Old 09-25-2008, 06:34 PM   #1
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Default VF34'd 05 WRX 260whp/260wtq?
I just got my car tuned and dyno'd today on a Dynpack. These #s seem kind of low for my setup, PnP'd VF34, STi Pink Injectors, Walboro 255lph fuel pump, Catless Invidia TBE, Catless Invidia DP, Catless Helix Flex Upipe, #' Ebay Inlet, and this was all on 20psi. Though I must say the car pulls pretty hard and the curve is real nice and smooth. My car is holding boost very nicely.
ismegamanthere is offline   Reply With Quote
Old 09-25-2008, 07:05 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
ehhh, dynapak is the one where they take your wheels and tires off? which should result in higher numbers right? i mean it is what it is, but could be seen as low.
godforbid67 is offline   Reply With Quote
Old 09-25-2008, 07:05 PM   #3
Member#: 189490
I would expect a little bit more. What did your tuner have to say? How much did you gain compared to the base line? What engine management do you have? What type of boost controller? Just so I can have a better understanding of your setup.
Thanks, Artie
Artie@Agile Auto is offline   Reply With Quote
Old 09-25-2008, 07:40 PM   #4
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Thanks, Artie
He told me that the STi TMIC isn't that great for a 2.0 liter and to get a different top mount. I actually left the charts in my car and I'm headed to a review for one of my classes but when I get back I'll post the exact stats. He had to use an MBC because of the stock re stricter pill and I did an open source tune.
Old 09-25-2008, 08:01 PM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
ismegamanthere likes boys..
on a serious note, it's probably cause you were heatsoaked
Jubert69 is offline   Reply With Quote
Old 09-25-2008, 10:24 PM   #6
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Snape, forgot about that. I don't have the STi Scoop or air splitter. I did just remember that the guy who owns the shop told me his dyno does run lower than other dynos.
Old 09-25-2008, 10:44 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
so an STi intercooler isnt good for a turbo that comes on 2L sti's Its only not good if your tuner was trying to run too much boost and the turbo was at a bad spot on the compressor map, but most of the time the vf's wont hold boost above 5500 rpm anyway. If you go back you can have him try reducing the boost at high rpm and running more timing.
if he was on a dyno with fans blowing heatsoak shouldnt have been an issue....unless they were running the car with the hood closed and no fans, which in no way simulates driving
Old 09-25-2008, 10:45 PM   #8
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Yeah, I was caught off guard by the STi TMIC comment...
Old 09-25-2008, 10:55 PM   #9
RexTexWagon
Member#: 150987
2013 Ford Focus ST3
Try going with a bigger TMIC. Pick one up used and go at it. But yea, dont expect to be breaking 275-300hp...lucky if you get that much torque.
RexTexWagon is offline   Reply With Quote
Old 09-25-2008, 10:56 PM   #10
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
I would have to disagree on the STi TMIC comment as well, That seems pretty low on power. Here is a car I tuned on a mustang dyno, 285.4whp, 283.2wtq (with an STi TMIC) http://forums.nasioc.com/forums/show....php?t=1542610 . I would expect somewhere around the 300's for WHP on a dynapack easy considering how high they read.
Benchmark Tuning is offline   Reply With Quote
Old 09-25-2008, 11:40 PM   #11
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Damn, hmmm... wtf is it then? Possible that my parts just aren't meshing well for some reason.
Old 09-25-2008, 11:51 PM   #12
Benchmark Tuning
Member#: 154444
could honestly be quite a few things, I wouldn't be able to tell you much w/o some sort of logs, or more even so a car in front of me to see if there is something mechanical issue.
There are many things to look for, PM me we can discuss more
04-05 WRX/STi Zerosports CF Grill nightcrawler60 Private 'Wanted' Classifieds 2 08-29-2010 08:29 AM
MD WTB: 05 WRX Front Brakes, 05 WRX Seats or STi Seats, 05 Front Seatbelt Recievers LeeC Private 'Wanted' Classifieds 13 05-23-2010 11:48 AM
05 STI TMIC, 05 WRX TMIC, Sti Catless uppipe, 05 wrx manifolds, BCS, FP, posite Engine/Power/Exhaust 28 06-06-2009 01:15 AM
My VF34'd 04 WRX dyno numbers Chino Bling Proven Power Bragging 38 06-23-2008 12:04 PM
stock turbo WRX 265whp 260wtq adding vf39 any advice? mitchwrx Proven Power Bragging 72 01-30-2006 12:05 AM
