Old 10-04-2011, 02:47 PM   #2126
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
Originally Posted by SubLGT View Post
Yes, performance winter is for you, but if you drive 90-100 on twisty mountain roads you will wear out the winter tires quickly.
haha, correction there, thats my higher speeds on the flat areas. most of the curvy roads I don't get much more than 55-60 in the summer so I expect less than that for winter.
Any suggestions on particular tires. I'm looking at the Michelin Pilot Alpin PA3, Blizzak LM-60, Pirelli Winter 240
bdj238 is offline   Reply With Quote
Old 10-04-2011, 02:52 PM   #2127
krzyss
Member#: 8365
2013 Ford Focus SE
D_Smitt, do you care about noise?
If you care not about noise,wet or dry but ice and snow then you may want studded tires. But if you are in Downingtown, PA then it probably is overkill.
Studless winter tires may be your best choic. Blizzaks WS series are usually leading the way in this category.
Krzys
krzyss is offline   Reply With Quote
Old 10-04-2011, 03:12 PM   #2128
krzyss
Member#: 8365
2013 Ford Focus SE
225/40R18 seems to be odd size for winter tires. Tirerack has 6 winter tires in this size: 1 Run Flat, 2 studless and 3 performance winter: Pilot Alpin PA3 is the best winter tire in the dry, Blizzak LM60 is not available in Europe so the only test is from CR and they are in the middle, Sotto Zero Serie II is solid mid pack in Euro tests but low in CR.
Pick your poison.
Krzys
Old 10-04-2011, 04:16 PM   #2129
n2oiroc
Member#: 141952
15 legacy 16 wrx
Hankook Winter i*Pike
pretty much the same tire.
n2oiroc is online now   Reply With Quote
Old 10-04-2011, 04:19 PM   #2130
n2oiroc
Member#: 141952
15 legacy 16 wrx
Originally Posted by 97 Pimpreza View Post
year: 2004
model: impreza wrx
rims: oem 16"
Looking at getting Blizzaks in either 205/65/16 or 205/60/16 but i'm kinda torn. I plan on running 1" spacers because I could really use the clearance this winter (pizza delivery boy on narrow, windy, and beat-up roads). could someone chime in on these sizes? will the geometry be off really bad with the 65's? rubbing issues?
Also, my one concern with the blizzaks are that I do a fair amount of highway driving as well as hit up the local mountain many times throughout the winter. I have heard blizzaks can get sketchy at highway speeds. any other tire suggestions based on my needs? Maybe the goodyear ultra grip ice WRT (cant find any reviews on them)?
205/65R16 are awful tall, im not positive, but they will probably rub. if you are worried about high speed handling, but still want a great snow, i would get these in a 205/60R16.
http://www.tirerack.com/tires/tires....odel=X-Ice+Xi2
Old 10-04-2011, 04:34 PM   #2131
SubLGT
Member#: 207528
2005 Legacy GT
I agree with the Michelin and Pirelli recommendations krzyss gave, as your priority seems to be for dry and wet traction in cold temperatures. Another tire to consider is the Dunlop Winter Sport 3D.
SubLGT is offline   Reply With Quote
Old 10-04-2011, 05:00 PM   #2132
SubLGT
Member#: 207528
2005 Legacy GT
Originally Posted by krzyss View Post
..........Pilot Alpin PA3 is the best winter tire in the dry, Blizzak LM60 is not available in Europe so the only test is from CR and they are in the middle, Sotto Zero Serie II is solid mid pack in Euro tests but low in CR...........
Krzys
Another performance winter that received high praise from CR, and one we don't see mentioned very frequently here, is the Hankook Winter i*Cept Evo. But I am not aware of any other tests of this tire. FWIW, it came in 2nd overall in the 2010 CR tests. Personally, I would be hesitant to buy a set of new tires on the recommendation of CR alone.
Old 10-04-2011, 05:47 PM   #2133
SWP2011WRXinMN
Member#: 296039
2011 WRX Hatch Base
Accordind to NTB The Generals are backordered until late November. I can't wait that long in Minnesota... Looks like I'll be getting the x-ice.
SWP2011WRXinMN is offline   Reply With Quote
Old 10-04-2011, 09:05 PM   #2134
WantAvant
Member#: 258735
16 Sti base
Wrb
I saw that too, I don't live too far from you so we have the same crappy weather....I can't wait either. Are the x-ice's alot like General's or should I go with Winterforce??
WantAvant is offline   Reply With Quote
Old 10-04-2011, 09:31 PM   #2135
n2oiroc
Member#: 141952
15 legacy 16 wrx
x-ice is a top tier winter tire. the generals are a older design with not as good of a compound, but the tread pattern is great and its a good performer. winterforce suck imo. there are much better "budget" choices.
Old 10-04-2011, 10:34 PM   #2136
SWP2011WRXinMN
Member#: 296039
2011 WRX Hatch Base
I've only run blizzak WS60s and original xice (not the xice xi2) so cant offer an opinion on winterforce. Xices were good on our old celica so i hope the xi2s will be good on my WRX. I'm sure they'll be better than the stocks!
Old 10-04-2011, 11:34 PM   #2137
SubLGT
Member#: 207528
2005 Legacy GT
Other than being round and black, the General Altimax Arctic and the Hankook iPike W409 are not "pretty much the same tire". Different tread design is the most visible difference. And no doubt they differ in internal construction and in rubber formulation.
Old 10-04-2011, 11:55 PM   #2138
n2oiroc
Member#: 141952
15 legacy 16 wrx
they are awful close in tread design.
http://www.discounttiredirect.com/di...rmance&sw=true
Old 10-05-2011, 07:50 AM   #2139
WantAvant
Member#: 258735
16 Sti base
Wrb
So your saying go with the x-ice's then?
Old 10-05-2011, 10:05 AM   #2140
D_Smitt
Member#: 168015
2002 WRX Wagon
MBP
Krzys
I don't care about the noise, but I can't use studded tires because of state law. I was looking at blizzaks yesterday and other tires in that category. I heard of good reviews on those tires, but wanted to see if there is any other suggestion. Thanks for the advice.
D_Smitt is offline   Reply With Quote
Old 10-05-2011, 10:58 AM   #2141
n2oiroc
Member#: 141952
15 legacy 16 wrx
of the choices given, yes. the ws70 and extremewintercontact would also be great choices. cant go wrong with any of the 3.
Old 10-05-2011, 11:05 AM   #2142
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
Yea, it does seem to be an odd winter size but I have to sets of wheels right now and that's what fits em.
Besides if there are only a few to pick from then it makes it easier to narrow down.
I need to look into the 3d I haven't seem them offered in my size yet.
Old 10-05-2011, 12:27 PM   #2143
BananaHands
Member#: 296846
WRX
I want to use steelies tire rack and discount suggest these wheels
http://www.discounttiredirect.com/di...6.5&vid=019120
Will these fit and what size tire is good for them? im very bad with understanding offsets and what not so i want to double check.
i'm also interested in these tires, live in north NJ which do you think is better bang for the buck?
http://www.tirerack.com/tires/tires....23&sortSize=16
thanks
BananaHands is offline   Reply With Quote
Old 10-05-2011, 12:57 PM   #2144
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
If you build your own Tire Rack winter package, it has 16 steelies as an option.
jonklein611 is offline   Reply With Quote
Old 10-05-2011, 01:09 PM   #2145
BananaHands
Member#: 296846
right so what tirerack says will defintely work? the wheels are cheaper from discounttiredirect and the tires are cheaper from local gas station that im friends with so thats why im wondering and not just ordering from tirerack
16x6.5 steelies
Pirelli 210 Sottozero Tires
215/55R16
will work on my car correct?
Old 10-05-2011, 01:23 PM   #2146
Cody
Member#: 42048
03 WRX Wagon
Sonic Yellow
16x6.5 steelies
215/55R16
What Tirerack indicated will work, will most likely work. I'd trust them to get it right. However, not all 16X6.5" steelies are created equal. The shape and offset play a role in them fitting as well. So you'll need to do a test fit to be sure.
Cody is offline   Reply With Quote
Old 10-05-2011, 04:42 PM   #2147
n2oiroc
Member#: 141952
15 legacy 16 wrx
my winter wheels/tires showed up today! 205/60R16 ws70's on steelies. went 205/60R16 because they are only .3" taller than stock and $21 a piece cheaper than 215/55R16's.
Old 10-05-2011, 05:10 PM   #2148
shawzito
Member#: 296873
Hi Guys!
Have a 2011 subaru WRX 5-door. Quick question - I live in San Francisco but I plan on making a weekend trips to tahoe during snowboarding season (probably a 4 hour drive there and a 4 hour drive back). I typically go to kirkwood.
I'm going to get some new wheels and tires. I was thinking that I wouldn't want to change them every time i go up to tahoe, and probably wouldn't need dedicated snow tires since I don't live up there, but I wanted to get your guys suggestions. Is there a good all weather tire that you would recommend, or should I get a dedicate snow tire and drive 3.5 hours on freeway before I actually get to the snow?
Anyone else in a similar situation? How did they handle this?
shawzito is offline   Reply With Quote
Old 10-05-2011, 05:15 PM   #2149
n2oiroc
Member#: 141952
15 legacy 16 wrx
Originally Posted by shawzito View Post
Hi Guys!
conti dws is great in the snow for an all season. i would go with those if you only want 1 set of tires. if you can have 2 sets i would get dunlop 3d's. they wear like iron and handle as good as most performance all seasons.
Old 10-05-2011, 05:33 PM   #2150
97 Pimpreza
Member#: 123693
2004 Impreza WRX
Red
Which Blizzaks are you referring to? There are several different models. None of the current Blizzaks are dangerous on the freeway, if you stay within their performance limitations.
I'm thinking about getting the WS70s. I read in a review somewhere (can't recall or find the thread) that the blizzaks the reviewer had (cant remember the model) were "squirelley above 70". probably an older model with a lower rating. the WS70s are a T-rating (118 mph).
97 Pimpreza is offline   Reply With Quote
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 10:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 11:42 AM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-15-2009 11:34 PM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 11:28 AM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 10:06 PM
