Old 09-24-2008, 02:18 AM   #1
yeos
Member#: 133855
2009 STi SparkSilver
Dom Tuned @ MPS
Default what else to look at replacing when doing clutch ? flywheel?
I'm planning on replacing my clutch and flywheel within the next two months with an exedy oem clutch and flywheel. I am wondering what else I should look at replacing while the motor is out? I will probably change out the rear main seal, but aren't sure what else to do. My stock motor has 164k miles and recently had the headgaskets replaced as well as all the seals within the valve cover.
yeos is offline   Reply With Quote
Old 09-24-2008, 08:43 AM   #2
Feign
Member#: 68604
06 STi
Front axle seals if they're leaking, motor mounts, tranny mount, pitch stop if you feel like it, tranny crossmember bushings, rear diff mount bushings, outrigger bushings. Shifter bushings and a short throw?
Feign is offline   Reply With Quote
Old 09-24-2008, 09:08 AM   #3
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
rear seal if it's leaking
hangman is offline   Reply With Quote
Old 09-24-2008, 10:43 AM   #4
SOHCEJ25
Member#: 135013
'17 WRX Hatch ; )
Also reseal the 2 plates on the back of the engine ( behind the flywheel ) with Permatex Grey or OE Subaru silicone ....
Shawn
GerBrock.net
My Site
SOHCEJ25 is offline   Reply With Quote
Old 09-24-2008, 02:06 PM   #5
John*G
Member#: 19562
95 coupe
red
Steel replacement "snout" for tranny, The aluminum wears out over time (like 164 k). You get a steel tube that slides over the tranny and a slightly larger throw out bearing to ride over it.
John
John*G is offline   Reply With Quote
Head gaskets being replaced, what else to do while engine is out nardvark Service & Maintenance 9 04-15-2009 03:10 PM
What else to upgrade during clutch replacement? ATXWRX Transmission (AT/MT) & Driveline 3 08-09-2006 07:09 PM
What else to replace while doing timing belt replacement? the_glassman Normally Aspirated Powertrain 3 04-16-2006 11:58 AM
Replacing radiator, what else to replace while I'm at it? MT_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-20-2005 07:53 PM
What else to do when doing uppipe/exhaust? mikkyo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-19-2002 09:24 PM
