Old 09-28-2008, 10:56 PM   #1
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Default turbxs tuned fpred+c16
went to turboxs this weekend and had my car tuned by jermaine who is just the magic man with the utec great guy. the car for some reason didn't make as much as i had expected , but it feels great and i am loving it. i think i may have picked up some bad gas for the 93 tune. here is a quick mod list, and maybe jermaine could throw up the dyno plot for me. jermaine check your inbox for pm, also just wanna say thanks for your patience saturday and for putting up with all my questions.
93 318whp can't remember torque 23psi
c16 424/369 30psi
the numbers seem low but it is a blast to drive now. i'm going to do a compression check tomorrow to see if that may be the problem, but last i checked it was good.
ej205
cp pistons (with overbore)
eagle rods
crower stg2 cams
crower springs and retainers
p&p heads
tgv delete
fpred 8cm
modded stock inj
turboxs tbe (with racepipe)
spec stg2 clutch
utec speed dentisy
1 step colder plugs
255 fuel pump
turboxs map sensor
txs fmic
arp studs
spoolinred is offline   Reply With Quote
Old 09-28-2008, 11:01 PM   #2
rallyrab
Member#: 145844
how much boost are u running?, also i hope you have a bigger fuel pump
rallyrab is offline   Reply With Quote
Old 09-28-2008, 11:15 PM   #3
r0n
Member#: 91839
hell yeah man... what psi on pump, and c16??
r0n is offline   Reply With Quote
Old 09-28-2008, 11:21 PM   #4
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
93 i think he told me was 23 and c-16 was 30. yeah i do have the 255 fuel pump...sorry forgot about that. for some reason timing was an issue... hey whats up ron hows the car?
Old 09-28-2008, 11:24 PM   #5
r0n
Member#: 91839
About to order gaskets and bolts this week, then off to the machine shop
Old 09-28-2008, 11:46 PM   #6
GeneralTJI
Member#: 152680
You put down 424 on a 205 block !? thats awesome and makes me feel better about the motor I'm slowing building right now!
Cool build!
GeneralTJI is offline   Reply With Quote
Old 09-28-2008, 11:59 PM   #7
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Cool build!
thanks man i just didn't want to do the same builds that everyone on here is doing. like i said we were having an issue with the timing, or the numbers would have been higher. he asked me if i wanted to take the boost up over 30, but we both thought that 30 was good for now...
Old 09-29-2008, 12:37 AM   #8
railguy
Member#: 53756
bump for this guy..... poor guy got bad gas on the way to the dyno........ he also has one of the coolest sisters to drive 8 hours in an untuned wrx! Im glad you made some power on race gas..... Did you get a chance to take it out with the race gas?
railguy is offline   Reply With Quote
Old 09-29-2008, 04:02 PM   #9
Digmaster
Member#: 183951
04 WRX Ej205
Built & Rotated 50trim
Nice setup and good #'s. Am almost finished with my rotated 205 build hopefully soon i'll be up there in numbers. gl with the timing issue
Digmaster is offline   Reply With Quote
Old 09-29-2008, 07:45 PM   #10
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
hey thanks man it was good to actually meet someone from the forums. yeah me and jermaine took it out on the street with the race gas and all i can say is WOW the hit was like a train.... the car is amazing fast on race fuel compared to what it was before, even the pump gas is crazy, it was fun on the way home.. i'm going to try to make it back and hopefully make some bigger numbers.
my sister said she was glad you could put up with her jabbering and she was glad she came...
Old 09-29-2008, 07:46 PM   #11
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
what turbo are you going to be using?
Old 09-29-2008, 08:45 PM   #12
Digmaster
Member#: 183951
04 WRX Ej205
t3/t4 50 trim with a .63 back housing at sea level and also running a little higher compression and fuel will be a mix of 93 with meth.
Old 09-29-2008, 08:48 PM   #13
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
Hope you enjoy it...
if its a timing issue, did you use a new oil pump during the build?
Just for reference those are respectable numbers... but mikaust with an 8cm Red put down 493 whp on TXS's dyno. This was a stock longblock EJ207. I'd think your built 205 with headwork would be on par with that.
Assuming the motor is healthy... and I hope it is... there could be more left in it for sure. Could be a sensor issue...
def
dug-e-fresh is offline   Reply With Quote
Old 09-29-2008, 10:49 PM   #14
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
def
thanks for the imput, just to let you know i have read alot of your posts and have learned a great deal from them, and applyed them to my build..
yes i did use a new oil pump also changed the oil day before i went up to have it tuned. i'm useing the txs tbe, the muffler is about 5yrs old this may have choked it up. was 493 with c16? i will check over all my sensors however nothing showed up on the scan tool....
Old 09-29-2008, 11:29 PM   #15
railguy
Member#: 53756
I would like know how high he reved that motor too?
Old 09-30-2008, 06:08 PM   #16
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
i think that he only revved it up to 7k, i told hime he could have went on up if needed...
Old 09-30-2008, 06:26 PM   #17
akaGeneyus
Member#: 127247
2015 Impreza
yeah i would think with cams at least 7500 could be achieved. id like jermaine to tune my stock ej205 sometime over the winter so this give me great hope!
akaGeneyus is offline   Reply With Quote
Old 09-30-2008, 07:42 PM   #18
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
the car would handle probably aroud 7800 maybe 8000, however 7 was enough to acheive our goals. i think i got my rev limiter set at 7200. i'm getting ready to install meth soon, well see how it runs then.
Old 09-30-2008, 10:28 PM   #19
railguy
Member#: 53756
pushing the envelope some more I see!
Old 09-30-2008, 10:47 PM   #20
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
yes sir. also going to go with the txs rfl muffler, think this will help out as well
Old 09-30-2008, 11:00 PM   #21
railguy
Member#: 53756
the rfl is a little loud try the wbr.
Old 09-30-2008, 11:54 PM   #22
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
What exhaust do you have now? When I switched, it made a huge difference. It is a lot louder than anything I have ever driven.
TAPOUT is offline   Reply With Quote
Old 10-01-2008, 12:00 AM   #23
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
Thats what I have on my car and it is nice and loud and mean sounding but if you have police issues I would not recommend getting the rfl-ti or you will probably get pulled over alot.
john 1badSTI is offline   Reply With Quote
Old 10-01-2008, 04:51 PM   #24
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
I'm still driving with my fingers crossed!!!
Old 10-01-2008, 06:47 PM   #25
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
The reason I ask about the oil pumps... there seems to be some cars who have had issues with oil pump/crank sensor combinations which limit max rpm and effect overall performance.
Glad to hear that I could help in the build We are both running eagle rods and cp pistons, lol!
def
05 STi...UR GT4088R Twin Scroll....Element Tuned...pump/c16 blowbyu24 Proven Power Bragging 142 04-11-2009 09:09 PM
trying to find someone to tune for c16? gt35r Rocky Mountains Impreza Club Forum -- RMIC 4 01-10-2008 09:04 PM
FPRed + C16 = 492 WHP stiIV Proven Power Bragging 17 06-24-2006 12:44 AM
C16 Tune Guidance xcntrk75 UTEC 4 06-21-2006 03:04 PM
