Old 09-27-2008, 06:06 PM   #1
Old School Scooby
Member#: 64128
86 Lifted,
Lowered 96
Default ??'s on 96 impreza 2.2 to 98 2.5
so im putting a 98 legacy DOHC 2.5 into my 96 impreza outback with a single port 2.2.
ive read through ALOT of threads and it seems like i just need to swap the wiring harness from the 2.2 engine onto the 2.5 engine and thats it. and run the 2.2 ecu and i should be fine. i know the exhaust is different so i have a borla header waiting.
anything else i need please let me know. but i mainly need to know on the wiring if there is anything else i need to do to ge this to run. this will be done on my day off at my work (we have a lift and its a subaru wrecking yard so any parts i need i have) and it needs to be done in 1 day prefered, but 2 is ok if need be.
Thanks,
Shean
Old School Scooby is offline   Reply With Quote
Old 09-28-2008, 12:01 AM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
You don't even have to swap the engine wiring harness. The one on the 98 2.5 dohc will just plug in to the existing 96 bulkhead harness. It's just that easy.
Old 09-28-2008, 02:14 AM   #3
Old School Scooby
Member#: 64128
86 Lifted,
Lowered 96
dam its that easy? the 98 2.5 was a auto car so it has a EGR, so i should just keep my 96 2.2 ecu and it will be fine?
Old 09-28-2008, 10:28 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yeah it'll be fine. The egr will be there but just not do anything.
Old 09-28-2008, 11:42 AM   #5
Old School Scooby
Member#: 64128
86 Lifted,
Lowered 96
schweet thanks for the help
Old 10-02-2008, 01:50 AM   #6
oooo
Member#: 92367
1995 legacy
I am also curious. If he uses the 2.5 injectors, fuel rail, and manifold, would he need to use a 2.5 fuel pump or will the 2.2 fuel pump work. The reason I ask is I am doing a similar swap. I have a 97 2.2 impreza that im swapping in a 97 2.5. and want to use the whole 2.5 engine and just run that with my 2.2 ecu. Is the 2.2 fuel pump capable or should I just use the 2.2 injectors, manifold, and ecu? Sorry for the partial hijack
Thanks in advance
oooo is offline   Reply With Quote
Old 10-02-2008, 07:14 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
The stock pump will be sufficient. A WRX pump would be an upgrade, but not necessary at all.....
Jay
Old 10-02-2008, 08:55 AM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Thanks in advance
They both use the same pump and the same injectors.
Old 10-02-2008, 10:49 AM   #9
JJ's Red Wagon
Member#: 155937
1995 Impreza w/EJ255
Red
The ecu's are plug and play as well. I would used the appropriate ecu for the engine. You will get a higher redline and 100% proper mapping.
JJ's Red Wagon is offline   Reply With Quote
Old 10-02-2008, 12:02 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes they are somewhat. Just watch out for different emisisons setups. Some have the canister under the hood and some have the enhanced evap with the canister in the back and a few more sensors. Those don't interchange with out adding sensors and wiring.
2001 2.5 RS exhaust on 96 Impreza? snowmanchris02 Normally Aspirated Powertrain 3 10-31-2008 03:18 PM
95 2.2l to 98 2.5l legacy EastsideLegacy Legacy Forum 16 08-17-2008 02:34 AM
Anyone Done A 1997 2.2l To 98 2.5rs??? TurboCharged97L Subaru Conversions 6 09-03-2006 09:41 PM
Advice on 96 impreza wagon jbogli New England Impreza Club Forum -- NESIC 3 07-29-2005 08:11 AM
Can Kartboy Shifter Fit on 96 Impreza! scoopydo Normally Aspirated Powertrain 7 10-09-2001 01:01 AM
