#1 |
Member#: 141536
Vehicle:2006 20G'd WRX Grey |
I have been working on this car for about a year and a half, and this is where it is as of now. The dyno graph is everything on the car except for the FMIC and gears. A perrin TMIC was replaced with the front mount. All of the work has been done by me, except for the motor build and the gears.
2006 WRX TR Motor: RAW1 (formerly AXIS) stage 2 block 1/2 mil over valves factory heads FP20G 7cm-internally gated,34mm flapper DW 750cc injectors walbro 255 Okada Plasma coils Perrin TBE no cat Perrin FMIC Trans: STI RA gears ACT lw flywheel Exedy Cerametalic Clutch ![]() The car is tuned via open source at 19psi on BP 92 oct. The tune was done on the road and the car was dynoed a few months later. Would like to see over 300 hp/tq with the FMIC and the P&P exhaust manifold going on in a few days. ![]()
#2 |
Member#: 88005
Vehicle:2002 WRX PSM GS500 |
those #'s seem kinda low for a 20g at 19psi, even with 92 oct. Looks like your car already has a fmic??
#3 |
Member#: 141536
the pics are new. Yeah I was expecting a bit higher, but oh well. The car kept knocking everytime we tried to add more timing, so we kept it safe.
#4 |
Member#: 102027
SCIC
Vehicle:BugI Tsx retro lamps for sale not listed pm me |
theres def more power there. once that gets figured out... think 80 more. why the 7cm and not the 8?
#5 |
Member#: 141536
I was a effing idiot when I bought the turbo...that is why. I did not do near enough research before making the purchase. I am happy with it though. next will probably be a Grimmspeed EWG setup to draw out some more power.
#6 |
Member#: 126696
SWIC
Vehicle:2002 Fatbody bugeye 03 R1 09 Raptor 700R |
Td05?
#7 |
Member#: 141536
no it's a TD06
#8 |
Member#: 164625
Vehicle:2007 WRX Wagon 20g External Wastegate |
no offense but those arent great numbers
#9 |
Member#: 141536
none taken. And I know. There is a lot more left on the table, just gotta get it tweaked.
#10 |
Member#: 164625
what are your afr's??? I made 365 whp on a dyno jet with an external wastegate, but I doubt an external made that much of a diffrence.
#11 |
Member#: 141536
not quite sure. Just got a LC-1 so I will find out soon. I know they are not where they need to be though. runs way rich sometimes.
#12 | |
Member#: 89752
SCIC
Vehicle:08 STI SWP |
That is NOT a good idea. From the look of the graph it's possible it was running very rich since a rough looking graph like that usually indicates that the coils/plugs are having a hard time lighting off the air/fuel mixture, but if it was that rich at 19 psi you should have been able to run a fair amount of timing which should have yielded far better number than you are getting. Not to be overly blunt, but I've gotten similar, if not better numbers on stage 1 (reflash only) STi's. |
#13 |
Member#: 141536
no it was tuned on wideband, I just do not know what the afr's are.
#14 |
Member#: 89554
Vehicle:2006 EVO SE Black E85 30PSI dd |
either something is very wrong w/ your motor or your tuner has no clue what hes doing. I made over 300wtq @ 3500 w/ an 8cm 20g @ 20psi w/ low 11 a/f's.
#15 |
Member#: 141068
SCIC
yea...i mean don't get me wrong good luck with ur setup but i've got a 07 tr with a walbro 255, vf23 turbo, catless tb exhaust, ebay tmic, and intake and i put down 296.5 whp with 326 torque at 18lbs...so you can def get ALOT more outta that big turbo...but regardless gl on ur build...
#16 |
Member#: 154013
Vehicle:2012 S4 Monsoon Grey |
Im wondering if he has low compression. Lately I've been looking into building my engine and I heard nothing but horror stories from those off the shelf built blocks. 19psi on a built block is nothing. Go to a real tuner that knows what he's doing.
#17 |
Member#: 141536
I am not sure what an off the shelf built block is, but it was not preassembled when Ron got it from subaru. My factory heads were used. But yes I need to get a good tune in the car.
#18 |
Member#: 100605
Perhaps as a point of reference, my '06 WRX put down 292/352 with just a VF43/STI TMIC/TBE and a tune.
#19 |
Member#: 157798
Vehicle:2007 wrx for sale!! BLuE |
they should still be higher numbers dude.....I would go to another tuner
#20 |
Member#: 108091
Vehicle:2002 WRX |
Am i the only one that didn't miss it? This car was road tuned, then it was dyno'd. It was never dyno tuned from what it sounds like. Which would most likely put up another 20-30 whp or so once optimized. Or am i being optimistic?
#21 | |
Member#: 141536
Josh |
#22 |
Member#: 130204
Vehicle:06 WRX IAG Built 11 Denali |
Goodluck with your setup... I wanted a 20G really bad when I first started building mine up but the 2.5 has had such great results with the VF series turbos I went the cheaper route.
#23 |
Member#: 170602
Vehicle:06 Wrx 6Spd TSBorg Warner S400-Aem-2200s |
I think you will be stoked when you finally get it dyno tuned. Im sure everything is fine, don't worry too much about your less than normal numbers until you get a better tune...!
#24 |
Member#: 142015
NESIC
Vehicle:2007 STI/Speed3 OBP/SSM |
Go meth, EWG and another tune and you'll see more POWA!
#25 |
Member#: 137556
BAIC
Vehicle:2011 STI Sedan OBP |
Why the STI RA gears and not a 6-speed swap or PPG's or even Mfactory if its a money thing ? Im sure you'll get the bugs worked out if you dont go to the poor house first.
| Thread Tools | |
| Display Modes | |
| 20g 06 WRX 1/4 mile time | al82 | Factory 2.5L Turbo Powertrain | 1 | 10-07-2009 11:18 AM |
| 20g 06 wrx vs 04 sti vf39 | PDT | Proven Power Bragging | 33 | 10-30-2007 01:21 AM |
| 20g 06 wrx plans advice | jrbouncer06 | Factory 2.5L Turbo Powertrain | 17 | 03-06-2007 10:15 PM |
| pdx or 20g map for 06 wrx with 20g | pollawrx06 | Engine Management & Tuning | 0 | 10-27-2006 06:43 PM |
| FP TD05H 20G on 06 WRX | blinguskahn | Factory 2.5L Turbo Powertrain | 33 | 01-12-2006 11:50 AM |
