Old 01-06-2010, 11:17 PM   #876
superhawk44
Member#: 20264
05 LGT arrestmered
07 Aprilia Tuono
Luke what pressure do you recommend? I would normally run about 36 front 32 rear.
sounds about right
superhawk44 is offline   Reply With Quote
Old 01-07-2010, 10:38 AM   #877
Daedalus
Member#: 29049
2007 WRX Wagon
year: 2007
make: Subaru
model: WRX wagon
tires only or winter package: tires only (EDIT: On 16x7" 6 spoke RS wheels)
NoVA is weird during the winter and is either dry, covered in ice, or knee deep in snow. Mostly it's pretty mild. I do ski and head to WV (Snowshoe) but thats usually 1-2 times per year. Also the winter weather usually doesn't last very long as the temperatures fluctuate a lot between above and below freezing.
I'm looking at the Michelin Pilot Alipn PA2 (locally, and non-run flat I believe) or the Dunlop Winter Sport 3D. Should I be looking at "Perfomance Winter" or should I go studdless?
I'm also concerned about tire life. Do the soft winter compounds wear faster? What about the wear characteristics of these tires?
I'm kinda leaning towards the Michelins because they are local (and cheaper due to the lack of shipping etc...) but are they any good? I've heard that Dunlops wear fast, is this true?
Thanks.
both are good choices but, I would opt for the Dunlop since that is a discontinued Michelin
Daedalus is offline   Reply With Quote
Old 01-07-2010, 07:51 PM   #878
jdmeg693
Member#: 149016
'06 STi WRB
Stage "what the" Deuce
Hey Luke,
what would you recommend for winter tires for a 2006 Civic Hybrid?
are there any good all-seasons that would work for it? it'll be driven in Denver.
Cheers
Michelin HydroEdge GreenX
jdmeg693 is offline   Reply With Quote
Old 01-08-2010, 11:40 PM   #879
MilesInCO
Member#: 233684
Trying to decide if I should buy a '08 STI, or a '10 WRX. Curious what the best snow tires are for each. For either car, I will get a dedicated set of winter wheels and tires. The priority is on getting to ski resorts and backcountry skiing trailheads. I'm not really concerned with dry pavement performance - I live a mile from work, the only time the car will go anywhere in the winter is when I'm going skiing.
year: 2010
make: Subaru
model: WRX wagon 5spd
tires only or winter package: package
Stock outer diameter for a WRX appears to be 25.0", so I'm considering 195/60R16 (25.2") or 205/55R16 24.9", but wondering if I can go up to a 205/60R16 (25.7") or 205/65R16 (26.5"). I've heard of a guy using 215/65/16 (27.0") on an Impreza with a 1" lift, and he called that "a very tight fit". For any of the sizes, I'm leaning towards a Blizzak WS60.
and the other car I'm considering:
year: 2008
make: Subaru
model: WRX STI wagon 6spd
Doesn't sound like any 16" wheels will clear the STI brakes, so if I got an STI I'd go with 17s. Stock outer diameter is 25.7". There's a Blizzak LM60 available in 235/50R17 (26.25"), or a Blizzak WS60 in 235/45R17 (25.3"). I like the OD of the LM60, but I've heard the LM60 isn't as good of a snow tire as the WS60. The problem with the WS60 is the small outer diameter. Also, for both options 235 seems wider than I'd want. Could you recommend a good snow tire in 205/55R17 (25.9") or 215/55R17 (26.3")? No Blizzaks come in those sizes. Also, how big of an outer diameter can I go with on an STI? 205/60R17 would be 26.7", and the 1/2" of extra ground clearance would be a welcome benefit.
Thanks,
Miles
been out of touch for a few days .... sorry for the delayed response
I would opt for the increased performance of the STi providing it hasn't been beat on too bad. and look at the Winter Sport 3D from Dunlop
MilesInCO is offline   Reply With Quote
Old 01-13-2010, 10:08 AM   #880
Subarudude2
Member#: 139445
2007 WRX wagon
CGM Cobb Stg 2
year: 2002
make: Subaru
model: Forester
tires only or winter package: 3 snow tires on 3 rims...oddball question
A little background:
I had 4 205/60/16 Winterforce snows on 16x6 black steel wheels on our forester. The rims were bought secondhand but fit the forester with no issues. my wife clipped a curb and put a nasty dent in the passenger front rim. Sidewall punctures took out both passenger side tires. I replaced the tires in the same size. The front rim was replaced with a new one from Tire rack. It ends up being 16 x 6.5" vs 16" x 6". Will the extra 1/2" make a difference if i use the same size tires on all 4? my thinking is that the contact patch and diameter difference wont be enough to matter. i don't want to replace 3 perfectly good steelies, pay to have the tires removed, remounted and balanced. They are on the car from about November to April before i put on the stock wheel/tires. Thanks for any help. Please PM if you's like or pose here.
Regards,
Kyle
running three 6" wheels and 1 6.5" wheel is not something I would recommend. It adversely effect the cars handling
Subarudude2 is offline   Reply With Quote
Old 01-19-2010, 02:51 PM   #881
P 4 T H O G 3 N
Member#: 68339
2010 Impreza WRX
World Rally Blue Micah
Subaru Stars
Year: 2010
Make: Subaru
Model: WRX 5-door Hatchback
Tires Only or Winter Package: 17" Tires Only (on OEM 17x7.5 rims)
Luke,
I will be putting my stock summer tires on my Enkei RPF-1's, and I am looking for a set of Winter Performance tires for snowboarding trips to Big Bear Lakes (primarily) during snow storms. With that said, I need a set of tires that will hold up on the 40-50 mile drive (highway driving) to the bottom of the mountain (where the snow starts), but will also provide some measure of "invincibility" during moderate winter driving conditions.
Please advise
Nick
any of the performance winter tires will be able to meet your needs .. I would probably choose the Winter Sport 3d
P 4 T H O G 3 N is offline   Reply With Quote
Old 01-19-2010, 03:47 PM   #882
aroncranford
Member#: 225925
i got a problem
i have the powerslot bb kit and 17s are all i can clear and i am trying to figure out if anyone that knows of a car that uses 17 steel wheels or knows were to find some 17 in steel wheels ??
i am looking to sell or trade a perfect set of 16 stockers from an 04 with re92s on them looking to trade for just the rims or a set of 17 if i can find them!
HELP PLEASE!
aroncranford is offline   Reply With Quote
Old 01-20-2010, 12:36 AM   #883
MurderedWRX
Member#: 235639
02 WRX Wagon
Java blue
02 WRX Wagon
Southeast Wisconsin
i have a set of blizzak WS60's and these tires eat hardcore... my old tires i was able to kick my car around all over road nice for messing around drifting and what not but now i can barely break her loose these tires are insane and highly recommended .... ride great on dry ground no road noise or vibration!!!! Awesome tire for subarus actually Awesome tire for any car!!!
MurderedWRX is offline   Reply With Quote
Old 01-23-2010, 10:25 PM   #884
cmcnamara
Member#: 219290
2015 WRX
CBS
year:2004
make: Subaru
model: WRX Wagon
tires only or winter package: Tires only
I am looking to buy a very lightly used set (almost new) of Toyo Observe G-02 snow tires and I am looking to see if they are a good snow tire. I am replacing an old set of dunlop snow tires and only put on my winter set up when I head up to the mountain and take them off when I get back. I have heard great reviews about blizzaks and nokians but nothing really about toyo's observe. Any help is much appreciated. Thanks!
Chris
cmcnamara is offline   Reply With Quote
Old 01-25-2010, 02:05 PM   #885
LGT+WRX
Member#: 91119
05/9 LGT-me/FXT-wife
ABP-me/SSM-wifey
Originally Posted by cmcnamara View Post
year:2004
make: Subaru
model: WRX Wagon
Chris
A 2008 Canadian test (French language, Quebec origin?) gave the G0-2 Plus top marks, comparable to the WS60 and IG20, which were their outstanding ("Best" - "5-Star") recommendations for "Touring Tires."
The Toyo Observe Garit KX was their outstanding ("Best" - "5-Star") recommendation for the "Performance Vehicle Tires" category.
I unfortunately can no longer find a valid URL link for the article. Originally, outahere on LGT.com had sourced it from a private .pdf scan via a fellow Subaru enthusiast in Montreal, but it's no longer hosted there.
From my discussions on that article (note that my usual screen-name is TSi+WRX):
Originally Posted by TSi+WRX
It also seems that the Quebec testing also had differences based on tire size, with the touring, performance, and SUV categories utilizing different tire size "standards" for both pricing as well as performance cross-comparison.
I almost wonder if [this] test, with its closer choice of tire to those typically purchased for our fitment, might not be the better test to get advice from, despite its seeming non-quantitative nature, as the "Performance Vehicles" category utilizes a 225/45/17 tire as the construct...... ?
change agent, a fellow LGT.com member in Montreal, then cited the following:
Originally Posted by change agent
Here the bias is toward heavy snow first and then normal snow and ice conditions.
LGT+WRX is offline   Reply With Quote
Old 01-25-2010, 04:39 PM   #886
cmcnamara
Member#: 219290
2015 WRX
CBS
^^Thanks for the info, I actually ended up buying the Garits. I thought they were the G-02 from the pic but sure enough they weren't. I went home last night and actually found that same post somewhere on here.I tried looking for the .PDF too but no luck. I was really pleased to find that most tire retailers and even Subaru recommend the garit kx because of their reinforced side wall.
Old 01-26-2010, 10:46 AM   #887
LGT+WRX
Member#: 91119
ABP-me/SSM-wifey
^ No problem - glad to have been of-service.
Old 01-28-2010, 10:32 AM   #888
CarbonXe
Member#: 211237
82 XJ 750
92 YJ 4.0
Subaru
WRX Premium
Northern NJ
Winter tires only
I found out this morning that the Dunlop tires they put on the new WRX are quite pathetic in the snow, which means it's time to buy some winter tires. I'm pretty set on either the Bridgestone Blizzak LM-25 or the Dunlop SP Winter Sport 3D and I was just curious about the tire size. Should I stick to the stock size, or should I go with a slightly bigger sidewall? No clue if it would help or not...
stick with the stock size and you'll be fine with either of the tires you mentioned
CarbonXe is offline   Reply With Quote
Old 01-31-2010, 10:05 AM   #889
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
Year: 2003
Make: Subaru
Model: WRX
Tires Only 17X8 wheels.
so in april i am moving with a freind to fairbanks. It should be a very wet drive until i get into canada. As far as what im looking for, is mainly tread life, then performance, then price.
being a michelin fanboy i noticed you have mostly suggested the X-Ice Xi2 for similar areas.
others i have seen you suggest are: pirelli sottozero, a continental tire, wintersport 3D, and the blizzaks.
personally after reading through the thread, im pretty set on a set of 235/45/17 michelin X's, but if you have a different opinion id love to hear it. also maybe a little more reasoning as to why.
David Medina is offline   Reply With Quote
Old 01-31-2010, 01:05 PM   #890
superhawk44
Member#: 20264
05 LGT arrestmered
07 Aprilia Tuono
I would suggest a snowmobile.
Old 01-31-2010, 03:49 PM   #891
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Year: 2005
Make: Subaru
Model: WRX Sedan
Tire or winter package: Tires only
205/55/16 on 16x7 2001 RS wheels
One of my old WS-50s has a gash in the sidewall and I don't feel comfortable driving on it. The tire has had a slow leak for a while. The wheel is true.
I was hoping these tires would last me through the end of March, but I guess its just time. I'm looking at the Blizzak WS-60's and the Michelin Alpin PA3's. I've been happy with my WS-50's performance and would assume the WS-60's are similar.
Noah is offline   Reply With Quote
Old 01-31-2010, 07:18 PM   #892
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
i have heard people up there dont like it when you call them "snowmobiles" they call them snow machines or some crap.
personally i call them ice tractors.
Old 02-06-2010, 10:16 PM   #893
Kc2iLq
Member#: 221757
2008 Impreza 2.5i
year: 2008
make: Subaru
model: 2.5i Premium
tires only or winter package: I want to buy tires on steel wheels.
our steel wheels are sold out for the season .... sorry
Kc2iLq is offline   Reply With Quote
Old 02-08-2010, 11:56 AM   #894
Daedalus
Member#: 29049
2007 WRX Wagon
Originally Posted by Daedalus View Post
year: 2007
make: Subaru
model: WRX wagon
Thanks.
I went with the Dunlop Winter Sport 3Ds and I had ZERO issues getting around during the aftermath of the DC area's Snowpocalypes 2010. Most roads were "mostly" plowed with either hard pack snow, or 3"+ of soft/slushy snow on top. No issues at all. Thanks for suggesting them Luke!
Old 02-09-2010, 09:23 AM   #895
SubiWRX
Member#: 209634
2009 Impreza WRX
Gray
year: 2009
make: Subaru
model: WRX Sedan
look at the Winter Sports from Dunlop
SubiWRX is offline   Reply With Quote
Old 02-23-2010, 10:05 AM   #896
hizzah
Member#: 235316
2010 WRX Limited
year: 2010
make: Subaru
model: WRX Hatch
I found a used package of 16" steelies with 205/55/16 Blizzaks, was wondering why they are sized down? How will this affect the car?
What are your thoughts on the use of steelies?
hizzah is offline   Reply With Quote
Old 04-11-2010, 08:25 PM   #897
Jay04WRX
Member#: 34075
2009 CTS-V
Question
I am looking at a set of slightly used Mastercraft Glacier Grip II tires from a local seller. I looked on here and online but I am having a tough time finding a review on this tire. Is it a decent winter tire? I see they sell for around $100 per tire and that seems ok and all I just dont se reivews.
I had Blizzak LM-25's on my last car and they were awesome but I found these at a decent deal. Are they worth it or should I look for a diff set of winter tires?
Jay
Jay04WRX is offline   Reply With Quote
Old 06-11-2010, 02:14 PM   #898
mistersooty
Member#: 193520
2008 Impreza 2.5i
Luke will be getting winter tires for two vehicles in a few months when budget permits;
year: 2008
make: Subaru
model: 2.5i Sedan
tires only orwinter package: tires only
year: 1999
make: Toyota
model: Corolla LE
mistersooty is offline   Reply With Quote
Old 08-16-2010, 02:37 PM   #899
my name is joe
Member#: 171412
year:2006
make:subaru
model:wrx wagon
tires only or winter package: I'm looking for a tire that does well in winter time. We get lots of salt and roads plow'd. When it snows hard here the roads dont get plowed fast enough and there is a blanket of snow everywhere. Some roads in staten island or long island do not get plowed. I also plan on going to PA for some winter paintball and upstate to snowboard. Which tire is good for me? Dunlop wintersport 3d? I dont want the wear to be terrible because there isnt enough snow..
my name is joe is offline   Reply With Quote
Old 08-16-2010, 06:00 PM   #900
dougm12a
Member#: 163638
2008 WRX
I have used the Dunlop 3D's for three winters. They are very good in snow but they absolutuely excell at driving on clear roads when the temperature is 40 degrees or below, including 0 - 20 degrees. They have the feel of a summer tire, handle very well, and are quiet and not harsh on the road. They are by far the best winter tire I have ever owned. As far as wear: I have 16,000 miles on them and they have most of their tread left.
dougm12a is offline   Reply With Quote
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 11:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 12:42 PM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-16-2009 12:34 AM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 12:28 PM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 11:06 PM
