09-29-2008, 02:33 PM | #1 |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
How I made my TMIC as Good as a FMIC
Maybe even better, if the FMICs pipe back to throttle is not insulated. I decided to make my own thread up instead of going into other's and expounding on it there. http://s18.photobucket.com/albums/b111/wrxdrvr/ There are three albums, wrxdrvr, ICmod, & info... Basically I insulated/isolated the IC from under hood heat, added a water sprayer, Tilted IC, and made airflow out of the engine bay easy-er so that air flow through the IC increased.
Stock TMIC set up; 59% efficient. New stock TMIC set up; 85% efficient. EDIT: This was on an '02 WRX.
09-29-2008, 02:43 PM | #2 |
Member#: 128269
Uh, how are you coming up with your efficiency ratings? And those fans look ridiculous, I'm sorry.
09-29-2008, 02:46 PM | #3 |
Member#: 174442
Vehicle:2007 SuperWagon I don't spell well |
wow, you went all out. But what happens to the fans when it rains?
09-29-2008, 02:51 PM | #4 |
Member#: 85905
Vehicle:2004 WRX |
I believe he has a temperature proble post IC so he can compare Intake Air Temp at the MAF vs Air Temp at the throttle body. Im still looking into fabricating some kind of sheet metal heat shield that will sit below the IC and hopefully block any radiating heat from soaking the IC so quickly. I wish you had more detailed pics of your setup.
09-29-2008, 02:52 PM | #5 |
Member#: 79222
W. Canada
09-29-2008, 02:52 PM | #6 |
Member#: 146606
BAIC
interesting...
09-29-2008, 02:52 PM | #7 |
Member#: 105814
NWIC
Sorry for the hijack, [email protected] on a stage 2 4EAT?
09-29-2008, 02:53 PM | #8 |
Member#: 79222
W. Canada
09-29-2008, 02:54 PM | #9 | |
Member#: 79222
W. Canada
09-29-2008, 02:54 PM | #10 |
Member#: 85905
Vehicle:2004 WRX |
Bump for some more detailed pics of the heat shield. Does it run under the IC or just block the turbo area?
09-29-2008, 03:01 PM | #11 | |
Member#: 79222
W. Canada
09-29-2008, 03:10 PM | #12 |
Member#: 185995
Vehicle:C5 Z06 |
Wow dude, that is seriously impressive (both the set-up and the track times). Hats off to you!
09-29-2008, 03:13 PM | #13 |
Member#: 56731
Vehicle:2004 STi, 00 Insight 10 Volvo C30R-d 11 F150 |
i wonder if it makes your drivetrain more efficient. It very well might with such a high change in efficiency. How much wattage does it take to run the fans
09-29-2008, 03:32 PM | #14 |
Member#: 186079
SWIC
Vehicle:2013 Impreza WRX STi Dark Grey Metallic |
Are you building a car or a computer?
09-29-2008, 03:49 PM | #15 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
All that work...and you couldve just bought a bigger TMIC and accomplished the same thing...
09-29-2008, 03:50 PM | #16 |
Member#: 126042
SWIC
Vehicle:2004 W Ŕ X PSM |
How many hp do you feel that you gain from the colder air vs. the hp you lose from running 5 fans? This is an honest question. I am not being sarcastic.
09-29-2008, 04:10 PM | #17 |
Member#: 79222
W. Canada
As far as the fans go, I don't think it makes much of a difference for drawing HP away from the engine through the alternator as they are just 12v 0.44A for two and 12v 0.20A for the other two. HP for my car is 225.9WHP figured out with a HP calculator using my 1/4 mile track time and speed/weight, is it as accurate as a dyno.? I would say yes, seeing as that's what most dyno's do, they just "calculate" the numbers they show too. I don't think any of this makes the drive-train any more efficient , just that the engine doesn't loose as much HP to hotter IAT than it would normally, tho I guess the engine IS part of the drive-train...
EDIT; Oh yes I could have bought a bigger TMIC or went to a FMIC but I still have the stock snail so I don't NEED one Just like most people don't NEED one... They just "think" they do. Last edited by wrxdrvr; 09-29-2008 at 04:19 PM. |
09-29-2008, 04:24 PM | #18 |
Member#: 49998
RMIC
Vehicle:2017 WRX MT6 WRB |
I'd suspect that those fans are worthless, particularly the one over the hole what used to vent air over the turbo. If anything that one is now a restriction to air flow.
I'd save money and time by using a high quality splitter, turbo blanket, and maybe some reflective heat wrap on the IC tubing. Well, mainly just step one. Then a good turbo heat shield. |
09-29-2008, 04:25 PM | #19 | |
Member#: 115154
09-29-2008, 04:30 PM | #20 | |
Member#: 56731
09-29-2008, 04:31 PM | #21 |
Member#: 99102
South East
Vehicle:17 BMW M2 Long Beach Blue 6MT |
could you imagine! stock sti tmic with this setup.... do it!
09-29-2008, 04:33 PM | #22 | |
Member#: 79222
W. Canada
As for the fans, when moving they probably don't help much but when parked or in traffic I'm sure they DO help and help a lot. |
09-29-2008, 04:47 PM | #23 | |
Member#: 115154
Good job on the execution, not sure if cutting multiple holes in your hood is such a bright idea however. |
09-29-2008, 05:15 PM | #24 | |
Member#: 79222
W. Canada
09-29-2008, 06:50 PM | #25 |
Member#: 44256
Vehicle:05 outback xt 02 wrx wagon - crushed :( |
I dont think this is the "simplest" of problems - I think heat soak is a big issue and I drive in stop and go traffic a lot.
I applaud your decision to try this out and the fact that you got results from it. Wow - lots of uneducated hate in here... In fact - if you research "intercooler" and "fan" you'll see that LOTS of people/manufacturers use fans on intercoolers... I actually plan on trying to find a slim mount puller fan to stick behind my tmic and to separate the tmic from the turbo with an insulated barrier... |
Is a bike ride as good as a walk? How long is a safe amount to ride? | Jm19 | Off-Topic | 18 | 07-19-2009 11:36 AM |
wish my car looked as good as brianchilds or Dmoney's! but im getting there. | evoklr101 | Member's Car Gallery | 71 | 02-21-2008 12:27 PM |
How I made my Momo shift knob screw on to my shift lever | Farnsrocket | Interior & Exterior Modification | 34 | 07-17-2006 10:14 PM |
Any good Honda forums as good as this one?? | Absubtle | Off-Topic | 10 | 06-17-2005 11:20 PM |
My brakes are as good as a Carrera's | TyrannoSullyRex | Texas Impreza Club Forum -- TXIC | 9 | 11-08-2002 10:32 AM |
