#1 |
Member#: 125580
Vehicle:2011 WRX 5dr OBP |
My 02 Impreza has started making a loud "drone" coming from the rear of the car at highway speed (very similar to this thread). I had inflated my tires about a month ago, but after checking last night I was shocked to find that the front tires were lower PSI than the back, and one back tire was ~5 PSI higher than the other. After correcting the pressure, the noise remains. Is the diff shot? How much will it cost to fix, and is it safe to drive on? My commute is 100% highway driving.
#2 |
Member#: 86274
Vehicle:. Andrewtech Gold Club Member |
You may also want to check the wheel bearings. Jack the rear of the car up and try to shake the wheels back and forth. If there is some play you may need to change them out.
To check if the rear diff is going, pull the lower drain plug on the diff. There is a magnet on it and generally there will be some nasty metal bits on it if the diff is going. |
#3 |
Member#: 133855
NWIC
Vehicle:2009 STi SparkSilver Dom Tuned @ MPS |
Sounds like a wheel bearing.
#4 |
Member#: 125580
Both rear wheels are super tight, no play whatsoever. I can't drain and refill the rear diff as I don't have a lift. Is a bad diff something you can drive on for a month or so, or is it in danger of seizing?
| Thread Tools | |
| Display Modes | |
| Ok, What REALLY Is My Rear Diff Ratio? Tranny Gurus ONLY! | 02CWRX | Transmission (AT/MT) & Driveline | 31 | 08-28-2012 03:45 AM |
| Is my rear diff shot? | BKscooby | Newbies & FAQs | 6 | 01-19-2010 10:36 AM |
| is my rear diff done? | jeraljay | Transmission (AT/MT) & Driveline | 6 | 12-18-2008 05:14 PM |
| Is my rear diff going south? | WRX Bamboo Steamer | Transmission (AT/MT) & Driveline | 5 | 03-17-2004 05:21 PM |
| what gearing is my rear diff? | supermoose | Subaru Conversions | 1 | 09-04-2003 05:07 PM |
