Old 02-13-2013, 03:13 PM   #551
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Originally Posted by wrxrally85 View Post
totally random but if you had 2400 to piss away on your wrx or sti right now what would you do in order?
Totally off-topic, but:
Sway bars + endlinks
Bilstein Struts w/ RCE yellow springs
If you're doing your own install, then use the leftover money for bushings.
Mr Wrex is offline   Reply With Quote
Old 02-13-2013, 03:23 PM   #552
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Start a new thread as though I weren't a total idiot intent on derailing a thread having nothing to do with the question I'm asking. Best part about that mod is that it's free.
Old 02-14-2013, 09:15 PM   #553
13BRZltd
Member#: 344145
Doesnt have to be whiteline but an rca kit is a great thing to have if you lower your car much i like mime
13BRZltd is offline   Reply With Quote
Old 03-02-2013, 01:39 PM   #554
DaveyPetey
Member#: 239944
2002 WRX Sedan
Instead of starting a new thread I thought I'd put my question in this thread as it seems related. I also emailed WL but haven't heard from them yet.
I have been trying to figure out how the RCK would perform with a mildly lifted (1-2") on my sedan. The bump stop idea seems to be really desirable for bumpy roads as many have stated, and some use the kit on stock height springs, so I am wondering how it will translate on weekend light rally duty with something like a King Springs lift. Any comments or explanations of why this is a good or bad idea would be awesome, as I haven't been able to find much on this specific question.
Thanks all
DaveyPetey is offline   Reply With Quote
Old 03-02-2013, 01:50 PM   #555
Web Foot STi
Member#: 39086
2004 STi
The whole idea behind the WL RCA is to re-level the lower control arm and tie rod pivot points on a lowered car so the links are moving closer to the middle of their arc. On a raised car you need the exact opposite.
Web Foot STi is offline   Reply With Quote
Old 03-02-2013, 02:00 PM   #556
DaveyPetey
Member#: 239944
2002 WRX Sedan
That is what I thought, but the guys at rallisport told be I would see still see benefits from the kits even on a lifted car. I thought this didn't make sense. I need to see a diagram of the changes to get this straight in my head...
Old 03-02-2013, 02:27 PM   #557
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You'll sort of still see benefits. You'll get more negative camber gain with roll once you install it, plus you'll still get the improved bump steer characteristics. At stock height, I still think the KCA313 is absolutely worth installing. Lifted a couple of inches, I would think it should still benefit but I haven't tried it.
Old 03-02-2013, 02:39 PM   #558
Web Foot STi
Member#: 39086
2004 STi
No need for pictures, or a compass and paper. Take your elbow and put it into your rib cage, hold your arm out horizontally, and walk over to a wall with your finger tips. Sweep your had up and down only pivoting at your elbow. You will see your fingers move away form the wall with more distance the farther you deflect your hand.
No for simplicity's sake imagine your arm it a tie rod your elbow is one pivot and your finger tips are the other. As your suspension moves in bump and droop the effective tie rod length changes. The further the arm is from horizontal the greater the change. This causes the steering arm to move inboard and outboard changing the toe. Hence the term bump steer.
Camber gain gets a little hairier to visualize, but I think Willity is right to a point. It's all a compromise.
Old 03-02-2013, 02:44 PM   #559
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well, your example for bump steer isn't quite right. I mean, you're right about things getting closer and farther away, but the big problem is that there's two arms.
Both the control arm and the steering arm move on pivots and trace out arcs. Since their pivots aren't in the same plane on both inboard and outboard ends, they trace out slightly different arcs. The difference in relative position of the outboard pivots as you move up and down the arcs is where bumpsteer comes from. When you go to the extended ball joints, you move the outboard pivot of the control arm, and therefore change the arc it traces out. To get the steering arm to agree with it again, you have to change the position of the steering arm's outboard pivot as well.
Old 03-02-2013, 02:52 PM   #560
Web Foot STi
Member#: 39086
2004 STi
I don't disagree, but I was trying to KISS it.
The RCA is designed for lowered geometry and I am assuming that WL has taken the subtitles that you mention into account. The difference between my cocktail napkin and real engineering.
P.S. I'm real old school and have used a drafting board and a T square.
Old 03-05-2013, 12:34 AM   #561
DaveyPetey
Member#: 239944
2002 WRX Sedan
What do you see as the benefits at stock height?
Old 03-05-2013, 12:37 AM   #562
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Improvement to the shape of the camber curve, negative camber gain over a greater amount of bump travel/roll, improved bump-steer characteristics.
Old 03-05-2013, 01:12 AM   #563
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
What's the trade off? Why wouldn't the subaru engineers have done this in the for place? Parts bin? Clearance? Legacy design? Intended loss of camber for "street friendliness"? More pronounced "body roll feel" which is objectionable to the average joe?
(Not doubting the benefits you mentioned, but there's never a free lunch; unless its a design goal change)
chimchimm5 is offline   Reply With Quote
Old 03-05-2013, 01:14 AM   #564
DaveyPetey
Member#: 239944
2002 WRX Sedan
Anyone using the kit for any rallyx duty at all?
Old 03-05-2013, 01:14 AM   #565
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Oh, forgot to add reduced roll couple as well.
Downsides are a raised roll center (which increases jacking forces, which are totally not a problem for the front end of these cars) and increased stresses on the parts.
As far as why not, lawyers or accountants, pick one. The stock design is probably a few cents cheaper and also promotes understeer (which helps avoid lawsuits).
Old 03-05-2013, 01:16 AM   #566
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, I've built about a dozen cars now for guys that RX on a regular basis. Not a single accelerated failure with any of them. The only problem with these things now is that the boots are a bit weak. Plan on replacing the boots every other year with the boot replacement kit Whiteline sells or plan on replacing the whole setup every 3-4 years if you forget the preventative maintenance of replacing the boots before they crack.
Old 03-05-2013, 08:38 AM   #567
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
on a slightly unrelated note...
anyone who has installed this. how much available threads are there for the stock arms? any more or less for these?
asking because i want to increase track width, and wondering if the stock tie rod ends have enough thread to be pushed out ~15mm
gsrcrxsi is offline   Reply With Quote
Old 03-05-2013, 11:29 AM   #568
DaveyPetey
Member#: 239944
2002 WRX Sedan
What height are these guys running? I'm very interested to know.
Old 03-05-2013, 11:51 AM   #569
chimchimm5
Member#: 88501
2006 WRX Wagon
CGM
Is this boot only lasting a year a "snow belt" thing?
Old 03-05-2013, 01:02 PM   #570
T-37
Member#: 175624
**** YOU
IT'S BLUE!
If I remember, I'll crawl under the car and compare the tie rod end lengths lengths (stock 04 WRX vs whiteline) when I get home tonight. Though 15mm doesn't seem like much at all, my suspicion is it would be fine either way.
T-37 is offline   Reply With Quote
Old 03-05-2013, 01:49 PM   #571
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, it's fine coming from a wagon, at least. With increasing the track width by going from wagon to STi arms, I still have close to an inch and a half of tread engagement.
Most settle in around 1/8" below stock RS ride height by the time all the mods are done. Generally, near stock RS height turns out to work well for RX.
2 years and yeah probably.
Old 03-06-2013, 01:20 AM   #572
jamal
Member#: 71875
98 2.5GT
my wheels fit
Almost three years on mine. Joints are still tight, boots all look good. Car has been on a lot of gravel and snow lately too.
If someone with a wagon and sedan arms was worried about it they would just need to get sedan inner tie rods.
jamal is offline   Reply With Quote
Old 03-06-2013, 01:27 AM   #573
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I looked at that once long, long ago and, at least for mine, the numbers were the same. Different years/models could vary considerably.
Old 03-06-2013, 04:42 AM   #574
fastwrx25
Member#: 126441
03 bugeye
no problems with wider sti arms on my wagon. enough thread on inner tie rods
fastwrx25 is offline   Reply With Quote
Old 03-06-2013, 07:35 AM   #575
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
Well from what I'm reading. The only difference in width for the GDs was something like 5mm per side. Going with wider arms on the GE/GH gives something like a 15mm difference per side.
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Suspension/Brakes/Handling 4 12-03-2009 09:34 AM
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Tri-State Area Private Classifieds 3 12-03-2009 09:34 AM
Brand new in Box - Whiteline Roll-Center Adjusting Kit & Kartboy Pitch Stop Mount! CALIBAN Suspension/Brakes/Handling 6 03-06-2009 05:33 PM
fs: 169 BRAND NEW Whiteline Roll Center adjuster kit fastwrx25 Suspension/Brakes/Handling 3 07-29-2007 03:53 PM
Message Board Statistics All times are GMT -4. The time now is 09:27 AM.
