Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 09-30-2008, 09:02 PM   #1
Carbonwrx04
Member#: 141743
2004 Wrx SanRemo Red
97 Leg Gt Blk
Default Grinding Noise, possible throw out bearing?
I have a 2004 wrx and a friend of mine just did a clutch job on it. We put an act street disc, pp, and streetlight fly. It did make any noise before the tranny was dropped out of it. When I drove it home it sounds like it is making a rotating grinding noise when im declerating mostly in second and in third. If I push in on the clutch the noise goes away. If im sitting in neutral it doesnt make it, niether in the cold. Only downshifting in those gears will make the almost kind of rattle noise.
Carbonwrx04 is offline   Reply With Quote
Old 10-01-2008, 03:09 AM   #2
zebro racing
Member#: 187273
1998 2.5 RS
Arrest me Red
wow! thats strange. check the rod that the the slave cylinder conects to, mine rattles off and on. thats all ive got, good luck.
zebro racing is offline   Reply With Quote
Old 10-01-2008, 11:10 AM   #3
Carbonwrx04
Member#: 141743
97 Leg Gt Blk
Thanks for the help, kinda confusing. Bump for second opinion?
Old 10-01-2008, 10:24 PM   #4
IH8PVMNT
Member#: 178254
2006 Wrx Limited BUG
2006 Wrx Limited Wagon
well if its rattleing when you depress the clutch.... does it fee like it slips/chatters or doesnt shift into any gears smoothly.... maybe the pressure plate wasnt tightened properly or all the way... and throw out brearing mainly make niose when the clutch is depressed not released. the only other thing i can think of its that the clutch disc wasnt linded up properly and may have been damaged... also did the flywheel come with a pilot bearing if not did you install one? if so how was the condition of it... theres so many possiblitites
IH8PVMNT is offline   Reply With Quote
Old 10-02-2008, 01:12 PM   #5
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
Its not a throw out bearing. The throw out bearing only does work when the clutch is depressed, otherwise its not moving.
Sounds more like an issue inside the gear box. 2nd and 3rd are usually different assemblys and not on the same shift fork, i assume subaru is this way but i dunno for sure. So its probably not a synco issue, possibly something along the lines of an internal bearing failure or something on the imput shaft, i dunno i'd have to be there.
Chocoholic005 is offline   Reply With Quote
Old 10-02-2008, 01:43 PM   #6
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Grinding/rattling noise is normal under deceleration with aftermarket clutches/lightweight flywheels. Its annoying, drives me crazy, but I've gotten used to it
twizzstyle is offline   Reply With Quote
Old 10-02-2008, 03:58 PM   #7
Carbonwrx04
Member#: 141743
97 Leg Gt Blk
All sounds like possible ideas, its really hard to know exactly what it is til we got underneath it again. Thanks for the input guys, the car is going back to the garage this weekend. I hope its not somthing that will forever be there! You right it gets really annoying.
Old 10-03-2008, 05:07 PM   #8
tomass2132
Member#: 190427
05 saab 92x
vf34 w/ avo 15lb actuator
Check the shifter linkage. I have the same problem right now and it seems to be part of the linkage rattling back and fourth.
tomass2132 is offline   Reply With Quote
Old 10-03-2008, 05:37 PM   #9
foolio
Member#: 9351
2006 trailblazer SS
black
Did you change anything else? Check to make sure nothing is hitting your drive shaft. Do you have a DSS One piece drive shaft? Those things tend to hit and make niose. Also there is a gaurd on the bottom engine, so rocks and such dont get up in the clutch area. Its right below were the engine and gearbox meet. I have seen where people have jamed that up into the clutch area causing all kinds of racket. Just a few things to check. After all else fails, drain your gearoil and check to make sure nothing is going on within the gearbox. If so, then maybe someone took it out for a "test drive" after the clutch install?
foolio is offline   Reply With Quote
Old 10-03-2008, 06:40 PM   #10
DiscoGsus
Member#: 47646
0211 RallyWagon
DGM Sedan
Also, try changing the air pressure in your tires a bit.
Stock WRXs get "deceleration noise" and its because when decelerating in gear their is no differential loading between the input and output shafts which means they can rattle. Buy upping the psi difference between the front and back the tranny is slightly loaded and the problem goes away.
If it makes noise when the clutch is out, isn't that the pilot bearing? But thats more squeeking and annoying then grinding.
DiscoGsus is offline   Reply With Quote
Old 10-03-2008, 10:25 PM   #11
jam007
Member#: 174706
2008 LGT-B
bro i've got the same problem with my trans. I even bought the clutch through STI (street disc) and it makes that winding noise when decelerating, it is killing me so if you get any answers from this weekend please keep us posted.
jam007 is offline   Reply With Quote
Old 10-07-2008, 03:56 PM   #12
Carbonwrx04
Member#: 141743
97 Leg Gt Blk
Nothing new, its starting to go away actually. Quited down a lot. I drained the gearoil and checked that, theres nothing wrong with the drive shaft or anything underneath with rattling up. My friend who put the clutch in said it was the aluminum flywheel and that his car did it a little too. Idk hope the noise goes away once its all broken in, keep you posted. Thanks for the help guys
throw-out bearing shot...possible flames welcome N/A_junkie General Community 13 07-18-2007 04:05 AM
Throw out bearing... a little noise OK? Heavy Fuji Transmission (AT/MT) & Driveline 2 12-08-2006 12:40 PM
Throw out bearing noise? lotusTT Transmission (AT/MT) & Driveline 6 06-06-2004 04:01 AM
throw out bearing noise? Heavy Fuji Transmission (AT/MT) & Driveline 1 02-11-2003 12:34 AM
Throw Out Bearing Noise? ChrisF Transmission (AT/MT) & Driveline 11 07-08-2002 10:01 AM
