Old 09-23-2008, 12:32 AM   #1
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Default drag racing and large turbos
Hey everyone,
I have a quick question regarding drag racing cars fitted with huge turbos. I understand what turbos do and how they work (I consider myself a noob). anyway, I have noticed at the track that a lot of the turboed strictly drag cars stage and rev up, there is a lot of noise once the turbo has spooled. poping and cracking mostly. I'm guessing it's pre-ignition, but IDK. Anyone know what causes this?
Thanks in advance,
Steve
jetfan2207 is offline   Reply With Quote
Old 09-23-2008, 12:38 AM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's anti-lag.
Basically they run it very rich with retarded timing to dump fuel into the exhaust and burn it there to spool up the turbo faster.
Old 09-23-2008, 12:44 AM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
^^ what he said
Jubert69 is offline   Reply With Quote
Old 09-23-2008, 06:41 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
They run anti lag at the launch? That seems odd......I figured it would be the launch control system holding the desired rpm.......
Old 09-24-2008, 10:20 PM   #5
vlady
Member#: 77997
dirty blue
Anti lag is part of the LC system (usually) on turbo cars. Without the retarded timing and stupid rich conditions, all it would do it hold a high RPM without providing any significant load on the turbo. Kinda of like you can go outside right now (don't do it though ) and rev your car to a high rpm and you won't build more than lets say 2-5psi of boost. Do that with anti lag, you leave the line with 20+psi (this will vary greatly, but you get the idea).
vlady is offline   Reply With Quote
Old 09-28-2008, 06:15 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Not really. You build boost by creating a load on the engine. Creating an artifically lower rev limit for launching, say 5500, then going WOT while not moving will build boost. No anti lag system is needed. The reason you can't build boost just revving an engine is there is very little load on it.
Tony
Old 09-28-2008, 06:27 PM   #7
gold rush
Member#: 90110
2004 wrx wagon
Tony
What your talking about is a 2-step rev limmiter, which helps smaller turbos get off the line, but for bigger turbos you need a launch control set-up that can seriously retard timing like anti-lag to build any boost.
gold rush is offline   Reply With Quote
Old 09-28-2008, 08:51 PM   #8
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Some 2-steps (gizzmo for instance) are ignition cut based - so work very similar to retard sysems in that excess, unignited fuel passes into the headers, and then ignites in the headers to provide very similar effects.
The LC patch used on subaru ecus cuts both fuel and ignition, so the benefit is greatly deminished, where the ignition cut systems can generate more then 10psi of boost if you rev it long enough, the LC patch (or most other fuel and ignition cut systems) usually generate less then 10psi (which is still pretty decent).
Saying that, nothing beats a retard LC system at generating as much boost (and flames) as required
wrxsti.l is offline   Reply With Quote
The Import Attack - Drag Racing and Car Show June 13th @ CFRC eschoenz Motorsports 0 05-24-2010 03:20 PM
I'm going to watch fords drag race, and watch my mullet grow MattSEG Off-Topic 20 05-17-2004 02:28 AM
Detroit Meets Japan Drag Race and Car Show after9events Motorsports 1 03-30-2004 09:13 PM
What RPM to shift at when drag racing...and how do you launch? wrexsta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 02-06-2003 11:55 PM
Three car drag race and one dead pedestrian scoobyman General Forum Archive 14 07-02-2000 03:27 PM
