Old 09-26-2008, 03:07 AM   #1
RallyColtTurbo
Member#: 16819
Default '05 LGT engine harness is the same as..?
I'm working on a building a car around a Subaru drivetrain. I've aquired a complete '05 Legacy GT harness, minus the engine/intake manifold harness. I've got the key, steering column, ECU and anti-theft box to make it run. As I understand it, the '05 ECU is open source flashable.
I know this is a CANBUS system. But if I use the harness mostly complete that shouldn't pose a problem. I planned on using most of the Legacy dash and instruments in my project anyways.
What I can't seem to find out is if there are any other cars/engines that I can source the missing engine loom from. Finding '05+ wiring diagrams is not easy. I know that the FXT, Baja Turbo, '06/7 WRX, and STIs are not CANBUS, but are the engine/intake harnesses compatable with the '05 Legacy vehicle harness? Maybe with a bit of re-pinning?
I do not have an engine yet as I'm hoping to get the needed wiring with the motor I choose.
Edit: Just found some Vacation Pics over @ LegacyGT.com.
Last edited by RallyColtTurbo; 09-26-2008 at 03:08 AM. Reason: searched some more.
RallyColtTurbo is offline   Reply With Quote
Old 09-26-2008, 11:42 AM   #2
ejoy1220
Member#: 157762
2002 WRX wagon
Aren't only the 07/08 LGTs CANBUS?
ejoy1220 is offline   Reply With Quote
Old 09-26-2008, 04:44 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if it were me i would be searching for 04 fxt/04 sti harness the can bus ecu is WAY WAY more trouble than you want
Old 09-26-2008, 07:17 PM   #4
RallyColtTurbo
Member#: 16819
I would normally agree with you, but I'm not trying to merge or integrate anything with this Legacy harness. The car is a complete blank slate. Everything in this harness will still be doing it's original function. Used in such a fashion I can't really see how just the fact that it's CANBUS makes it too much difference. I realize that there may be a few things to work out when dealing with the ABS, traction control, instument cluster, etc. But I still feel that if I keep as much as possible installed and connected, what's to go wrong? Theroretically, the "harness" won't even know it's been removed from the car.
Another concern is the fact that asking prices on non-CANBUS harness are highly inflated. Or maybe I'm just looking in the wrong places.
The Vacation pictures seem to have provided some of the diagrams I need. I'll be comparing pinouts tonight, hopefully.
Old 09-26-2008, 07:42 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
thing is car won't run right with out the cluster or abs ...
imobilizer talks to the cluster (probably so that it can't be swapped)
vss comes from the ABS-> no abs signal ->limp mode
its not so much the can bus, but the calls across the bus that are the problem
Old 09-27-2008, 03:09 PM   #6
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
05+ are CANBUS
The engine harness will have to be off the same car. I have the simular issue of my 05 EZ30R swap. Just get the LGT cluster and fit it in the Impreza dash. That's what I'm doing. When I got mine in I sat in a freind's WRX to check the line up. Line up nicely. Other thing is the AC control and radio will need to be the Legacy one and as long as from that peice down you have an 04+ full dash set up it should fit. Here's a pic of mine peices. 05 LGT AC/radio controls and bezel + 07 STi lower peice.
Good luck. Oh and where and howmuch did you source the harness and key and imobilizer stuff for?
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 09-28-2008, 04:33 PM   #7
RallyColtTurbo
Member#: 16819
Originally Posted by Seraphinwolf View Post
.......The engine harness will have to be off the same car.........
Why? I can't find anything immobilizer related on the engine harness.
Any non-CANBUS manifold harness is out (as suspected) without major re-pinning and sensor swaps.
Anybody have a link to '08 Impreza/WRX/STI or '08 Forrester wiring diagrams? If I don't dig something up by the time I get the harness stripped down and organized, I guess I'll just get the Subaru TechDocs subscription.
-Gaddis
I got it from a parted out '05 LGT 5-speed for $200. Was supposed to get the cluster, but wasn't in the box when recieved. My research indicates that the dealer can re-flash any 'immobilizer' cluster to work with the ECU/key. (I realize that "can" and "will" are not the same thing)
What Year Forester engine is the same as a 05 LGT? el_pincho Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-10-2010 02:54 PM
apparently my wrx is the same as a ralliart lancer?!?!? NiFFa General Community 77 04-22-2009 09:58 AM
Anyone know if the JDM WRX interior is the same as the 04+ interior? Butt Dyno Interior & Exterior Modification 3 03-23-2004 11:34 PM
anyone know if US spec susp is the same as Europe scotto Brakes, Steering & Suspension 1 10-07-2001 04:36 PM
Does anyone know whether or not the brakes from the '99RS is the same as the '00's? GTBGUY Technical Forum Archive 2 08-23-2000 09:00 AM
