Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 10-05-2008, 10:57 PM   #51
Rexer06
Member#: 125065
2006 WRX
i've the whiteline RCA kit installed on my 2006 WRX and i'm getting paranoid after reading some of the less than favourable comments. what should i look out for or check to see if there are any defects?
Rexer06 is offline   Reply With Quote
Old 10-05-2008, 11:00 PM   #52
DuckStu
Member#: 124060
2004 WRX STI
Basically,...listen to the car. If you hear clunking in the front end like somethig is worn or loose when you drive over rough pavement,....check it.
I went back to stock today. 2 set of ball joints went bad within 6,000 miles each.
Too much hassle.
DuckStu is offline   Reply With Quote
Old 10-05-2008, 11:04 PM   #53
MasterKwan
Member#: 98961
2003 WRX
Crawl under the car, you can do it from the front and examine where the balljoints go into the knuckles, there shouldn't be any gap or any of the large barral of the balljoint pulling out of the knuckle. That's the first thing I noticed.
Old 10-05-2008, 11:05 PM   #54
Rexer06
Member#: 125065
2006 WRX
great tips! thanks!
Old 10-05-2008, 11:22 PM   #55
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Hmm... I haven't heard any of these comments...
Links?
Thanks,
-- Dave
AcquaCow is online now   Reply With Quote
Old 10-06-2008, 02:06 AM   #56
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Links?
Heard any of what comments? Links to what?
Old 10-06-2008, 05:32 AM   #57
CPC
Member#: 123085
2006 WRX
Originally Posted by boost junkie View Post
I recently started getting some vibration through the steering wheel that's noticeable all the time. It's particularly scary during trail braking.
Wow! I had this exact same thing at my last race meet! When trailing the brake the steering wheel wanted to reef out of my hands. I raised my concerns earlier in this thread about the WL ball joints but I never suspected they might be responsible for this. I assumed it was a mistake with my brake pad bedding procedure (new Hawk HT10's). I'm putting some 6Gun hubs in soon and will go back to stock ball joints. I'll be able to see what difference it offers in handling.
Chris.
CPC is offline   Reply With Quote
Old 10-06-2008, 08:33 AM   #58
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
The ones mentioned here:
-- Dave
Old 10-06-2008, 08:43 AM   #59
dunk
Member#: 15359
Replaced mine with the stock ball joints. Did five sessions at a track day this weekend before my turbo grenaded. Didn't notice any meaningful difference in handling.
Duncan
dunk is offline   Reply With Quote
Old 10-06-2008, 09:38 AM   #60
DuckStu
Member#: 124060
2004 WRX STI
-- Dave
Read this thread. Plenty of them in here.
Old 10-06-2008, 12:48 PM   #61
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Oh, whoops.
I clicked right to the last post when I first read this thread, which had the response I quoted as the first post on the page. I didn't notice that there was a proceeding page.
That said, I'll check under my car tonight and see if my ball joints are starting to separate.
I have probably 10kmi of driving hard on these, but with only street tires...
I didn't see anything out of place when I was adjusting the camber bolts on Friday...
-- Dave
Old 10-06-2008, 12:57 PM   #62
Rexer06
Member#: 125065
2006 WRX
I recently started getting some vibration through the steering wheel that's noticeable all the time. It's particularly scary during trail braking, the first time it happened I thought I snapped a tie rod or something. Although in that extreme sense, the problem is intermittent. When I got the car up on the lift and gave the control arms and tie rods a really good tug I couldn't feel any play in the ball joints so I ruled that out. I'm wondering now if I should take them off the car and give them a closer look, I've only had the Whitelines installed for a couple months but maybe that's enough...
did u manage to check/confirm that the RCA was the cause of the vibrating steering wheel problem?
Old 10-06-2008, 01:50 PM   #63
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
-- Dave
I'm pretty sure he was referring to the comments in this thread that you replied to. Did you read the thread before you replied? If so I would think it would be pretty obvious that people have had some significant issues with all parts of the WL kit.
Pat
Old 10-06-2008, 05:12 PM   #64
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Pat
Yes, I realized that and posted about it about 2 posts above yours.
Did you read the thread before you replied? If so I would think it would be pretty obvious that I have realized and corrected my error.
-- Dave
Old 10-06-2008, 07:34 PM   #65
WL Flatout
Member#: 35326
G’day everyone
Just got a heads-up about this thread, thought we’d try to help.
DuckStu, though we’ve heard about play in the ball-joints this is the first time we’ve heard about repeated issues like that in such quick time. Is it possible for you to contact us direct on jim@whiteline.com.au to talk a little more about this. Would really like to have the old ones back here to test as we have made some running changes over the last 12 months to keep improving the product. As for swaybar surface finish, I understand your frustration in replacing parts but I would still be happy to change over any part that a customer may not be happy with.
CPC, not sure about the steering feel changes while “trailing the brake”, I would think that this would be an overall setup and alignment issue rather than roll centre kit related. Can you tell me what the lowering height you are running along with wheel size and or offset, alignment settings?
AcquaCow, not sure I understand the comment re ”ball joint separating” but you might be seeing the extra spacing below the hub that is part of the dimension change. That is, assuming it's properly seated, the exposed body of the ball joint is longer than the stock.
Overall, from a handling “feel” point of view, the roll centre adjustment component of the KCA313 kits is designed around lowered heights between 20-50mm from stock. That is not to say that it will not “work “ for stock vehicles but the desired outcome is optimised for lowered. Also, because the product is generally fitted to highly modified vehicles, there are typically many other changes that are working at the same time not least of which are upgraded tyres and wheels. Any of these will contribute to how the car behaves and feels. Some of these technical issues are better covered in an earlier post here http://forums.nasioc.com/forums/show...ghlight=KCA313 .
We will be standing by to deal with any further questions or concerns, let us know what we can do to help.
Best
Whiteline Jim
www.whiteline.com.au
WL Flatout is offline   Reply With Quote
Old 10-06-2008, 07:41 PM   #66
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I was just refering to this post and stating that I am going to go and see if my car shows any evidence of this:
Originally Posted by MasterKwan View Post
I've had the ball joints walk out of their pockets in the knuckles too. Not enough to pop out but, enough to notice and fix.
The only problem that I have noticed thusfar is that the dust boot on my driver's-side ball joint is torn and leaking grease.
-- Dave
Old 10-06-2008, 07:43 PM   #67
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
^^ Nothing like whiteline customer service!
gr8r rex is offline   Reply With Quote
Old 10-06-2008, 08:38 PM   #68
04furesterXT
Member#: 73223
2009 STI
I bought a set a few months ago which I haven't installed yet. How would I know if mine are updated or not?
04furesterXT is offline   Reply With Quote
Old 10-06-2008, 10:47 PM   #69
DuckStu
Member#: 124060
2004 WRX STI
DuckStu, though we’ve .......... the product. As for swaybar surface finish, I understand your frustrat.............
Whiteline Jim
Email sent,..but it was someone else with Swaybar finnish issues. My 2 bars are just fine, so far as I know.
Regards, Stuart.
Old 10-06-2008, 11:42 PM   #70
TreyV
Member#: 4027
2006 STI
SGM
nm, sorry
TreyV is offline   Reply With Quote
Old 10-07-2008, 12:07 AM   #71
MasterKwan
Member#: 98961
2003 WRX
WL Flatout, you seem to have ignored the issue with the balljoints walking out of the pockets in the knuckles that pretty much started this discussion. It's not a wear issue. My knuckles were brand new. Dunk's gone through at least 2 sets of knuckles.
As far as I can tell, both, the tie rods and balljoints are still in good shape. I just can't risk them popping out at 130 mph. I took the car to Mach-V for an alignment, they saw what I saw. Balljoints backed out of the knuckle. My stock balljoints don't do it.
Any comment?
Old 10-07-2008, 12:34 AM   #72
CPC
Member#: 123085
2006 WRX
x2 ^^.
I'm quite suprised to hear you say "this is the first time we’ve heard about repeated issues like that in such quick time." I'm a Whiteline customer, not a workshop manager, and certainly not a WL employee, yet I've heard plenty about this problem. Why haven't you?
Chris.
Old 10-07-2008, 08:50 AM   #73
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
x3^^^^
FWIW, my car is a modestly lowered car - right in the sweet spot of Whiteline's design guidelines, and is NOT track-driven. My ball joints started walking/rocking out of the knuckles within weeks of installation.
The other issue of concern is all the reports I've seen (and my own experience) with ripped grease boots. Both my tie rod ends have been replaced, so a big thumbs up for standing behind the product - but it's not something I want to have to do on a bi-annual basis.
_Jeff
Portly is offline   Reply With Quote
Old 10-07-2008, 02:29 PM   #74
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
Hmmm, I haven't had any issues yet with my RCA kit although its only been on the car for about 7-8 months, 2 track events, and roughly 6k miles. I'll get under the car and take a closer inspection but everything seems the same as day one.
kunfuzion is offline   Reply With Quote
Old 10-08-2008, 03:39 AM   #75
WL Flatout
Member#: 35326
Hi everyone,
Thanks for all the feedback, both good and bad. In light of the latest comments and the difficulties people are experiencing we think it best that we ask you to return the stock of the latest batch of KCA313 kits while we sort out what’s what.
MasterKwan and CPC, I understand that this may be hard to accept but this is the first time that we have seen this detail about the ball joint moving in the hub. Naturally this is of some concern and we need to investigate this more but would prefer that we get this particular batch back to check. It looks like a running change has identified the latest batch and I have attached a photo showing the difference.
It seems to be restricted to kits supplied ex our factory after June off this year and the suspect ball joints can be identified by:
- Dull silver/gold finish vs bright gold.
- Silver wire clamps for the boots vs blue wire
- Code “WL 65079” vs “65079 D7” marked on the bottom of the ball joint. (Top once fitted)
Further detail available by downloading http://www.whitelineautomotive.com/B...313_return.pdf from our FTP site.
I can only imagine how frustrating this must be for our customers and I sincerely apologise for the inconvenience and trouble this might cause. We have no excuse and ask that you persevere with us if you can while we resolve this. Unfortunately we do not have a direct replacement batch to offer you in exchange so would like to do what we can to help you fit replacement stock units until we can deliver a replacement.
Can anyone affected please contact jim@whiteline.com.au directly so we can sort out an action plan for you. This will include logging you down for a direct replacement set to be shipped ex Australia via courier once available at our expense. Alternatively, we understand if you would like to return the kit for credit and will help where needed. Either way, we would like to arrange for the return of the stock you have via your nearest distributor.
Again, our sincere apologies for the trouble, we thank you once again for your patience and we will keep you posted once we know more.
Best regards
Whiteline Jim
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Suspension/Brakes/Handling 4 12-03-2009 09:34 AM
FS: Whiteline Roll Center Adjustment kit - KCA 313 UM-WRXer Tri-State Area Private Classifieds 3 12-03-2009 09:34 AM
Brand new in Box - Whiteline Roll-Center Adjusting Kit & Kartboy Pitch Stop Mount! CALIBAN Suspension/Brakes/Handling 6 03-06-2009 05:33 PM
fs: 169 BRAND NEW Whiteline Roll Center adjuster kit fastwrx25 Suspension/Brakes/Handling 3 07-29-2007 03:53 PM
