Old 05-03-2009, 10:01 PM   #401
Rexer06
Member#: 125065
2006 WRX
Originally Posted by STi-MAN View Post
Ok so i finally got my car up and checked.. the passenger side ball joint isnt seated as tight as the drivers side.. i've never run the whiteline ball joint kit.. so seems like theres still a bit of a issue with seating..
was this visible? did u try using a metal rod to try prying it to check if it was indeed loose?
Rexer06 is offline   Reply With Quote
Old 05-03-2009, 10:45 PM   #402
STi-MAN
Member#: 70252
05 STI
blue
it was visible.. i used my hand to shake to see if its loose.. was not loose by hand.(yes i know thats not saying much)
Gap was the same as rexworx's pictures.. so slight.
STi-MAN is offline   Reply With Quote
Old 05-04-2009, 11:57 AM   #403
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Did you clean out the receiver in the knuckle ? When I did mine I had less than 30,000 mi. and there was some rust and crud inside. I used a scotch pad and worked on it for a few minutes, a lot of stuff came out. I also used the jack under it to apply pressure when I seated it. Don't know if any of that will help. I haven't had any issue with mine, 10 auto-x runs is the hardest I have pushed it though. I probably have 3000 miles or so on them to date.
UFOpilot is offline   Reply With Quote
Old 05-04-2009, 02:26 PM   #404
STi-MAN
Member#: 70252
05 STI
blue
yes sir i did.. maybe anti seize could be culprit as well? either way we now know that it does not seat correctly on knuckles that have never seen a white line balljoint..
i have over 3000 miles and 2 track days on them going on 3 this weekend.
Old 05-04-2009, 02:44 PM   #405
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
I guess anything is possible, but I used what I presumed to be a decent amount of anti-seize, and mine locked in fine. Also I did not have Version 1, so mine went into knuckles that had never seen anything but stock parts prior. Casting tolerances maybe ? Who knows, good luck with it though I hope it turns out to be no big deal.
T.
Old 05-04-2009, 07:19 PM   #406
WL Flatout
Member#: 35326
G'day everyone
STi-MAN, we're struggling to understand why this might be happening to you as our guys are very confident that the new design ROCK body is even a better fit than stock. That is, in the last design change, particular care was taken to make sure the external mount dimensions were as good as they could be and dare I say, potentially better than stock with a tighter tolerance.
There are a number of possible explanations but an important thing to keep in mind is that the design of any of these sort of performance products must lead to greater side loads on the knuckle meaning everything else needs to be in good order. Fitment and related issues become even more important.
I guess Iím suggesting that fitting stock ball joint back in to these knuckles may or may not show the same symptoms but at the end of the day, we will always stand behind the product and provide a refund if customers arenít happy. Please let us know if there is anything we can do directly to help you here.
Cheers
Whiteline Jim
www.whiteline.com.au
WL Flatout is offline   Reply With Quote
Old 05-04-2009, 07:47 PM   #407
STi-MAN
Member#: 70252
05 STI
blue
Originally Posted by WL Flatout View Post
G'day everyone
Cheers
Whiteline Jim
I havent really noticed any noise.. or clunking from that side.. so after the track event this weekend.. i'll take some more pictures.. Thanks Jim.
Old 05-05-2009, 01:30 AM   #408
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Sorry I havent been around...
Yes the knuckles were tight. I cleaned them out, used anti-seize, the had to tap the in.
since then I popped it back in and havent had it pull out at all again.
Ian,
Hi everyone,
Good to see so much positive feedback about the new product but lets deal with the questions too.
blahhblahh, probably best to contact our US distributor, Global Performance Parts about a replacement set. They'll look after you.
rexworx, talking to the engineers the only conclusion they can come to is that the knuckle or mounting is worn. Did you remember how tight they were going in? They should be very snug as we tweaked all the tolerances. Did Tim come back to you?
Let me know and I'll follow up.
Best
Whiteline Jim
rexworx is offline   Reply With Quote
Old 05-26-2009, 12:31 PM   #409
ragejed
Member#: 76817
2005 WRX
Thumbs up
G'day everyone
Cheers
Whiteline Jim
Its statements like this that make me want to buy whiteline products and not the competitors!!
ragejed is offline   Reply With Quote
Old 05-26-2009, 12:37 PM   #410
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Many miles of performance driving at the limit and mine are seated properly. No issues, no complaints.
Good product.
Travis
Old 05-26-2009, 02:20 PM   #411
wantsti
Member#: 134764
04 sti
java black pearl
i'm getting mine this week i hope they work out good.
wantsti is offline   Reply With Quote
Old 05-26-2009, 02:28 PM   #412
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
I've installed mine on my GC1 Impreza over 2 months ago and the ball joints are still in their original position. Good product Whiteline
Ramon_12345 is offline   Reply With Quote
Old 05-27-2009, 12:04 AM   #413
Lutfy
Member#: 150245
Whiteline had their unit sent to me directly from Australia (am in Dubai) UPS Express. Installed the new kit, a couple of autox and a few track days. No noise, no fitment issue all the benefits of the kit.
I do understand in R&D sometimes issue(s) can rise. But the fact that WL stood behind their product and the excellent customer service...As they say "atta boy!"
Thank you folks.
Lutfy
Lutfy is offline   Reply With Quote
Old 06-07-2009, 11:22 PM   #414
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
I just installed this kit onto my 03.
The ball joints have that same gap, however, there's no movement or associated nasty clunking noises. I took it out after a test drive and everything's tight.
The issue with this knuckle design is that the knuckle essentially becomes a wear item. Some of the knuckle will absolutely come off when you take out the old ball joint (which is why most companies don't use this design).
I'll see how things hold up.
03SubyWRX is offline   Reply With Quote
Old 06-08-2009, 12:13 AM   #415
wantsti
Member#: 134764
04 sti
java black pearl
I installed mine with no issues. huge improvement!! I'm very happy.
Old 06-08-2009, 07:59 AM   #416
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Checked mine and they're fine after 2 weekends of track.
Nothing to do with the RCA Kit, but it does make it diffucult to route the hose for the RCE brake ducts.
Old 06-09-2009, 09:25 PM   #417
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
Just wanted to update.
I checked my Whiteline joints today after hearing a clunk for about a day. I was concerned it was the lower ball joints coming out. The ball joints are fine with no sign of coming out whatsoever.
What was making the noise however was a broken sway bar link, which will be repaired tomorrow afternoon.
I just want to say thanks to Whiteline in the end for a great product. Even without that link I my bumpsteer has decreased immensely. While I was worried about the ball joints not fitting, I can safely say they are well updated and are seated perfectly, even after some horrible potholes only to be found in Boston came across them. Well done Whiteline!
Old 08-24-2009, 01:49 AM   #418
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Any feedback on people running the new version of Whiteline RCA?
Fierysun is offline   Reply With Quote
Old 08-24-2009, 01:50 AM   #419
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It works. Get one.
Old 08-24-2009, 07:42 AM   #420
mav1c
Hoodbridge!
Member#: 560
Did you read the whole thread?
Old 08-24-2009, 08:44 AM   #421
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Update from me after ~5000mi
These seem to be rusting a lot faster than the old ones. One is seated flush, one is not by about 1mm?
-- Dave
AcquaCow is offline   Reply With Quote
Old 08-24-2009, 09:06 AM   #422
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Weird. Mine are both fully seated and neither is rusting here in Central Ohio, the Rust Capitol of the World.
Old 09-11-2009, 01:02 PM   #423
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I loosened the bolt on the passenger one that was showing the gap (above) and popped it back in to place this weekend.
Re-torqued to 45ftlbs, will see how long it stays that way.
I need to grab an alignment before driving the car out, but after that, I'll drive it daily till winter and see if it moves at all...
-- Dave
Old 09-11-2009, 01:23 PM   #424
mav1c
Hoodbridge!
Member#: 560
After 3 more track weekends, mine are still fine. And not a hint of rust.
Old 09-11-2009, 01:25 PM   #425
STi-MAN
Member#: 70252
05 STI
blue
^same here.. but im in california. no winter. no salt
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Suspension/Brakes/Handling 4 12-03-2009 09:34 AM
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Tri-State Area Private Classifieds 3 12-03-2009 09:34 AM
Brand new in Box - Whiteline Roll-Center Adjusting Kit & Kartboy Pitch Stop Mount! CALIBAN Suspension/Brakes/Handling 6 03-06-2009 05:33 PM
fs: 169 BRAND NEW Whiteline Roll Center adjuster kit fastwrx25 Suspension/Brakes/Handling 3 07-29-2007 03:53 PM
