Old 09-22-2008, 06:36 PM   #1
ryan1220
Member#: 189927
Default need help
whats up i reacently purchased an 07 wrx motor and trans i want to know what years the motor will fit in without having to do too much crazy work and howgood and reliable was this motor brand new im new to subaru's
ryan1220 is offline   Reply With Quote
Old 09-23-2008, 02:43 AM   #2
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
k first always read the sticky's first cause 8 0f 10 times the answer is in there second basically all tranny engine combos like all of them can go into any model... your set up can go into an impreza, an outback, a forester, in basically any year after 1990. all this info is in the sticky
also you have to be more specific with alot of work because to get the AVCS system to work you have to rewire the whole car with the 07 harness which is a pain or you can can say scruw the AVCS system and hook it up to a a regular ECU but either way you will need a harness...
my advice read the sticky, and dummies guide to an STI swap there's alot of basic info in each then make your question more specific if you need anything you can always pm me to (personal message )
bugeye-brawler is offline   Reply With Quote
Old 09-23-2008, 02:45 AM   #3
bugeye-brawler
Member#: 182337
Sport -- White
of coarse they are reliable they are subarus thinking more it is easier to put that engine into a model that already has or had a turbo so you don't have to work about turbo cross members and such... but then again dropping it into a 1997 legacy or outback wagon would make it one hell of a sleeper
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 08:53 AM
Need help!! Need to find a +12v switched wire NOW! Please help! nxwrxfx Electrical & Lighting 16 04-25-2006 05:29 PM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
