#1 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Attached below is a diagram I made which I believe represents the electronic circuit ScoobySport has developed to eliminate the CEL when you have no cats. Three identical 1.5M Ohm resistors are used in series because I couldn't find anyone that sells a 4.5M Ohm resistor (and besides, you usually have to buy at least 5
).I myself haven't even seen the ScoobySport fix yet and I haven't tried the circuit, below, myself. And I have a request for those with electronics skills who will be buying these little boxes from ScoobySport in the near future. Please make some capacitance and resistance measurements on the various leads and let me know whether you can confirm that I got the circuit right. P.S. B17 is the ECU's input from the rear O2 sensor D3 is a 12V ECU output |
#2 |
Member#: 9898
Vehicle:2002 WRX Water Injected Blue |
I think I was awake when some physics teacher said that temperature changes will influence resistivity in a circuit. Where is this "magic box" mounted? If near the exhaust, would the temp extremes have an effect on this trick?
#3 |
Member#: 10228
Vehicle:2002 Subaru WRX |
yes heat will increase resistance. I dont see why you cant mount this with the ECU under the carpet, sounds like a great location there is lots of room there
#4 |
Member#: 8221
NESIC
Vehicle:02 WRX Wagon Blue/Gold |
It has to be mounted near the ecu.. the wires aren't all that long, and there's no reason to put it anywhere else.
#5 |
Member#: 9898
Cool, thanks.
#6 | |
Member#: 2992
NESIC
Sorry. I should have explained a little more.
The ScoobySport "black box" attaches to the wiring at the ECU, under the mat in the passenger (RH) side foot well. It has four wires, colored orange, yellow, black and blue. Thus, it lives inside the passenger compartment and its temperature should be relatively stable by the time the ECU decides conditions are ripe for testing the cat system efficiency. The method of attachment is: 1) Cut the wire with white insulation leading from ECU pin B17 (see WRX ECU wiring diagram at www.Ravensblade.com, www.projectwrx.com and elsewhere). That white wire carries the sensor signal from the rear O2 sensor to the ECU. 2) Attach the orange wire from the "black box" to the ECU-side white wire. 3) Attach the blue wire from the "black box" to the sensor-side of the white wire. 4) Attach the yellow wire from the "black box" to the 12V wire from the ECU with yellow insulation and blue strip (only remove insulation; don't cut the wire). 5) Attach the black wire from the "black box" to a good chassis ground. All the info I have arrived unsolicited via email: Quote:
#7 |
Member#: 8221
NESIC
That's not entirely true.
There are about 4 more wires coming out of the box that are unused.. and are about half as short. I'm not sure what their purpose is. |
#8 | |
Member#: 2992
NESIC
lenyx,
I believe you're correct. My correspondent told me it was a : Quote:
So, lenyx. It seems you have one. What else can you report? ![]() |
#9 |
Member#: 8221
NESIC
Umm.. it's grey in color.. and uh.. yea... that's about it for what hasn't been said.
I spent last weekend building a wiring harness for it and my unichip and avc-r so that I could keep all my ecu wires organized and do away with a mess of butt connectors and splices. I won't actually have anything to report on functionality until I finish putting the appropriate connectors on the ecu wires and plugging everything in. That will hopefully happen this weekend. Although I'm not even sure if I'm still getting the low catalyst cel anymore.. ever since I installed my up-pipe the cel has been oddly quiet. |
#10 |
Guest
Member#:
Is it possible to make the splices in the corresponding wires on the unichip? I would prefer to make the connections there, if possible, and keep from altering the factory ecu wires. But, I imagine since it's a piggyback unit, I will not be able to. Thanks for any help.
#11 | |
Member#: 8221
NESIC
#12 |
Member#: 9214
Vehicle:2002 WRX |
Jon,
Are you sure that black wire goes to ground? Seems that the return voltage would just go there and not to the ECU, or am I missing something here? What would the resulting voltage be for a return signal of .7V or .3V? Just curious to see what's happening. Last edited by Thumper; 03-19-2002 at 12:33 AM. |
#13 |
Member#: 8221
NESIC
The black wire is indeed a ground. Has a ring terminal and everything.
#14 |
Member#: 7089
NWIC
Vehicle:05 Legacy GT Sedan 07 4Runner Limited |
Hmmm....
#15 | |
Member#: 2992
NESIC
I'm not sure about anything here, since I don't have one. For instance, I'm not sure that the capacitor is in the correct "spot" in my diagram, above. It would, indeed, be interesting to build one of these, ground the Black wire, supply 12V to the Yellow wire, supply .3V or .7V to the Blue wire and then measure the resulting voltage at the Orange wire. But I don't have the equipment to perform that kind of test. |
#16 |
Member#: 13461
This post is most amusing. I look forward to hearing how well Jon's reverse-engineered box works... or not.
![]() worry bbs.22b.com |
#17 |
Member#: 9837
Vehicle:2002 White WRX Wagon 7800 ft |
It's obvious that Jon's schematic, as shown in the 1st post, is wrong. Take a look at the Black ground lead. It connects directly to the Orange/White/ECU-B17 lead. With the circuit as shown, the ECU's rear sensor input will always be grounded.
It would be useful to have resistance measurements between the black lead and the orange lead, and between the black lead and the blue lead. Then Jon could refine his schematic accordingly. |
#18 |
Member#: 2071
Hi All!
Simply using a few passive devices to get round the CEL problem isn't necessarily the best approach (perhaps even dangeroous), because whatever the circuit achieves it can only ever be a linear function of the original input voltage from the O2 sensor, which is obviously "wrong" otherwise it wouldn't be causing the CEL to come on. I would advise against fitting a simple passive device, because any passive configuration capable of alleviating the CEL problem will also distort the ECU's lambda readings, which it uses for fuel trim. Cheers, Pat. |
#19 | |
Member#: 2992
NESIC
And I agree with Rocky WRX. Jon needs resistance and capacitance measurements between all possible "black box" lead combinations. ![]() |
#20 |
Member#: 2071
Jon,
I would agree with your assumption that the ECU would not try to use the rear O2 sensor for closed loop lambda control should it determine that the front O2 sensor has failed, because it sits (or should sit ) behind three catalytic converters, and thus will not be seeing the same appearance AFR as the front sensor anyway.However it may use the rear O2 sensor to purge a NOx trap (should such a device be stipulated by the CARB), or for periodic regereation of the cat cores, since the rear O2 sensor gives a true post-cat appearance AFR reading, something that the front unit is incapable of. If it is used in either of these capacities then it stands to reason that the ECU does use readings to affect fuel trim for the purposes of cat / NOx trap "health". Additionally, the distortion of the readings created by a passive device based solution could in itself create new a new CEL condition reporting that the rear O2 sensor has failed.... Cheers, Pat. |
#21 | |
Member#: 2992
NESIC
#22 | |
Member#: 2992
NESIC
A boatload of measurements have landed in my inbox. So, I'll
leave these measurements with you, 'til the morning, when I'll have the time and attention that they deserve. A quote from their author: Quote:
Code:
Black (Pos+) Blue (Pos+) Orange (Pos+) Yellow (Pos+) Green (Pos+) Gray (Pos+) Purple (Pos+) Pink (Pos+) Black (Neg-) XXXXX 4.94M OL 140.8M OL 7.44M 3.34uF 4.95M OL OPEN 0.48nF 5.52M OL 5.04M OL Blue (Neg-) 3.145M OL XXXXX 3.145M OL 17.80M OL 12.31M 4.55uF OPEN 0.48nF 13.72M 4.00uF 12.44M 4.49uF Orange (Neg-) 140.8 OL 4.92M OL XXXXX 7.40M 3.32uF 4.95M OL OPEN 0.48nF 5.52M OL 5.01M OL Yellow (Neg-) 3.815M OL 14.08M 3.99uF 3.80M OL XXXXX 14.12M 4.23uF OPEN 0.48nF 15.76M 3.63uF 14.28M 4.19uF Green (Neg-) 3.097M OL 12.08M 4.35uF 3.097M OL 17.48 1.03uF XXXXX OPEN 0.48nF 13.50M 3.98uF 12.25M 4.49uF Gray (Neg-) 1.891M OL 8.68M 3.21uF 1.890M OL 12.36 0.88uF 8.71M 3.33uF XXXXX 9.64M 2.88uF 8.80M 3.29uF Purple (Neg-) 3.043M OL 11.85M 4.41uF 3.044M OL 17.18 1.04uF 11.92M 4.60uF OPEN 0.48nF XXXXX 12.04M 4.55uF Pink (Neg-) 3.084M OL 11.96M 4.35uF 3.084M OL 17.33 1.03uF 12.04M 4.53uF OPEN 0.48nF 13.40M 3.98uF XXXXX Top Row: Positive Lead Left Column: Negative/Common Lead Top Reading: Resistance in Ohms (M=Megohm) Bottom Reading: Capacitance in Farads (uF=MicroFarad, nF=NanoFarad) Open Air Capacitance reading: 0.34-0.38nF Shorted Capacitance reading: OL Last edited by Jon [in CT]; 03-20-2002 at 09:33 AM. |
#23 |
Vendor
Member#: 6605
Interesting post this ...
Just a note to say that the black box is a bit more sophisticated than the initial parts of the post are noting. ScoobySport invested a good bit of time and money into development of a proper fix. The advantage for us is not in making profit on the fix itself, but on positively and completely solving the CEL problem, which gives our exhaust a bit of an edge. Regards, Ken Cole ScoobySport N.A. |
#24 |
Member#: 2071
Jon,
I see your point about a fix not being a fix if it generated another CEL condition I was merely suggesting that a simple passive device based "fix" may do this, and would, by your reasoning, therefore not be a fix. Of course, if it fixes the CEL problem without creating a new CEL condition, and doesn't mess up the ECU's mixture control, then it is indeed a fix. Your point about the fix getting round the problem where the cat / NOx trap have been removed is indeed correct, my point was that if one distorts the readings the ECU sees to fix the CEL problem, it could alter the fuelling in a way that it would never have done, were the cats still in place and it was getting true readings of appearance AFR post-cat / NOx trap. Cheers, Pat. |
#25 |
Member#: 12976
TXIC
Vehicle:2002 WRX grocery getter |
1. Is the Scoobysport CEL-fix box for sale to everybody including people who don't have Scoobysport exhausts?
2. What does it cost? This looks more complicated than just a simple MIL-eliminator. But.. maybe they've just thrown in extra wires to confuse people trying to reverse engineer it. If the answers to the two questions above are not satisfactory, I'd consider reverse engineering the scoobysport box. Based on Jon's measurements I'm sure we can put together a functional replica. Besides, it'd be a fun project ![]() |
