Old 09-23-2008, 11:22 AM   #1
SportyMark
Member#: 167263
02 WRX Sedan
Default Stock 2.0 with a 08 STI oil pump?
Just wondering if there woudl be any improvements to installing the 11mm pump when I am in for the timing belt?
thoughts?
SportyMark is offline   Reply With Quote
Old 09-23-2008, 11:32 AM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
you probably wont benifit much from the STi pump on your 02 even though the impeller is bigger on the STi pump than wrx. If you have a FMIC, the pump may help the cooling slightly since the FMIC blocks your rad.
fastnoypi is offline   Reply With Quote
Old 09-23-2008, 12:25 PM   #3
GeneralTJI
Member#: 152680
Oil Pump.. not water pump...
There is a large thread about the larger oil pumps on here somewhere....
If you plan to spin your motor up high (large turbo / cams etc.) the larger pump can help supply more oil at the higher revs where there is some issues with the way the factory crank is drilled. The real fix is have the crank oiling passages modified.. but the larger pump does help extend the safe RPM zone a little higher. If you don't plan on spinning it up higher, it's probably a waste of money.
GeneralTJI is offline   Reply With Quote
Old 09-23-2008, 01:50 PM   #4
SportyMark
Member#: 167263
02 WRX Sedan
Well i do plan on running it harder with a larger turbo so looks liek a go.
Old 09-23-2008, 02:35 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
oops ..my bad..pwnd by reading this morning...but still dont think there will be much of a benifit, even at higher rpms because the crank isnt crossdrilled like the ej207.
The subaru oil will pump plenty of oil and should be able to supply as much oil for any turbo the OP chooses. Garrets blow out all the time due to too much oil if you dont put a restrictor on the suby.
Old 09-23-2008, 04:04 PM   #6
GeneralTJI
Member#: 152680
Tell me about it-
I have two restrictors on my t3/t4, and it's NOT ball bearing.. so I should be able to feed it a fair amount of oil without trouble, and I'm still pushing oil past the seal....
FS:CT- 04-05 Sti Head Gaksets- 2.0 Wrx Engine Gasket Kit- 04-07 Sti Oil Pump 98SubbyLeg Engine/Power/Exhaust 9 05-25-2010 04:55 PM
08 STi Oil Pump Part Numbers Element Tuning Built Motor Discussion 46 05-08-2009 04:04 PM
08 STI Oil Pump TurboDXsti Built Motor Discussion 2 04-27-2009 07:40 PM
08 STi Oil Pump Norrberrt Private 'Wanted' Classifieds 14 10-01-2008 03:52 PM
08 STi Oil Pump.. New Norrberrt Private 'Wanted' Classifieds 0 09-28-2008 04:56 PM
