Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Old 03-18-2002, 12:40 AM   #1
scaryfastskier
Member#: 7893
1979 GS550 puttputt
2000 Lexus Landcruiser
View Member's Myspace Profile
Default New battery
Here is the story: I hate my battery. It sucks in cold weather and when I go on long trips and leave the car unused. (week+). Would getting a new battery make my car run better and get rid of those problems? If so, what is a super fly battery that will not bust the bank?
thanks,
grant
scaryfastskier is offline   Reply With Quote
Old 03-18-2002, 01:45 AM   #2
illmatic
Member#: 3536
2002 Impreza WRX
A bit of E85
Are you talking about the stock battery? try a dyna batt, its only 13.5 lbs compared to the 40lbs stocker. http://www.performancedistributors.com/batteries.htm
Lighten up your street rod or race car! Remove the 40 lb battery and replace it with Performance Distributors 13.5 lb Dyna-Batt. The Dyna-Batt is built with extremely low internal resistance which leads to faster, more consistant starting. The Dyna-Batt is completely dry cell and can withstand the rigors of high performance and racing enviornments. It is built with corrosion resistant terminals and is truly maintenance free. The Dyna Batt has an excellent storage life and recharges very quickly. Works great with one of our alternators!
illmatic is offline   Reply With Quote
Old 03-18-2002, 01:51 AM   #3
scaryfastskier
Member#: 7893
1979 GS550 puttputt
Default Battery
Thanks for the quick reply....Yes to replace the stock battery. I don't really care about saving weight at this point, but would definetly buy the dynabat(man) battery if it was a better performer and cost efficent. Any users or know-it-alls care to comment?
thanks,
grant
Old 03-18-2002, 04:46 AM   #4
mitch808
Member#: 10228
2002 Subaru WRX
Hold on there, the Dyna-batt is not good in cold weather situations.... You may want to think of something else.
mitch808 is offline   Reply With Quote
Old 03-18-2002, 11:01 AM   #5
6Pack
Member#: 13901
2002 WRX Sedan
If you're looking for something that won't bust the bank, I'd check into Sears Die Hard Gold. It has the cold cranking amps you need, not going to be as strong for audio as the Optima's, but they're a lot more expensive too.
6Pack is offline   Reply With Quote
Old 03-18-2002, 11:21 AM   #6
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Dynabatt is NOT a solution if cold weather is an issue. Die Hard as mentioned above is GREAT solution. I have a Dynabatt in my WRX (but I only drive in warm weather) so its not an issue. However in my contour, Die Hard has never failed me. We've had a few 0 degree nights and it turns over like a dream.
If cold start is the issue...die hard is the answer.
JenisonWRX is offline   Reply With Quote
Old 03-18-2002, 04:38 PM   #7
scaryfastskier
Member#: 7893
1979 GS550 puttputt
Talking
Thanks! Looks like I will be heading over to the local sears for a diehard instead of to the dynabat-cave or whereever they are sold. Cold starts are a huge issue here in MN. It's cold as balls when I have to park outside for work.
thanks for the advice,
grant
Old 03-18-2002, 05:13 PM   #8
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Die Hard Gold is a great battery. My other car has a DHG and was off for almost 3 months with the little alarm blinky going.. I walked out a week or so ago and started it up no problem. Best battery ive ever had.
Evaider is offline   Reply With Quote
Old 03-19-2002, 09:50 AM   #9
7nth_Son
Member#: 13749
Default Miata battery?
Has anyone here tried a Miata battery? It is definitely lighter than our stock battery, and probably more powerful than the Dyna-Batt. I think Westco makes one for about $80.
7nth_Son is offline   Reply With Quote
Old 03-19-2002, 10:19 AM   #10
BYBYV8
Member#: 13103
2002 WRX on N20
12.24@112
Energizer... I love the bunny
BYBYV8 is offline   Reply With Quote
Old 03-19-2002, 05:20 PM   #11
mattrudella
Member#: 11594
I put an Exide Optima battery my car, the stock battery did not have sufficient CCA. I'm not sure about the weight differences (not a concern of mine), but the Exide battery works like a dream and the cost was $100.00 with a 3 year replacement. The battery also has 2 sets of terminals in case I add a stereo.
Matt
mattrudella is offline   Reply With Quote
Old 02-15-2003, 10:55 PM   #12
Coati
Member#: 9106
2002 WRX Wagon - PSM
2008 STI - Aspen White
I got a westco miata battery to replace my stock one. I was mostly concerned about leaking batteries (this is because my last car was a Corrado, and, for instance, a leaking battery in one = holes in your plastic intercooler tubes = no boost ) and their general causing of much grief.
The westco arrived quickly, and weighed 24 pounds on my digital bathroom scale. So I popped it in the car. It fits with very little trouble, all I did was reverse the square-ended bolt and nut holding the positive cable so that it would sit right with the red rubber cover over the top.
Then I took the stock battery and weighed it on the same scale.
30 pounds.
No the battery's fluid was not low - I checked and it was within the recommended levels and had just been checked at 30,000 miles a couple weeks ago.
So this is not the world's most cost effective way to save weight over a stock battery, but the fact that it is sealed does give some peace of mind, and it doesn't add 8 pounds to your front end like an Optima.
Coati is offline   Reply With Quote
Old 02-16-2003, 01:18 AM   #13
hotrod
Member#: 14141
2002 Impreza WRX
WRB on E85
Default Take a look at Walmart
As silly as it may sound one of the best deals in town are the batteries at Walmart. They are made by the major manufactures, and just rebranded.
If you shop by CCA on the battery and get the biggest CCA value you can for you dollar you won't have any cold weather problems.
Larry
hotrod is offline   Reply With Quote
Old 02-16-2003, 10:29 AM   #14
ScreaminFast
Member#: 24399
2003 A. White WRX
2006 Yamaha "Raven" R6
Are there any batteries that offer high CCA, but are still lightweight batteries? I've seen some racing batteries out there, but alot of them seem to have to have some modification to work in a street car.
ScreaminFast is offline   Reply With Quote
Old 02-16-2003, 02:41 PM   #15
hotrod
Member#: 14141
2002 Impreza WRX
WRB on E85
Default CCA and plate area
Yes some batteries are lighter for their CCA rating, they increase CCA by increasing the plate area in the battery. It is a tradeoff. Thinner plates are a little more fragil, but the larger surface area per pound of lead will flow more current in cold weather.
There are also several different internal constructions of batteries etc.
In warm weather you can start and run a car on only about 1/2 the battery that comes stock in the WRX, but as soon as it gets cold your screwed.
The Dyna bat which is a relabled Hawker battery at 2x the price is only an 16 AH battery.
http://www.hepi.com/documents/ibdsp014.pdf
The stock battery in the MT WRX, is a 31 lb, 48 AH battery, with CCA of 356. A top end battery will have CCA values of about 500.
The optima red top is a 55 AH battery with 750 CCA and weighs 38.8 lbs.
As a rule of thumb there are two things I look for in a battery. If your trying to decide between two batteries that cost about the same, choose the heavier battery and the battery with the largest CCA value. This is assuming you want reliable cold starting. The Optima battery is unique in that it has a totally different construction than most car batteries. They are the cadillac battery if you can afford one.
The light weight racing batteries are fragile in that they don't like high temperatures. If you run one on a daily basis in hot weather they will only live about 3/4 of a year from what we saw posted last year from folks in Texas. The Dynabat removes the label, if you look at the Hawker documentation you'll see that that voids the warrantee on the battery, as it allows the battery to dry out.
Larry
Old 02-16-2003, 04:25 PM   #16
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Exclamation
Dont use a Miata battery!I had a Miata ,I know.It had barely enough power to turn over the enemic 1.8. and if it was parked for more than a week the battery would die.
I`m using this in my WRX.Its a Pro-Volt 1100CCA ,2hr reserve capacity and AGM design(no acid sloshing around).It has a free full 2yr replacement and its deep cycle capable.Its small and light and the cables fit no problem.The Optima is also a very good battery.
http://store.summitracing.com/defaul...%3D11%26s%3D13
Camperguy is offline   Reply With Quote
Old 02-16-2003, 06:47 PM   #17
tdxflex
Member#: 13634
optima's aren't really expensive at all. costco sells the red tops for $105 i'm almost positive. really not bad considering what you're getting.
tdxflex is offline   Reply With Quote
Old 02-16-2003, 08:35 PM   #18
Coati
Member#: 9106
Thumbs up Good info!
When I say "miata battery" I dont mean one that came stock in a Miata. I'm talking about this one from Westco.
Westco "miata" www.westcobattery.com/miata.html
AH 31
CCA 475
25 lbs (24 on my scale)
sealed, glass mat
$85 shipped
fits
Stock MT WRX courtesy of hotrod:
AH 48
CCA 356
31 lb (30 on my scale)
not sealed
$? (free to start with)
fits
The Optima red top
AH 55
750 CCA
38.8 lbs.
sealed, glass mat
$105 at Costco?
longer cables help
Pro-Volt http://store.summitracing.com/produc...3957&view=2047
AH 50 (from online review)
1100 CCA
33 lb (again from online review)
sealed, glass mat
$120
per camperguy, fits with no problem
Hawker/Dynabat per http://www.performancedistributors.com/batteries.htm
AH 16
?? CCA (apparently "not rated")
13.5 lbs
dry cell (sealed, glass mat?)
$132
Baker Battery (two models)
http://www.bakerprecision.com/battery.htm
Model: 125 / PB19
AH 19
CCA 390
Weight 15lbs
$90.00
"epoxy sealed, gel-filled"
Model: 125 / PB34
AH 34
CCA 500
Weight 23
$95.00
Edit: edited to add Baker battery.
Old 02-16-2003, 10:55 PM   #19
Camperguy
Member#: 21274
2002 Mc_Bains car
Question Optima orange fit?
I`m just curios ,does the Optima orange fit our WRX`s.I thought reading somewhere that these are made for the foreign car market(tops +&- are reveresed on top) so you dont have to change out the cables
The Pro-Volt is a AGM type battery Ie Absorbed Glass Matt,just like the Optima though the Optima uses spiral wound plates instead of flat plates.It doesnt have liquid per-say.Sealed I think is just a acid filled without refill caps and some type of pressure relief/vapor return vent though anything that doesnt leak is sealed also I think?
Bill
Old 02-16-2003, 11:11 PM   #20
tdxflex
Member#: 13634
forgot which ones fit, mulder knows a lot about optima batteries. the problem is with extending the wires. the optima redtops that i've seen are the group 35 and group 34. the 35 i think is 720cca, the 34 is 800cca. or else it's the other way around i'm going to relocate my battery in the trunk, and i'm leaning towards a stinger power2 800, 800cca, 24.9lbs. it's an odd shape, not sure if it will fit under the hood without some modification.
Old 02-16-2003, 11:21 PM   #21
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO
You rang?
I haven't actually seen an Orange-top so I don't know for sure if it fits any better than a Red or Yellow. I do know that the Orange is only available in 34 not 35. I went with the Red-top 35 because it's closer in size (actually not as high) and weight to the stock battery so an easy fit in the tray, yet has more than enough capacity- 720 CCA, 910 CA. I did change the starter cable but it was not a big deal. There are a few threads about it which you can find by searching around.
Old 02-16-2003, 11:29 PM   #22
tdxflex
Member#: 13634
wow, that was quick mulder
Old 02-17-2003, 12:11 AM   #23
TheRedWRX
Member#: 32918
2002 Subaru WRX
Sedona Red
Haven't changed my battery in my wrx yet, but I've been very pleased with Day Starters. I had them in my last car and they are amazing batteries! Alittle bit more expensive....but they sure are worth it. Lasted much longer than the stock battery!
TheRedWRX is offline   Reply With Quote
Old 02-17-2003, 01:28 AM   #24
Coati
Member#: 9106
Default Re: Optima orange fit?
Okay, in the batteries where I put "sealed" they are all glass mat. From Westco's site:
Introducing the brand new Westco sealed battery - A radically different, second generation sealed battery for your Mazda Miata, Utilizing the very latest absorbed glass mat technology, this advanced battery has no free liquid electrolyte - unlike the current factory "flooded" battery.
This would appear to be basically the same thing as the Optima and the Pro-Volt?
I'll edit the summary to say "sealed, glass mat" for each to make it clearer.
Old 02-17-2003, 01:47 AM   #25
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
So where can you buy this "miata" battery?
drees is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:43 PM.
