Old 10-01-2008, 10:39 AM   #1
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Default Clunk/Grind... that goes away when braking?
So recently I had a clunking noise start in my car. Originally I thought it was only while decelerating in gear, but now I've found it does it when accelerating softly (maybe hard too... my car's too loud to hear it), and it does it in neutral too. Around 25 mph its a rough kind of "clunk clunk clunk clunk" that changes with vehicle speed. As I slow down to almost a stop its more of a grinding "grriiiinnndd......grriiiinnddd....etc"
I got under the car last night and found quite a lot of grease around where the axle meets the tranny. The CV boot itself is fine, the grease was only on the tranny. So now I'm thinking maybe its been leaking grease for a while, and the CV is just tearing itself apart with no grease now. Does that sound like normal bad CV noise? It's on my driver's side.
Now the weird thing (to me anyways) is if I barely touch the brake, the sound goes away entirely... Would a CV noise go away if you were braking?
twizzstyle is offline   Reply With Quote
Old 10-01-2008, 05:32 PM   #2
foolio
Member#: 9351
2006 trailblazer SS
black
How do your brakes look? May not be related to your gearbox.
foolio is offline   Reply With Quote
Old 10-01-2008, 05:39 PM   #3
vica153
Member#: 76586
2006 9-2x Aero
Yeah check if the rotor on the corner the noise is coming from looks messed up. It might be a caliper that is sticking.
vica153 is offline   Reply With Quote
Old 10-02-2008, 11:49 AM   #4
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Rotors are fine, calipers are fine, pads are fine, brake lines are fine... I checked all of that first hoping it was like a loose caliper or something.
Wheels squeak when I drive, goes away when I press brake nitr0x99 Brakes, Steering & Suspension 11 12-13-2010 12:34 AM
03 Front Wheel rattle, goes away when braking blitzpb Service & Maintenance 4 12-29-2008 10:37 AM
Unknown Squeal when NOT braking and goes away when lightly braked Gorge Brakes, Steering & Suspension 1 04-05-2008 02:57 AM
weird sound but goes away when pushing the clutch x12oyx316x Transmission (AT/MT) & Driveline 23 06-22-2004 12:18 PM
Squeeky Rear Suspension when Cold, goes away when warm. nhalterman Brakes, Steering & Suspension 2 12-12-2001 03:31 PM
