Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-29-2008, 07:56 PM   #1
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Impreza GC8 RWD conversion, front suspension options
Im seriously considering doing a RWD conversion and theres lots of info on how to make this work and how to strengthen the rear end but very little info on how to adress the front suspension/camber problems.
and Im no doubt going to get flamed for even considering turning my AWD beauty into a RWD atrocity lol but this is the cheapest option to not destroy my tranny, what other choices do I have...?
1)ppg gears = $5,000
2)STI 6mt = $4-5,000
3)RWD = $1,000
and both the first & second option do not include the labor intencive cost of installation, labor that I nor most average gearheads cant perform but the third is just your average bolt turning.
So my question is what is the best solution to fix the front end suspension problems?
2.5rsDOHC is offline   Reply With Quote
Old 09-29-2008, 08:04 PM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
What are the problems with the front suspension, The only thing i could see is maybe needing a bigger sway bar and new suspension all around, I dont believe there is a problem with the front suspension, Is it not strong enough in design for RWD?, AWD guys through there cars around all the time im shure its fine.
parkes is offline   Reply With Quote
Old 09-29-2008, 08:48 PM   #3
2ndGearFling
Member#: 64466
05, STI on green
I dont see any issues with leaving your front half shafts in and just letting them turn. I also know that most of the people that swap over just leave the front suspension alone.
Parkes has no idea what he's talking about. Talk to PRE Racing, they've done it atleast once.
2ndGearFling is offline   Reply With Quote
Old 09-30-2008, 12:17 AM   #4
parkes
Member#: 166898
1994 T leg SS
ABM
Cut out the racist comments
Old 09-30-2008, 12:56 AM   #5
inyoface59
Member#: 95972
2012 Legacy
i think 2.5rs is talking about how its going to steer after i does the swap. after a turn the awd straightens the wheels back out. after the rwd swap its not going to straight back out since the front wheels arnt pulling out of the turn. so you either need to turn out of it your self which is the safe thing to do or you could adjust the caster to make it straighten back out on its own. they did a artical about it in... i think it was either subiesport or modified about how team orange adjusted there cars suspension after converting them to rwd... i know drifting isnt the same as Daily driving but its the same concept with returning the steering after a turn.
ya there shouldnt be a proplem with leaving the half shafts in either.
-phil
inyoface59 is offline   Reply With Quote
Old 10-13-2008, 01:22 AM   #6
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
What?
Front sus stays the same. If you plan on drifting, you'll need more steering angle.
If your trans has stub ends for female inner CV joints, just use some outer CV stubs in your uprights to keep the wheel bearings together. (I will sell you mine if you want) Or, remove the shim stacks and transfer gear inside of the center differential and leave all that stuff in the front just the way it is.
If you're making power over 160rwhp you'll need a tougher trans, but if you just want to have some fun just drop in a welded center and enjoy (I've also got one for sale if you're interested).
Unless there's someone else who has had a RWD daily driven Subaru since 2005, I'm probably the most qualified (and happiest) to answer any RWD conversion questions you've got.
mranlet is offline   Reply With Quote
rwd conversion AntonioS Transmission (AT/MT) & Driveline 16 09-27-2005 07:04 PM
front diff/ rear diff/ and RWD conversion supermoose Subaru Conversions 5 09-08-2003 06:16 PM
Auto RWD Conversion ImprezedRS Transmission (AT/MT) & Driveline 4 03-26-2003 08:31 PM
Billet RWD Conversion centre diff chiraoka Transmission (AT/MT) & Driveline 14 01-08-2002 09:04 PM
Anyone done RWD Conversion? cdigerlando Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-25-2001 09:55 PM
