Old 01-02-2013, 04:14 PM   #3376
sreggie101
Member#: 337458
2012 WRX Hatch
Originally Posted by Jdub.csu View Post
It will get worse with time call them for the warranty I've seen them get so big they look like a boil lol.
out of luck. warranty didn't cover that. but tire rack gave me discount shipping and half off replacement tire since i purchased 3 weeks ago.
o well..
sreggie101 is offline   Reply With Quote
Old 01-02-2013, 04:43 PM   #3377
SNE2040
Member#: 72195
2012 WRX GV
I'm debating between the general altimax arctic and the michelin x-ice xi3.
I would get 205/60-16 for oem 02 wrx wheels.
Anyone prefer one over the other? Different between the two sets is almost $100, Michelin being more expensive
SNE2040 is offline   Reply With Quote
Old 01-02-2013, 07:23 PM   #3378
idauntless
Member#: 330375
2013 Sti SWP 4dbs
1997 A6 SWP Avant quattro
Wheel: 2005+ GDB 5x114.3 BBS 19lb/wheel, powder coated in new condition, $780 to the door;
Tire: Blizzak WS60 225 55 17 97R(106mph damn low rating), 27lb/tire, brand new $500 to the door.
In general:
Pros: Rally racing look and great lateral traction on heavy snow/water ice mixture, better ride quality than stock 245 18 Dunlop and quiet as well on dry pavement. Decent dry traction comparable to Continental DWS, reasonable price;
Cons: Mediocre longitudinal traction on ice/snow esp. when breaking, poor lateral traction on snow covered ice/black ice, a bit heavy at 46lb/corner.
In comparison with WS70: WS60 has better tread-wear as WS70 has very different compound(or shall I say NanoPro Tech polymer and Multicell compound make a loose tire texture). WS70 improves ice performance a lot but not a big difference on dry/wet/rain/deep snow. I had WS70 on my Audi C4 A6 Avant last winter.
idauntless is offline   Reply With Quote
Old 01-02-2013, 10:37 PM   #3379
Scooter Sube
Member#: 104044
2002 Wrx Wagon
wrb
@sreggi how is it that both the rim and tire have sores? from the pic, it looks likes your rim is indented shaped. unless my lazy eye is kicking in again. seems like you knew you hit a pot hole.?
Scooter Sube is offline   Reply With Quote
Old 01-02-2013, 10:49 PM   #3380
SNE2040
Member#: 72195
2012 WRX GV
Yeah the rim is bent in that area
Old 01-03-2013, 01:28 PM   #3381
sreggie101
Member#: 337458
2012 WRX Hatch
i recall hitting a bad pothole on this side of the car, but it never occurred to me to check for this tire issue since it never happened to me before. i've hit bad potholes before and never ran into an issue. this is a first for me. but once i found out the sidewall was busted from a pothole i recalled the last instance I hit one. (found this out after i posted the pic).
im not sure what you guys are seeing with the rim. the tires and rims are dirty as hell from the boston snowstorm over the weekend and from installation of these tires from 2 weeks ago. i checked all rims (on the outside at least) and found no problems. a dent on the rim would stand out up close.
Old 01-03-2013, 04:38 PM   #3382
SNE2040
Member#: 72195
2012 WRX GV
To the right of the bubble, look at the pic you posted. It doesnt seem perfectly curved where the lip of wheel meets the sidewall. Looks kinked/bent
Old 01-03-2013, 10:05 PM   #3383
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Lol don't worry u weren't seeing things cuz its kinda funny how that pic was removed from the original post/
trev762 is online now   Reply With Quote
Old 01-04-2013, 07:08 AM   #3384
sreggie101
Member#: 337458
2012 WRX Hatch
...says who?
Old 01-04-2013, 07:30 AM   #3385
sreggie101
Member#: 337458
2012 WRX Hatch
i checked again this morning. its the angle of the pic. where the spoke meets the outer rim is raised. its the same all around. i can see how it looks dented, probably should've taken a better pic. o well.
thanks for the responses. problem already solved
Old 01-04-2013, 09:47 AM   #3386
Zanardi1782
Member#: 89855
2010 Impreza STI SE
Dark Gray Metallic
I can still see the pic. If you look closely, you can see the spoke in the lower right-hand side of the pic. Maybe the outer portion of the rim looks different where it meets the spoke. It's kind of hard to judge without a pic of the whole wheel, but it doesn't look like it's bent to me. It looks more like it's machined or cast that way.
My US$ 0.02.
Zanardi1782 is offline   Reply With Quote
Old 01-05-2013, 06:20 PM   #3387
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
My US$ 0.02.
Lol that wheel is clearly bent/
Old 01-05-2013, 07:44 PM   #3388
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
I believe Reggie.
The bulging tire gives an optical illusion that the rim is bent. In reality the rubber is obstructing the view of the rims true curvatire
gsrcrxsi is online now   Reply With Quote
Old 01-06-2013, 07:32 PM   #3389
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
The bubble just happens to coincide with where the casting comes out a bit at the spoke.
Not bent. Bummer on the bubble. It happens sometimes. I had it happen on a couple brand new tires once (in the tread zone) thankfully with it being purchased locally they replaced them under warranty, the shops warranty or the manufacturer, I don't know.
Breezio is offline   Reply With Quote
Old 01-07-2013, 11:00 PM   #3390
dlinsalata
Member#: 338589
Originally Posted by Microkoa View Post
Needing some input as I am new to the Suby world. I live in N Cal and wanting to take my family to snow country this year. Will my stock all seasons tires be ok in area's where there is chain control with out me putting chains on? (R2 chain control areas) If the answer is no. And my manual states not to put chains on my car. Suggestions on what others use? Are there cables or spring chains which are ok to use? Also if I were to change tires and its not beneficial to change to snow/ ice, what all season with good snow ratings would be good to buy?
Thanks for answers!
Hope to get some clarity.
Driving a 2012 impreza sport limited.
I'm in the same spot, except with a 2013 impreza sport limited. Manual has the same problem, and says I can use "spring chains." Unfortunately, the tires (Yokohama Avid S34 205/50 R17 88V all-season tires) do not say "M+S," so I think I need chains.
1) Can someone explain the difference between spring chains and tire chains?
2) Any suggestions on good spring chains?
Thanks!
dlinsalata is offline   Reply With Quote
Old 01-08-2013, 12:34 AM   #3391
Breezio
Member#: 234357
2009 WRX
An 'all-season' tire that isn't branded M+S...? Weird.
Old 01-08-2013, 12:44 AM   #3392
dlinsalata
Member#: 338589
Yeah - I just went out and double-checked, but these are the OEM tires from my '13 Impreza Sport Limited.
Oh, and I think I have answers to my questions, but would love it if someone could confirm:
1) Tire chains are actual chains that wrap the entire tire. Spring chains are metal ropes/cords/thick wires that go in a loose zig-zag formation over the tire instead.
2) I'm going with the*Super Z6's...assuming I understand #1 right
Old 01-08-2013, 02:52 AM   #3393
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Those Yoko are prob. as bad as infamous RE92...
My 0.02 for your safety: Get rid of those Yoko (sell them on Craigslist ) & get better tires (in 225/45).
Fendyman is offline   Reply With Quote
Old 01-08-2013, 02:03 PM   #3394
paulrio74
Member#: 247953
2012 WRX OBP Hatch
70 Buick Electra w/455
Roads with mandatory chain controls require a tire with the snowflake symbol instead of m+s in many states. It would be wise to do some checking with the local department of transportation. The z6 chains are some of the lowest clearance available I've been able to find. I have some for my '12 wrx, but haven't needed to use them due to snowflake tires. They appear to have no clearance issues after dry fitting, but if the manual says no chains...it could be a bit of an expensive repair gamble. I decided to have them, and if I end up on a road closed except for chains only, I have options. From my dry fit test, I would very likely use them if needed.
paulrio74 is offline   Reply With Quote
Old 01-08-2013, 10:41 PM   #3395
Breezio
Member#: 234357
2009 WRX
Just a little FYI, since I see you are in Oregon also. In oregon M+S tires and AWD/4WD constitutes having a traction device. The only time you need more, is during a conditional closure, which doesn't happen often, and then you need chains AND AWD/4WD, snowflake tires alone won't be legal..
Old 01-10-2013, 07:57 PM   #3396
shibbi3
Member#: 343215
Default Winter tire specs - STi
Hi all, new owner of a 2012 WRX STi. Loving it so far even though I only drove it home.
I need to get winter tires on it and every shop is specing 225/50R17 tires.
I'm new to all this so go easy. I looked at the door frame and the specifications for tires should be 245/45R18.
Why am I getting specced 225/50R17?
Also, another shop is speccing 215/50R17, which I am thinking about getting since it is the best deal right now... will there be problems on the car if I put on a 215/50R17 package?
shibbi3 is offline   Reply With Quote
Old 01-10-2013, 08:10 PM   #3397
Jdub.csu
Member#: 283784
2012 SWP WRX HATCH
Lol what? The 2012 WRX came with 17 inch wheels not 18 stock.
Jdub.csu is offline   Reply With Quote
Old 01-10-2013, 08:17 PM   #3398
Breezio
Member#: 234357
2009 WRX
He has an STi.
Perhaps the shops are accidently pulling up the wrx, and not the wrx sti.
Or, they wish to sell you some winter wheels also. [shrug]
Old 01-10-2013, 08:17 PM   #3399
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Definitely stick with a 17" wheel cuz tires r alot cheaper than for an 18" wheel. U will be fine with either 225 or 215 but highly suggest making sure the tires r speed rated like H rated or better hope this helps.
Old 01-10-2013, 08:21 PM   #3400
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Originally Posted by Breezio View Post
He has an STi.
Its no accident and its obviously a winter tire and wheel combo and sounds like its a descent shop to deal with cuz they're not trying to gouge the op with 18" winter tires lol
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 10:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 11:42 AM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-15-2009 11:34 PM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 11:28 AM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain 31 09-11-2007 10:06 PM
Message Board Statistics All times are GMT -4. The time now is 03:58 PM.
