Old 11-24-2008, 07:26 AM   #276
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Originally Posted by rjrutzky View Post
Have these hit retailers yet? Any reviews of the new part?
They're on my track car, so I won't really be able to test them until March.
Old 11-24-2008, 10:41 AM   #277
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I'll be driving 600mi through PA mountains on them all weekend, I'll report back.
-- Dave
AcquaCow is offline   Reply With Quote
Old 11-24-2008, 12:35 PM   #278
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
The above pictures is a poor comparison, considering how the two balljoints are not lined up with each other very well. Also, one of them has the conical sleeve installed already which does not help the comparision.
aboothman is offline   Reply With Quote
Old 11-24-2008, 01:11 PM   #279
mav1c
Hoodbridge!
Member#: 560
Sorry it's not up to your standards.
Old 11-24-2008, 01:34 PM   #280
unclemat
Member#: 114530
2005 LGT 6MT wagon
The question is whether the height difference matters with respect to the tie rod ends. I thought the tie rod ends and the roll center balljounts were designed as kit. Now, if the height of the new ball joints slightly changed, does it mean that the tie rod ends should have also been revised?
unclemat is offline   Reply With Quote
Old 11-24-2008, 02:00 PM   #281
Daishi00
Member#: 78952
2005 WRX
CGM
It's pretty easy to compare the two in your pic. Not sure what the complaining is about. You can see the significant differences in thicknesses of each part. Also pretty easy to see that they are the same size too.
Daishi00 is offline   Reply With Quote
Old 11-24-2008, 02:08 PM   #282
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We just got our first sets in today. Haven't installed any yet though.
Tony
Old 11-24-2008, 07:03 PM   #283
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Well my "standards" are hardly high, nor am I "complaining." I guess sitting both ball joints on end on a flat surface is too much to ask. Putting a ruler next to each as a frame of reference is definately out of the question. What about removing the conical sleeve?
The new (left) ball joint is obviously at a different angle than the old one, nor is it held even with the old one lengthwise.
My point is that you are directly contradicting a representative of Whiteline. If a half-assed picture is the best you can do to prove your point, then you should probably not post it in the first place. It just appears to me that you are seeing what you want, and starting rumors with an inaccurate photo as proof.
If I seem defensive to you, consider that I am a Whiteline customer who has purchased and installed this part, and then paid for an alignment. I am very interested in issues and changes to the specs of said part, so it reasonable that I expect anyone claiming Whiteline's info is not entirely accurate should have their **** together.
Old 11-24-2008, 07:58 PM   #284
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Originally Posted by fullerton View Post
looks to me like the extension area is significantly shorter.
It's hard to tell from this picture, but I'll bet that WL just moved the position of the end of the boot. Not sure why, but that's the only way I could see them not having changed the offset. I just got mine, so I'll try to get them photographed and installed tomorrow night since I plan to run the car up to my parents this weekend.
Frank
Frank A is offline   Reply With Quote
Old 11-24-2008, 07:59 PM   #285
mav1c
Hoodbridge!
Member#: 560
Sorry it's not perfect and there's no ruler. It's not a technical picture, just a reference. And I am not the one complaining it's shorter, or complaining at all. I thanked Whiteline for the replacement. Oh, and the picture wasn't even taken by me. It's just a picture comparing the two. That's all. I never said it was anything else, or tried to make exact measurement comparisons. It is pretty obvious that there is a difference. That's all the pic was meant for.
Old 11-25-2008, 08:41 AM   #286
subiesoon
Member#: 78103
05 FXTi
2.5mm difference
subiesoon is offline   Reply With Quote
Old 11-26-2008, 01:22 PM   #287
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Ok. Installed mine and took some more pictures. I tried to line the three joints up in a vise to keep the height of the part where the cone rests the same. From this picture, I think the new ball joint does have the same offset as the old one. Note that there is a slight angle on the new joint, but I tried to minimize it so as not to throw off the visuals:
L-to-R: stock, new WL, old WL:
apologize for the crummy shot, but here's an attempt to show the change in width of the upper surface:
Some observations- joints fit maybe a hair tighter in the hole. Prior to installation, they were definitely stiffer than the old ones- I had to use leverage to get them to move. Moving the metal shoulder down gives the boot more room. For whatever reason, I'm getting a clank on the right side coming off drop-offs that I am still investigating- too soon to tell if its from the joint or something I did at the last track event. The BJ that was loose before was on the left side (it is also the one in the photos, so you can see the dirt on the shoulder area).
Edit: the clunk was a loose strut top nut on my Cusco camber plate. My bad for not tightening them enough originally. The cusco plate's stack height is so tall that I can't access the flat spots on the KW's rod without using a pair of needle nose pliers. I think its tight enough now, but we'll see.
Frank
Old 11-26-2008, 08:06 PM   #288
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I just put 300mi of combo highway/PA twisty mountain roads on the new balljoints.
No clunking or unexpected behavior.
No noticeable bumpsteer either...
Will look at them close up in the AM to see if they are still seated completely.
-- Dave
Old 11-27-2008, 02:28 AM   #289
WL Flatout
Member#: 35326
G'day everyone,
If you measure the distance from the step or knuckle seat to the end of the stud it should be the same for both versions.
Cheers
Whiteline Jim
Whiteline Flatout
www.whiteline.com.au
WL Flatout is offline   Reply With Quote
Old 11-28-2008, 11:27 PM   #290
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
I should be getting a set of these in a couple days, TIC already shipped them out, i probably wont be able to post any real data about it until spring when the track opens up again but this should be the last suspension part i will be changing... nothing really left except for some odds and end bushings, (steering rack, outrigger, rear diff) current setup for Time attack/short circuit
DMS 40mm Gold
DMS adjustable camber plates
helix 21mm FSB
Hotchkis 25mm RSB
Hotchkis rear endlinks
Cusco Trailing arms
Cusco Latteral Links
Aluminum control arms
Urethane control arm bushings
Cusco Front and rear strut bars
I hope the WL roll center kit is the icing on the cake.
wopdeeze is offline   Reply With Quote
Old 12-05-2008, 12:22 PM   #291
jim1969
Member#: 34877
2005 Legacy GT sedan
-- Dave
were they seated?
jim1969 is offline   Reply With Quote
Old 12-05-2008, 12:36 PM   #292
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Originally Posted by jim1969 View Post
were they seated?
Actually haven't looked yet.. it's been cold.
I have ~1000mi on them now...will check tonight if I can find my flashlight...will hopefully take pics too.
I'm sure they are due for a re-torqing (as per the install instructions) as well...
-- Dave
Old 12-08-2008, 11:58 AM   #293
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
I replaced the defective RCA's with the new version sent by Global last week.
The defective RCA's had come out of the spindle about 3mm.
I've driven about 700mi and have done about 5 dyno pulls during a tuning session on the new RCA's. So far the new RCA's are still in their proper place
Sucks that I had to pay ANOTHER $90 for alignment due to the defective parts. I guess I'm lucky because I can install stuff like this on my own. Otherwise you gotta pay labor twice and this mod becomes extremely expensive, more so if you end up damaging your spindles.
engineerx is offline   Reply With Quote
Old 12-08-2008, 02:15 PM   #294
lemon19mmm
Member#: 144545
GG Wagon
Where can I buy the new version RCA?
lemon19mmm is offline   Reply With Quote
Old 12-08-2008, 05:14 PM   #295
pio!pio!
Member#: 4190
2008 Impreza WRX STi
I just got the fixed version in the mail today. I haven't lowered my car yet; if I install these before I lower my car, will it detrimentally upset my camber curve?
pio!pio! is offline   Reply With Quote
Old 12-08-2008, 07:42 PM   #296
WRX 2002
Member#: 11211
2004 STi
Rally Blue
By replacing the ball joints, why would you need another alignment?. The yare tecnically the same size where it counts for the alignment. Just wondering if I missed something.!.
N.
WRX 2002 is offline   Reply With Quote
Old 12-08-2008, 07:46 PM   #297
WRX 2002
Member#: 11211
2004 STi
Rally Blue
I had the same question to Whiteline and I quote:
"You'll have no problems with running the KCA313 kit with a standard height set up, it will work to offer additional roll resistance in addition to swaybars and offer better than factory bump steer settings."
I change my suspension every season between ice racing and summer track day setup, so wanted to know if I need to also change the BJ and tie rods. This will save a little work and reduce the possibility of damaging them by installing and uninstalling them every year.
N.
Old 12-08-2008, 07:49 PM   #298
WRX 2002
Member#: 11211
2004 STi
Rally Blue
MAPERFORMANCE, is where I purchased mine from. Very helpful and reasonable pricing and quick shipping. Even for getting my replacement set.
http://www.maperformance.com/whiteli...3-wrx-sti.html
Old 12-17-2008, 11:23 PM   #299
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Well, ~2000mi and the new ball joints are still firmly seated in the hubs...
I certainly haven't been going easy on them...
-- Dave
Old 12-17-2008, 11:26 PM   #300
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I just need the weather to cooperate so that I can swap my replacements in
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Suspension/Brakes/Handling 4 12-03-2009 09:34 AM
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Tri-State Area Private Classifieds 3 12-03-2009 09:34 AM
Brand new in Box - Whiteline Roll-Center Adjusting Kit & Kartboy Pitch Stop Mount! CALIBAN Suspension/Brakes/Handling 6 03-06-2009 05:33 PM
fs: 169 BRAND NEW Whiteline Roll Center adjuster kit fastwrx25 Suspension/Brakes/Handling 3 07-29-2007 03:53 PM
