Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 09-29-2008, 08:04 PM   #1
0260B4U
Member#: 33249
2003 WRX
white
Question So how bad is it really to have 2 different types of tires on the front and rear?
I was discussing this with a friend at work today and Ive heard its bad but really couldnt bring any hard evidence to back up my point. I already figure 2 different sizes would spin the diffs at different speeds and tear it up that way. But if you had 2 identical tires on the front and rear but different tread pattern/style, assuming fairly close performance-wise(not passenger vs Azenis or anything)
Any info, links, writeups, etc you could help me with would be great
0260B4U is offline   Reply With Quote
Old 09-30-2008, 11:04 AM   #2
0260B4U
Member#: 33249
2003 WRX
white
No one have a definitive answer?
Old 09-30-2008, 11:07 PM   #3
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
center diff has to work as well...not only left right but also forward and back.
Mr_Snips is offline   Reply With Quote
Old 10-01-2008, 12:02 AM   #4
ringe
Member#: 49998
2007 WRX CT Stg 2
Identical tread wear assumed, two different sets of tires will have different traction and handling capabilities, which could cause unusual handling characteristics.
ringe is offline   Reply With Quote
Old 10-01-2008, 12:09 AM   #5
Boxologist
Member#: 21118
same size, nominal difference in wear, u will be fine. start mixing different sizes and u will begin adding wear to ur center diff.
Boxologist is offline   Reply With Quote
Is it OK to add a different type of oil? lawn boy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2010 07:07 PM
How bad is it really, to have 2 different sets of tires on an AWD car? WhiteFox Tire & Wheel 12 03-19-2008 03:22 PM
So.... how bad is it to drive without a gas cap? Laugh Damon Newbies & FAQs 44 02-12-2006 07:44 PM
So how bad is it?....... Fach Tri-State Area Forum 12 03-02-2003 04:37 PM
