Old 09-27-2008, 10:47 AM   #1
xtian
Member#: 93248
95 20g powered gc8
PPG'd yO! & is250 AWD
Impreza GC8 what to expect? 95 impreza "L" 20g'd 06 wrx swap
ok, my car is scheduled to be tuned on thrusday (jorge from P&L aka riftswrx) and i was wondering what to expect in terms of numbers(realistic). ive tried searching on here but it seems like i cant really find a setup close to mine. track time estimations are also welcome. theres alot of tuning "gurus" in this subforum and would like to see them chime in and what i can look forward to and your guys are welcome to critizes my setup also.
heres some pics of the setup for ref.
specs/mods:
06 2.5 wrx motor (stock)
cobb AP v2
sbr td06-20g (8cm housing - ported, polished,coated)
perrin "big maf" intake
grimmspeed ewg setup w/ dump tube (wrapped)
tial 38mm wg
DW 850cc injectors
walbro fuel pump
fmic (wrapped hot side)
NGK copper plugs
GM boost solenoid
Koyo aluminum racing radiator
trans:
04 sti 6mt
spec stage 2 6mt clutch kit
the car is fully gutted with one Sparco "EVO" seat. it has no dash with just the dash bar and gauges mounted on it.
let me know what you guys think.. i just want to see people's ideas and expectations when they see such setup. (hp/tq wise and track times)
*i will be back to update this thread once the final result is out! dyno sheet and such...
thanks in advanced
--christian
xtian is offline   Reply With Quote
Old 09-27-2008, 04:50 PM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
360-380whp on 93 octane
420-440whp on c16
11's on street tires (maybe 10's depends on how much your car weighs....)
10's on slicks
Old 09-27-2008, 05:05 PM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
i know this isn't member's car gallery but...from the outside your car is awesome! i'm not so sure about the interior
good luck with the tune
Old 09-27-2008, 05:15 PM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
370whp pump running mid 12s
400whp on "race" running low 12s.
Weight, 2700ish.
DoctorNick is offline   Reply With Quote
Old 09-27-2008, 05:24 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ You should read this and reconsisder the 12's
2.5L, 18g, 2850 lb wrx, it does have ppg's though
10.80 @ 128.18 Back For Some More !!!!!!!!!!
Old 09-27-2008, 05:31 PM   #6
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Look at our locations. I KNOW the driver and how the tuner is going to tune this guys car...
He'll trap 115+ but I doubt he'll ET it. (I too owned a 94L sti swapped wagon with a green too)
Old 09-27-2008, 07:01 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
How much did it weigh after the swap? Was your wagon gutted too? You had 100-200 lbs on him for being a wagon, plus if yours wasnt gutted.....
Your wagon seems like it was either pretty close to 3000-3200 lbs, had a semi conservative tune, or your track conditions and/or altitude/weather produce DA's of 3000-5000 ft.
If your track is a little slower, the tune a little conservative, and not gonna run slicks then those traps/ets will go up....
maybe high 11's on pump 11.3-11.6 on c16. really just depends on how much the car weighs. the dyno numbers are gonna be 20g dyno numbers, the trap however will depend on the weight
based on your results and comments this 20g car should be easily into the 11's on race gas.....
im really wishing i got the ppg's for my wrx instead of the 6 spd...
Old 09-27-2008, 07:57 PM   #8
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Weight, 2700ish.
LOL, no. He'll get mid 12s on pump gas if he's a the worst driver ever. His car is most definitely capable of hitting the 11s on pump gas with the setup he has going.
ismegamanthere is offline   Reply With Quote
Old 09-27-2008, 09:13 PM   #9
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
I have to definatly agree. I can run a mid 12 with only 296whp on Jorges dyno. And if I ever got to properly run my race gas map i know I could get a low 12.
Dirtyhobo010 is offline   Reply With Quote
Old 09-28-2008, 02:04 AM   #10
kalescustom
Member#: 147598
95 Impreza 2dr
i have a similar setup.. with the 20g he should be mid 11's on race fuel.. i ran an 11.8 with a vf34..
kalescustom is offline   Reply With Quote
Old 09-28-2008, 12:04 PM   #11
xtian
Member#: 93248
95 20g powered gc8
OMGHi2U
wow....i guess i was setting my HP goals pretty low i was just hoping a little over 300awhp and id be happy.
the car is pretty gutted.. but i do have a 6mt and a 2.5. ill go visit the nearest truck stop here in chicago and weigh it with and without me in it. ill come back with numbers.
i guess as long as i hit 12's with this car (mid-high) id be happy. i didnt really build her to be a drag car..i want it to do everything ..(auto-x, track, strip,street etc)
thanks for the input. id like to see people with similar setups on 93oc though. so input away!
Old 09-28-2008, 12:12 PM   #12
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
I ran 12.1 with 311whp(mustang dyno) in my RS with a weight of 2800lbs. So I would expect your car to run 11s with a good driver.
RFoy91TSi is offline   Reply With Quote
Old 09-28-2008, 12:14 PM   #13
xtian
Member#: 93248
95 20g powered gc8
yeah and you are my hero.. i loved your RS.. did u sell it?
Old 09-28-2008, 12:18 PM   #14
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Dude, if you have ANY shred of driving in you you'll be in the 11's. Trust.
Old 09-28-2008, 12:20 PM   #15
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
Not yet. I won't let it go for less than what I want.
But yea man with some halfway decent driving you should be able to hit 11s
Old 09-28-2008, 12:22 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm a 95 +ej255+6 speed - interior
i would guess 2575-2675lbs may be less not sure how much more a 6 speed weighs vs a 5
Old 09-28-2008, 12:31 PM   #17
xtian
Member#: 93248
95 20g powered gc8
i believe its a 100 lbs more.. not sure though..
Old 09-28-2008, 01:13 PM   #18
BrianH
Bing user
Member#: 44383
Just since it's you, 14.7
BrianH is offline   Reply With Quote
Old 09-28-2008, 01:39 PM   #19
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
I think you should put your dash back in. It looks terrible and really how much weight are you saving. If your that hard up to lose weight a diet might suffice.
Other than that Awesome car all the way.
wrxwagon253 is offline   Reply With Quote
Old 09-28-2008, 02:09 PM   #20
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
i don't think that he has a dash.
slava from goshen is offline   Reply With Quote
Old 09-28-2008, 02:12 PM   #21
CSCSATCWRX
Member#: 140032
06 vf43 wrx R.I.P.
09 forester 2.5x
...So jealous. Mid 11's should be attainable.
Subscribed.
CSCSATCWRX is offline   Reply With Quote
Old 09-28-2008, 04:07 PM   #22
xtian
Member#: 93248
95 20g powered gc8
theres alot of reasons why my dash is off. 1st.. im running a full 06 wrx harness and nothing is merged. 2nd ..have you taken apart a dash? do you know how heavy everything is under there including the dash pad heater core, blower etc.? its about 100lbs or maybe more. 3rd.. to each his own. i honestly think it doesnt look horrible..its just that theres no dash... (i guess if you are into nice interior stuff w/ super jdm parts like a red hazard button then maybe..)
lastly, i didnt take the dash out to save weight. i kept it off because of the reasons above (wiring) so yeah...
Old 09-28-2008, 05:20 PM   #23
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
I say leave the dash out but make up some panels to make it like a race dash.(maybe lay some CF down or something.)
Old 09-28-2008, 05:26 PM   #24
xtian
Member#: 93248
95 20g powered gc8
yup.
Old 09-28-2008, 11:07 PM   #25
kalescustom
Member#: 147598
95 Impreza 2dr
on 93 oct you should be in the 11's... no problem.. and the dash itself from a wrx weighs like 3 lbs. with the airbag removed..
FS : (OR) 1995 Impreza coupe with 06 WRX Swap ret.sti Private Vehicle 'For Sale' Classifieds 20 04-10-2011 02:03 AM
FS : (OR) 1995 Impreza coupe with 06 WRX Swap ret.sti Private Vehicle 'For Sale' Classifieds 4 06-01-2010 02:08 PM
95 impreza coupe!!! MINT 04 WRX SWAP STi in ur face Private Vehicle 'For Sale' Classifieds 45 08-13-2007 01:35 AM
95 impreza L(4door) with 97 wrx swap including wrx tranny4500 Tam Ly Private Vehicle 'For Sale' Classifieds 0 12-04-2006 11:28 PM
95 Impreza L Wagon with WRX swap andrewp724 Private Vehicle 'For Sale' Classifieds 126 04-25-2006 02:44 PM
