236494
2002 wrx
black
replaced the seal. everything went fine. but the leak is still there. its the input shaft seal thats leaking(which i was hoping it wasnt,b/c its a pia to replace). now we get to take the whole tranny back out again split that case and fix the leak. the perks of buying a used tranny. gotta love it
Old 05-27-2011, 09:53 PM   #59
xzchaos
Member#: 32051
Default 02 Wrx
My car recently started making noise from the passenger's side axle. Upon inspection i noticed the the boot is ripped. I need to do a lot of driving in the near future. Will i harm anything before i have a chance to look at replacement? Should i get some grease in there in the mean time? Could it damage transmission/diffs?
xzchaos is offline   Reply With Quote
Old 05-27-2011, 10:48 PM   #60
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Depends on how bad. I would say replace it as they are only about 100 bucks new from autozone and stuff. Or if you can upgrade them to the forester ones (depending on your model transmission etc)
scoobdude is offline   Reply With Quote
Old 08-06-2011, 05:07 PM   #61
EntrySpeed
Member#: 261859
2004 Impreza STI
Great write up!
Thanks for taking the time.
Just incase anyone else is looking for the info; I found this while searching around...
2004 STI axle oil seal can only be serviced when the retainer plate (sundial) has been removed. Its because of a small lip inside where the axle stub passes through. (Caused a hell of a lot of frustration till I read this! LOL)
From what I understand, 2005 STI and beyond seals can be changed while the plate is still installed, due to the lack of the lip.
EntrySpeed is offline   Reply With Quote
Old 08-28-2011, 04:26 AM   #62
code3suby
Member#: 151125
I started trying to pull the front axle with a puller and realized that there must be a lip and found this post. I removed the sun dial / retainer and when I did, another piece fell out, I believe its part of the roller bearing, and when I put it back in it wont stay. When I try to put it back in a unit, I can't screw the sun dial all the way back to its original position, anyone have any ideas?
code3suby is offline   Reply With Quote
Old 09-13-2011, 12:26 AM   #63
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
Sure maybe this thread is old, but this is an awesome write-up, pics are superb. Just blew my axle seals and I will definitely be printing this to help me out. Again, awesome write-up.
down_for_the_scooby is offline   Reply With Quote
Old 09-13-2011, 10:21 AM   #64
wtyree
Member#: 29879
2002 WRX Wagon
It is very helpful, I used it a few months ago while I was replacing my front axles. I should have bumped it then.
wtyree is offline   Reply With Quote
Old 09-14-2011, 08:01 PM   #65
down_for_the_scooby
Member#: 78314
04 PSM WRX
As an update, I was able to use one of my BC coilover wrenches to loosen the differential cap. I found I could also use a large pipe wrench as well. The "proper" subaru manual way calls for a special tool which is unavailable to the average shadetree mechanic but the coilover wrench worked fine.
Old 09-20-2011, 03:58 AM   #66
oguitar
Member#: 206720
2002 WRX Wagon
Dang I might have to do this soon.
oguitar is offline   Reply With Quote
Old 11-14-2011, 03:01 PM   #67
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
I had replaced mine already and it is still leaking. Albeit slower than before but leaking non the less. I believe it is coming from the metal retainer o-ring and not the axle seal in the middle of the retainer. Is it wise to tighten up the retainer a half a turn to stop the leak? Or will my diff assplode? This is the passenger side BTW.
Gr3en is offline   Reply With Quote
Old 03-20-2012, 10:03 AM   #68
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
I am wondering this as well? I replace both seals not too long ago and all my fluid above the seal leaked out. It's worse than before.
Can the retainer be tightened half a turn? Should I have this done again at the stealership to have some sort of a warranty on it so when it happens again i can just bring it back?
Old 06-25-2012, 08:43 PM   #69
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
I used a specialty plumbing wrench that I had from our remodeling project, was only like $10 at Lowe's back when I bought it, and it worked great:
http://www.superiortool.com/tools/sp...tool/03845.htm
This write-up was fantastic, btw.
Wade-O is offline   Reply With Quote
Old 02-18-2013, 03:06 AM   #70
Dinoboy707
Member#: 347410
Default driver axel seal
hey new to the website but i am wondering what type of driver axel seal i need for my 2000 imported sti from japan. im leaking tranny fluid can anyone please link me a website where i can order the right part?
Dinoboy707 is offline   Reply With Quote
Old 05-09-2013, 10:01 AM   #71
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
2011 post, but I'd like the opportunity to respond.
That's a bearing race. The ball bearings (or whatever type of bearings) ride inside of that race in a cage.
You're not going to be able to reassemble that. And you may have to rebuild your trans.
I am interested to see how this worked out though.
And for what it's worth, doing this yourself will get the bearing preload and lash *close* to what it was stock, so long as you do as the DIY says and count the number of times you have to unscrew it, however you ALSO need to put it back in exactly the same position, so make sure you make a mark on the case and the nut to align them properly when reinstalling. That being said, you'll be a bit off just by virtue of taking it apart, so you may blow up your front diff doing this. Just fair warning.
tooocool49723 is offline   Reply With Quote
Old 05-09-2013, 12:17 PM   #72
PSBeachBum
Member#: 279870
2005 WRX Wagon
I did the same thing and had 0 problems.
PSBeachBum is offline   Reply With Quote
Old 05-28-2013, 06:21 PM   #73
CodyS
Member#: 354203
2006 9-2x aero
Obsidian black 6spd swap
Old thread I know, but seems to have recent posts. My axle seal just started leaking every so often. My question is do you need to drain the transmission of oil before replacing the seal? Or will there be minimum spill out of the now open axle hole. Sorry if I read over the section that explained this if there was a section.
CodyS is offline   Reply With Quote
Old 05-28-2013, 06:55 PM   #74
NVsubaru
Member#: 247111
2007 Impreza 2.5i
1971 VW Fastback
As far as the adjustment being on the right side, that's the same as the passenger side, I'm assuming...
NVsubaru is offline   Reply With Quote
Old 05-28-2013, 08:06 PM   #75
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
If you can lift the front bumper 30 or so inches above the ground and leave the rear wheels on the ground, no oil will leak out once you pull the axle. It the car is setting level, oil will come out.
SOCAL: Stock 02-03 WRX Seats Blu & Blk Front and Back Great Condition!!! racerx66 Interior/Dressup/Audio & Security 12 04-13-2007 03:07 PM
STOCK 02-03 wrx wheels, wagon front sway bar, headers, intercooler, lugz fastwrx25 SCIC Private Classifieds 4 03-14-2007 07:13 PM
FS: Stock 02-03 WRX front seats w/ wet okole covers Einherjar MAIC Private Classifieds 2 02-23-2007 11:30 AM
WTB: Stock 02-03 wrx WRB front bumper ToesWRX Mid Atlantic Impreza Club -- MAIC 1 08-03-2005 02:06 PM
wtb : stock 02-03 wrx sedan front bumper atomicapples Private 'Wanted' Classifieds 0 05-19-2004 09:53 PM
