Old 11-08-2012, 11:00 AM   #3126
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
You need tpms sensors in the wheels and they need to be flashed to the car. Otherwise they will blink and stay on.
colin1234567 is offline   Reply With Quote
Old 11-08-2012, 11:08 AM   #3127
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Originally Posted by WRX Smokescreen View Post
year:2012
make:subaru
model:wrx 5-door premium
tires only or winter package: Dunlop snows on 16" (Nitrogen fill)
TPMS lit up this morning (installed the tires yesterday).
Is this to be expected using wheels that aren't same size?
FYI - The wheels are used. (old WRX 02-03 wheels)
That ^
Pain in the ass in my opinion. I just deal with the light.
SWP n Gold is offline   Reply With Quote
Old 11-08-2012, 11:20 AM   #3128
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
if anyone has a tire depth gauge can tell me right now trying to figure if i can use these tires using a quarter
measure A: the tip of his nose
measure B: his eyebrows
see if there is a 2/32 difference
JAMM0N is offline   Reply With Quote
Old 11-08-2012, 11:59 AM   #3129
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
Would you recommend 225/45/17 or 225/50/17 on stock 2012 WRX wheels with EPIC LOWERING SPRINGS?
WRXinpa is offline   Reply With Quote
Old 11-08-2012, 12:24 PM   #3130
sc00by4life
Member#: 97135
225/45 or 215/50.
Old 11-08-2012, 12:45 PM   #3131
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Originally Posted by sc00by4life View Post
215/50
Gonna be stretched on an 8" wheel.
Old 11-08-2012, 01:04 PM   #3132
sc00by4life
Member#: 97135
Not really....
Old 11-08-2012, 01:54 PM   #3133
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Not really....
Care to elaborate? According to TireRack's website, they recommend nothing wider than 7.5" on a 215.
Old 11-08-2012, 02:04 PM   #3134
sc00by4life
Member#: 97135
Tire rack also calls the v12 ventus a max performance summer tire. Their website isn't always correct.
http://customwheelsmarket.com/rimwheelwidth1.html
Not to mention plenty of people run 215's.
On the left is 215/45/17's on 8" wheels, which is slightly shorter than what I suggested. Taller sidewalls actually come out slightly further than shorter sidewalls to support the height of the tire, and will be less stretched than a 215/45...if you even want to call tha "stretches".
Old 11-08-2012, 02:25 PM   #3135
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
That website you quoted also states 6.5-7.5" wheels for a 215/50. I didn't say he couldn't run it or that others haven't, but there are plenty of pictures out there of 215s on 8" wheels and they're stretched. Either way, he can do whatever he wants.
Old 11-08-2012, 03:33 PM   #3136
krzyss
Member#: 8365
2013 Ford Focus SE
.5" will not cuase big problems but one is out of spec per manufacturer (check manufacturer web site for specs, Tirerack may be wrong). I suspect that if you have warranty claim (wear issue for example) they may use it agaist you.
Krzys
PS I try to stay within design parameters for all hardware I use.
krzyss is offline   Reply With Quote
Old 11-08-2012, 03:38 PM   #3137
Freedog
Member#: 293551
Default Tire Pressure in Blizzaks?
I've read elsewhere that people are running a little higher pressure in their Blizzaks than their summer tires. From other forums it seems that anywhere between spec OEM psi and up to near 37 psi for the Blizzaks has had good results.
Anyone have best results at a certain psi?
Last year I ran 35 psi front and rear and they felt solid all winter.
Freedog is offline   Reply With Quote
Old 11-08-2012, 05:55 PM   #3138
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
just slapped some bugeye wheels on my 2012 with a 205/60/16 tire.
need moar snow!
BigRob74 is offline   Reply With Quote
Old 11-08-2012, 07:21 PM   #3139
Scooby207
Member#: 255687
11 WRX DGM
My dealership is trying to get rid of some 16" moda md12 wheels. I'm thinking about grabbing them for my winter set up as they are only asking about $10 per wheel more than the steel wheels I was going to be getting. I don't love them but for the price I think it's definitely an upgrade from steel in terms of looks but is there any reason I wouldn't want something like this for winter wheel? One of my friends said I would be dealing with snow getting stuck in between the spokes. The other said less will get stuck than in the steel wheels and it will even be easier to get out.
Any input would be appreciated
Scooby207 is offline   Reply With Quote
Old 11-08-2012, 09:34 PM   #3140
noodleface
Member#: 111952
2013 '13 BRZ/'17 STI
WRB/TOP
'13 BRZ
Boston
Tires only
I currently have 225/45/17 Dunlop Wintersport 3Ds (about 25,000 miles) from my previous WRX. Problem is that one of the tires developed a bubble on the sidewall and I'm not sure whether to replace just the single tire or to replace all four. The local tire shop shows the 3Ds as discontinued in my size but might be able to track one down (albeit at a price of ~$250).
They recommended Nexen Winguard Sports but I've not seen too many reviews. Any other recommendations in the ~$150 per tire range ideal for southern NE conditions? I'd prefer a winter performance tire more than a normal winter tire but I'm open to suggestions in the 205/50/17or 215/45/17 sizes.
Thanks in advance.
noodleface is offline   Reply With Quote
Old 11-08-2012, 10:00 PM   #3141
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
need moar snow!
Painted or powdercoated?
Old 11-08-2012, 10:15 PM   #3142
paulrio74
Member#: 247953
2012 WRX OBP Hatch
70 Buick Electra w/455
Consider checking your local stores too. I stopped in an American tire/discount tire. Explained Costco wouldn't put on blizzak ws70 in stock size because of the drastic speed rating difference, discount tire had a $100 off on eBay, and the Nokian dealer offered a decent trade on my 6.5k mile stock dunlops. Walked out with ws70 in 235/45r17 with full balance/mount for $645 after an hour wait.
paulrio74 is offline   Reply With Quote
Old 11-08-2012, 10:15 PM   #3143
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
powdercoated
Old 11-09-2012, 02:44 PM   #3144
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
because winter:
17x7
225/50/17
BRING IT ON MOTHER NATURE!
Old 11-09-2012, 02:51 PM   #3145
sc00by4life
Member#: 97135
Originally Posted by Peacewalker86 View Post
I ran 205/50 general arctic on my stock wheels last year. A little stretch but looked fine and the narrow tire handled awesome in the snow.
pic for reference
I'm running saab wheels this year tho
it aint that bad.
Old 11-09-2012, 04:33 PM   #3146
AjaxBleach
Member#: 229884
2011 WRX 5 Door
Spark Silver Metallic
year: 2011
make: Subaru
model: WRX 5 Door Standard
tires only or winter package: Tires Only
I have a set of 16" wheels I got off a 02-04 WRX. I went to the Tire rack website and looked for the 16" recommended tire size for my car. I'm looking to buy Winter performance tires for my car but couldn't find any for my size. Does anyone know what the next recommended size would be?
AjaxBleach is offline   Reply With Quote
Old 11-09-2012, 06:02 PM   #3147
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
Originally Posted by AjaxBleach View Post
year: 2011
make: Subaru
post 3138 has the info. this size is cheaper than the recommended 215/55 and fits those wheels fine
Old 11-09-2012, 08:28 PM   #3148
deesarco
Member#: 293266
Originally Posted by trev762 View Post
My best recommendation for u would be to get a set of good wet weather tires as the stockers really do suck in wet weather.
If u r going into the mountains alot I would consider steel wheels with studded snow tires as the Seattle mountain ranges get alot of ice and snow hope this helps.
I like this advice a lot, I'm looking at tires and I am thinking the Pirelli Winter 210 Sottozero after reading about many tires, noted to be good for wet and still decent in dry conditions, a little longer lasting, but only ok in snow (still better than my stock tires).
I'm thinking of stepping down to a 16" diameter for the winter set to save some cash and I plan on buying dedicated rims anyways, the standard size on the Premium model 2012 Impreza's is 205/55-16, however Tirerack.com recommends 195/60-16 for winter tires. Would anyone here recommend the stock size for 16" on 2012 Impreza's or should I be getting a slightly narrower and higher tire?
Thanks!
deesarco is offline   Reply With Quote
Old 11-09-2012, 10:26 PM   #3149
von Wachtstain
Member#: 52726
For my 2012 Impreza Limited I bought Blizzak WS60 in 195/60/16 size. Car performed like a tank during our first snowstorm. I really don't think you should go smaller.
von Wachtstain is offline   Reply With Quote
Old 11-11-2012, 10:11 AM   #3150
Zeeper
Member#: 299286
2015 WRX CVT
Thanks!
I would downsize to the 15" wheel setup. The overall size of the wheel is the same and 195/65-15 works fine on my Sport. It will save you a little more money overall and the only real difference is the height of the sidewall.
Zeeper is offline   Reply With Quote
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 10:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 11:42 AM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-15-2009 11:34 PM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 11:28 AM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 10:06 PM
