Old 09-24-2008, 11:59 AM   #1
thugzlife
Member#: 167895
2005 Impreza 2.5 RS
Default 2005 2.5rs - Floor the gas and Car stops responding
So Iíve been having a problem recently where if i floor the gas pedal in certain situations the car will stop responding until restarted.
  • Iíll be lightly tapping the gas going around 35 mph
  • I then decide to push the gas pedal completely down.
  • The engine rev doesn't rev the car up in response to me flooring the gas, as soon as the pedal is floored the check engine and cruise control light will blink. The engine immediate starts to idle higher in every gear except neutral.
  • The car is put in some sort of mode where no matter how hard I push the gas down it moves one speed, but just barley (10 mph at tops). And the rev will never go high.
  • Once I restart the car everything is fine except the check engine light which doesn't go away for a few days.
thugzlife is offline   Reply With Quote
Old 09-24-2008, 12:15 PM   #2
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
It sounds like "limp mode" is being activated. This prevents the car from revving over a certain RPM and limits fuel delivery. I think it's a failsafe for if the ECU isn't getting readings from certain sensors (or they have failed).
But I thought it was closer to ~30MPH that people had found was the maximum speed...
fastenova is offline   Reply With Quote
Old 09-24-2008, 12:28 PM   #3
thugzlife
Member#: 167895
2005 Impreza 2.5 RS
Yea my speedo was broken at the time it was prob 25 or 30
Old 09-24-2008, 01:54 PM   #4
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
My guess is that your TPS or pedal sensor is reading high when you floor it, throwing a code and activating limp mode.
There are a couple redundancies that make up a "health check" for your DBW system. If the system stops responding correctly, it will go into limp mode to prevent the car from running away to WOT.
EDIT: have somebody pull the code, it will tell you which sensor is acting weird.
EDIT again: Actually, if the engine doesn't respond BEFORE the CEL gets thrown, it could be the throttle plate sticking, also. Regardless, pull the code.
sniper1rfa is offline   Reply With Quote
Old 09-24-2008, 04:25 PM   #5
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Do you have the snorkus delete done to your car?
Gr3en is offline   Reply With Quote
Old 09-24-2008, 06:30 PM   #6
thugzlife
Member#: 167895
2005 Impreza 2.5 RS
^^No, everything is completly stock.
Also forgot to add That I can floor the gas in other situations. I first thought it was the intake problem with the MAF sensor, but it has happened too many times.
Old 09-25-2008, 12:54 AM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Read the CEL. All this is just pissing in the wind until you get the code read.
Old 09-29-2008, 02:53 PM   #8
thugzlife
Member#: 167895
2005 Impreza 2.5 RS
I got the codes p2123, p2128 and p2123 pb, p2128 pb
Old 09-29-2008, 02:56 PM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Your DBW system is pissed the frak off. Specifically, it's bitching about the pedal position sensor. However, it doesn't always bitch about what's actually wrong. Could be the pedal position sensor, could be the place position sensor, could be the plate actuator, could be the wiring. Honestly, something that complex and safety-critical should just be taken to an SAE certified mechanic with experience with Subaru DBW.
Anyone have a 2.5rs? Hows the gas mileage? Touge86 General Community 15 04-16-2008 05:00 PM
2.5RS Floor Mats and seat covers Andursun0013 Private 'For Sale' Classifieds 3 06-20-2006 11:42 AM
2005 2.5RS, Do they make headers for this car? ImprezaRS05 Normally Aspirated Powertrain 27 02-14-2006 12:07 PM
Does the Apex'i cat-back from a GC body fit the 2005 2.5RS? awdlifestyles Vancouver Impreza Club Forum -- VIC 6 09-26-2005 10:03 PM
Well, my 2005 2.5RS is wrecked and in the shop... (details inside) 3DF General Community 81 02-24-2005 02:35 AM
