Old 09-28-2008, 10:06 PM   #1
WorstNameEver
Member#: 93156
All you see is
crime in the city.
Default Is it possible for a perfectly fine clutch to not grab during startup?
The Problem
So yesterday is when it all started, I drove 14 miles to a grocery store and got my items and left. The clutch was working fine no problems at all. Then I drove another 2 miles to pick up my grandma. I got to my destination picked her up and was ready to go. I went to start the car and nothing happened. I'm just guessing its a clutch problem because it sounds like how a car would start up if you didn't press down on the clutch where the seat belt light and all the other lights come on but the engine does nothing. I left it there for the night and went back in the morning to fix it. Upon arrival I went to start it up just to see what happens and it started first try.
Then today it happened again after a 9 mile drive from work to home. I stopped at a gas station to fill up and it would not start up. So I waited for 2 hours till it finally started up again.
I've been on the same clutch since July 4th of last year. During that time I had my flywheel resurfaced and a brand new exedy oem replacement clutch.
Anyone have any idea what the problem could be?
WorstNameEver is offline   Reply With Quote
Old 09-28-2008, 10:10 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This doesn't have anything to do with the clutch itself, just the starter cutout switch connected to the pedal. Sounds like for some reason the circuit isn't being completed, which could be from something as simple as the floor mat being caught under the pedal. Yes it happens.
Old 09-28-2008, 10:19 PM   #3
WorstNameEver
Member#: 93156
All you see is
crime in the city.
I should also mention once in a while when I try to start my car I get that noise the car makes when you keep turning the ignition after the car is on, that grinding type noise, would that be a circuit problem too?
Old 09-28-2008, 10:44 PM   #4
gling
Member#: 122654
2002 v8 STI w/ GT30R
2013 GTR & M-Sport 335xi
You might need a new battery(?); look into that.
gling is offline   Reply With Quote
Old 09-29-2008, 12:20 PM   #5
WorstNameEver
Member#: 93156
All you see is
crime in the city.
Any other suggestions? This is starting to become a really big problem, I am now sitting in my schools parking deck and it looks like this car isn't gonna be moving anytime soon. This car is a 95 L btw.
Old 09-29-2008, 12:25 PM   #6
novacivic
Member#: 117980
2005 sti
wr blue
you probably need a new starter
novacivic is offline   Reply With Quote
Old 09-29-2008, 01:16 PM   #7
SOHCEJ25
Member#: 135013
'17 WRX Hatch ; )
Or just starter contacts ... these have little brass contacts in the starter that wear , just have to pull the starter and replace them ....
SOHCEJ25 is offline   Reply With Quote
Old 09-29-2008, 01:29 PM   #8
gling
Member#: 122654
You could try push starting it too?
Is it possible for me to run two different auto-x classes in the same auto-x? Swine Motorsports 9 05-04-2005 01:13 PM
Is it Possible for uneven tires to mess up alignment? thetikler1 Tire & Wheel 4 01-11-2005 05:26 PM
Is it possible for a wrx to be FWD? PaulRex Transmission (AT/MT) & Driveline 1 12-15-2004 03:41 PM
Is it possible for an EGT gauge to be bad? Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-11-2004 08:42 PM
Is it possible for a down pipe to reduce EGTs? dandbest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-27-2002 04:10 PM
