Old 09-29-2008, 05:41 PM   #1
travisatlarge
Member#: 173794
02 WRX Wagon
Default Help I can't get my new shifter into the socket!
I've tried to rubber mallet but I cant get this dang thing to seat into the socket. I'm trying to install a kartboy shifter and it's just not going in. Any suggestions?
travisatlarge is offline   Reply With Quote
Old 09-29-2008, 06:02 PM   #2
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
Take a really long screwdriver or something of ur liking , put it through the shifter lever hole... leverage it underneath the shifter console and push down. should pop right in
kevin85193 is offline   Reply With Quote
Old 09-29-2008, 06:05 PM   #3
dstnbmxvr6
Member#: 168106
2002 aspen white
20g8cm
push harder
dstnbmxvr6 is offline   Reply With Quote
Old 09-29-2008, 06:06 PM   #4
Russ45
Member#: 170237
Hey, don't be a
dick, bro..
The rubber mallet shouldn't hurt the threads. Don't be afraid to whack it pretty hard.
IBthatswhatshesaid
Russ45 is offline   Reply With Quote
Old 09-29-2008, 06:06 PM   #5
Russ45
Member#: 170237
Hey, don't be a
dick, bro..
Double post.
Old 09-29-2008, 06:10 PM   #6
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
take the socket out and install it on the SS out of the car. then put it all back in the car together.
pauli18c is offline   Reply With Quote
Old 09-29-2008, 06:11 PM   #7
Member#: 67
1999 Outlasting
the competition.
use a plastic dead blow. a rubber hammer will absorb most of the force.
T
Old 09-29-2008, 06:16 PM   #8
travisatlarge
Member#: 173794
02 WRX Wagon
thanks for the tips, how might one remove the socket if the plastic hammer doesn't work?
Old 09-29-2008, 06:29 PM   #9
Back Road Runner
Member#: 60082
2004 Forester STI
Rubber mallet.
You're thinking wrong.
Find a piece of wood and grab yourself a 10 lb maul. Put the wood on the stick to protect the threads and smack it with the maul. It'll go in like butter.
The key to this whole thing is having a high impact force. It'll take you a year to get that shifter to pop in with a low impact device like a rubber mallet.
Old 09-29-2008, 06:33 PM   #10
travisatlarge
Member#: 173794
02 WRX Wagon
ok so i won't hurt the tranny or anything if i hit it hard?
Old 09-29-2008, 06:47 PM   #11
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
there is a little "c" clip that holds it in. I am assuming you didn't take it out before you ripped your old shifter out. you should remove it before you wack it in any more
If you all ready did then wack it harder, but it should slide right in, then reinstll the c clip
medamullet is offline   Reply With Quote
Old 09-29-2008, 07:22 PM   #12
69subaru360
Member#: 159682
1995 WRX
2015 F150
The right way is to pull out the clip take out the bushing and re-assmble. The easy way is use a block of wood and a hammer. I use a block of wood and a big hammer.
Old 09-29-2008, 07:38 PM   #13
smurfwrx
Member#: 151928
09 Triumph S3
quit being a girl and nail the funky piss out of it one good time!
No, seriously. It needs a good wack, preferably with a plastic hammer. Like Tom said, the rubber just doesn't cut it.
smurfwrx is offline   Reply With Quote
Old 09-29-2008, 07:58 PM   #14
travisatlarge
Member#: 173794
02 WRX Wagon
ok guys I got it in finally. I drove to home depot a got a bright orange dead blow hammer and it only took two tries to get it in. Thanks for the input. On the more self deprecating side, while I my girlfriend was out I asked her to pick up a "plastic mallet" and she came home with a wiffle bat. No lie...
Old 09-30-2008, 08:30 AM   #15
smurfwrx
Member#: 151928
09 Triumph S3
^^^ LMAO!
That's FUN-E right there! I was knee deep in a project on my car one evening and needed a couple metric nuts and bolts. I gave my wife one bolt and one nut and said bring me back 5 of each. Pretty easy, right? I mean, she has a nut and a bolt so she can find a nut to fit the bolt, and a bolt to fit the nut........
She came back with 10 of everything I DIDN'T need.
Corpus Christi: Help, I can't get my IC back on my 07 STI Spectre186 Texas Impreza Club Forum -- TXIC 8 09-21-2008 12:07 AM
HELP!! I can't get my reservoir out! Stivie Water/Methanol Injection, Nitrous & Intercooler Cooling 0 01-24-2008 07:30 PM
Help needed with installing my kicker amp into the stock wiring.... wake_wrx Car Audio, Video & Security 15 12-05-2004 05:32 PM
How do i get my amp wires into the trunk? Meyers Car Audio, Video & Security 5 07-21-2003 11:00 AM
Can't get new SHIFTER int he socket Syms General Forum Archive 10 08-28-2000 05:16 PM
