Old 10-12-2011, 09:50 PM   #2201
wayward167
Member#: 253998
13 BRZ
Originally Posted by SubLGT
Continental EWC or Nokian Hakka R
I agree...I went through snow over my hood last yr using the conti EWC...
Went to a 16 this yr so I'm ordering the hakka R's to try them
wayward167 is offline   Reply With Quote
Old 10-12-2011, 11:32 PM   #2202
technique00
Member#: 239422
2010 WRX ltd
dark grey
Originally Posted by cixelsyD View Post
http://www.teamilluminata.com./Shop/Braid/compcast.htm
my wheels
$225 per wheel $76 per tire
paul at teamiluminata was great
wheel are hubcentric and have steel lug seats
Wow this company is AWSOME! All my wheel issues SOLVED! I love small companies that really care about what they do and about their customers. Sory for thinking yours were enkeis
technique00 is offline   Reply With Quote
Old 10-13-2011, 03:07 PM   #2203
ShawnRS
Member#: 18797
MY06 WRX Wagon
Hi there
I have made it to page 56 and can't read anymore.
Are the, "15X6.5 Sport Edition D5", rims still made? These are the ones that fit the MY 2006 WRX sport Wagon, right? They can fit over the the stock 4 pots?
I am trying to get the specs so I can order the right 15" wheels for the coming winter.
I have called TireRack and 1010tires (preferred to avoid duty) both people were not sure what I was talking about.
Thank you for your help.
Shawn
ShawnRS is offline   Reply With Quote
Old 10-13-2011, 03:21 PM   #2204
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
^ Tirerack shows that 16" is the smallest size that will fit.
They still list the D5, but not on the product page.
jonklein611 is offline   Reply With Quote
Old 10-13-2011, 03:29 PM   #2205
technique00
Member#: 239422
2010 WRX ltd
dark grey
you shouldn't necesairily go by that though. Tirerack has a threshold for comfort that they wont go below. For example, they wont show the enkei RC-G4 15" for the 2010 wrx but but both luke and Enkei international confirmed that they'll clear the breaks by 2mm, which enkei says is more than sufficient, and seing as they are the rims used by many professional wrx rally cars i don't see any reason to doubt it.
Old 10-13-2011, 03:31 PM   #2206
technique00
Member#: 239422
2010 WRX ltd
dark grey
i'm really on the fence with 15" rims my self. I'd really like them for peace of mind and aesthetics, but any that are worth getting will run me at least 930$ and since i'm not doing any rallying, the question is whether or not its really worth it vs a 17" stocky and when I could just put the money towards a nice set of summers.
Old 10-13-2011, 03:53 PM   #2207
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Hi Luke, all:
year: 2006
make: Subaru
model: Impreza STI
tires only or winter package: Tires only
I'm looking for a performance snow tire to replace my V-rated Bridgestone Blizzak LM-25. I was happy with these tires but it looks like they only come in RFT for my size now (225-45/17) -- not interested in RFT. I'm hesitant to experiment with new brands but I have been satisfied with Dunlop summer tires before. Is the new V-rated Dunlop SP Wintersport 3D a good replacement for the LM-25? H-rated tires are not adequate for this application. What are your recommendation(s)?
For a different car, do you know the wheel weights for these steelies that are currently on sale at Tirerack:
"16X6.5 New Steel Wheel Black Painted for 2006 Subaru Outback Wagon 2.5I Base Model"
And how is the weight compared to the old steelies from Tirerack (circa 10/2007):
"16x6.5 5-100 et50 cb56 st new" (for 2006 Subaru Outback Wagon 2.5I Base Model)
Thanks in advance!
Mike Costin is offline   Reply With Quote
Old 10-13-2011, 04:18 PM   #2208
Mendo
Member#: 271134
2011 WRX Sedan
year: 2011
make: Subaru
model: Impreza WRX Sedan
Theres a ton of information here and I've sifted through enough to know what I want.
I just need above all else, something that wont put wear and tear on my car. I know AWD cars can be sensitive to tire diameter changes and I can't afford to screw that up so I need to do this legit. Same offset and everything.
I'm looking to go the 16"/snow tire route if at all possible, otherwise I'll have to put all seasons on the stock wheels, which I would like to avoid due to cost/performance compromises.
I know people are just going steelies/snow tires but how will this effect the AWD system?
Any help would be greatly appreciated. I'm capable of finding the tires I want, I just need help with the technical aspects of this conversion.
thanks.
Mendo is offline   Reply With Quote
Old 10-13-2011, 04:27 PM   #2209
jonklein611
Member#: 117776
WR Blue Pearl
Originally Posted by Mendo View Post
year: 2011
make: Subaru
thanks.
As long as all 4 wheels and tires are the same (and have the same amount of tread depth), the 16" setup will not affect the AWD.
16" old WRX wheels and snows works fine on mine:
Old 10-13-2011, 04:31 PM   #2210
technique00
Member#: 239422
2010 WRX ltd
dark grey
y does tread depth matter?
Old 10-13-2011, 04:49 PM   #2211
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
I think they were reassuring the previous poster who lamented, "I know AWD cars can be sensitive to tire diameter changes"
(2 tires of the same spec will have a difference in diameter that is twice the difference in tread depth between the 2 tires -- ignoring air pressure, loading, etc.)
Old 10-13-2011, 05:10 PM   #2212
jonklein611
Member#: 117776
WR Blue Pearl
The answer is in your owners manual:
STI:
NOTE
. If the tire pressures are not correct and/or the tires are not all the same size and brand, the rear differential will be heavily loaded when the vehicle is driven, resulting in an abnormally high oil temperature.
. The rear differential oil will deteriorate if its temperature increases enough for the rear differential oil temperature warning light to illuminate. It is advisable to have the rear differential oil replaced as soon as possible.
All Subarus:
When replacing a tire, make sure you use only the same size, construction, brand, and load range as the original tires listed on the tire placard. Using other sizes, circumference or construction may result in severe mechanical damage to the drive train of your vehicle and may affect ride, handling, braking, speedometer/odometer calibration, and clearance between the body and tires. It also may be dangerous and lead to loss of vehicle control.
The following precautions should be observed in order to ensure that the Vehicle Dynamics Control system is operating properly:
All four wheels should be fitted with tires of the same size, type, and brand. Furthermore, the amount of wear should be the same for all four tires.
Old 10-13-2011, 05:24 PM   #2213
technique00
Member#: 239422
2010 WRX ltd
dark grey
thank you. this is good stuff because subaru provided me ONE tire onder warranty when there was a bubble in the sidewall of a factory tire. Clearly they should've provided me with 4. I have my 30,000 checkup on tuesday. I'm highlighting this and bringing it to them.
Old 10-13-2011, 05:45 PM   #2214
jonklein611
Member#: 117776
WR Blue Pearl
How many miles had been on the car when the tire got replaced? How much of a difference was there in wear? If the difference is small enough, then it's no big deal. If it was a few 32'nds then it might be an issue.
Old 10-13-2011, 05:59 PM   #2215
technique00
Member#: 239422
2010 WRX ltd
dark grey
well i dont notice much of an issue when i'm driving, but there had been appx 21K miles on the tires when the new one was put on
Old 10-13-2011, 06:21 PM   #2216
SubLGT
Member#: 207528
2005 Legacy GT
............Is the new V-rated Dunlop SP Wintersport M3 a good replacement for the LM-25? H-rated tires are not adequate for this application. What are your recommendation(s)?.........
The Dunlop M3 is the old model, prior to the WinterSport 3D. The newest WinterSport is the 4D, not yet available in North America AFAIK. The 3D is an excellent replacement for the LM25.
SubLGT is offline   Reply With Quote
Old 10-13-2011, 08:28 PM   #2217
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Thank you sir
I can't find anything in the press release for the 4D that indicates when they'll be available in North America
Does anyone know when the Dunlop WinterSport 4D will be available in the US?
I can wait 1-1.5 months but then I'm going to have to pull the trigger on whatever is available
Old 10-13-2011, 09:25 PM   #2218
Plasma2011WRX
Member#: 291897
Default Winter setup
Does anyone know if 205/60R16 will work on 2011wrx sedan?
Plasma2011WRX is offline   Reply With Quote
Old 10-13-2011, 10:12 PM   #2219
n2oiroc
Member#: 141952
15 legacy 16 wrx
yes!
n2oiroc is offline   Reply With Quote
Old 10-14-2011, 08:31 AM   #2220
ShawnRS
Member#: 18797
MY06 WRX Wagon
Question
BUMP: Is Luke still kicking around?
I tried emailing him last week and Tirerack since then, but have not heard back.
Thank you
Shawn
Originally Posted by ShawnRS View Post
Hi there
Shawn
Old 10-14-2011, 08:33 AM   #2221
lordgrinz
Member#: 293423
WRB SPT/Stock
Just ordered the 16" Steelies with the Dunlop Wintersport 3D's, not sure if the order supported NASIOC, but I did use the link. I was hoping it would show NASIOC on the order, but I don't see it.
lordgrinz is offline   Reply With Quote
Old 10-14-2011, 05:59 PM   #2222
warmitup
Member#: 158926
11 WRX 4dr ltd
spark silver metallic
Default My winter set-up
I just picked up my order from Discount Tire. 16" steelies with Michelin x-ice xi2. 205/55r16. No tpms, I'll deal with the flashy light! $70 michelin rebate and a $60 rebate for the tire/rim combo for using the car care card with 6mos 0%. Total out the door before rebates was $850.
I don't think it'll look half bad! Bring on the snow!!
-Chris
warmitup is offline   Reply With Quote
Old 10-14-2011, 06:40 PM   #2223
rkjunior
Member#: 112220
2011 WRX 5DR Premium
2011 WRX 5Dr..
I have set of 215/45/17s left over from my 06 but they need wheels.. I can run these on my 2011 with no issues, right? What wheel should I look to get? TireRack is recommending anything from a 17x7.5 to a 17x9.... 17x7.5e48 should be ok, right?
rkjunior is offline   Reply With Quote
Old 10-15-2011, 01:11 AM   #2224
jonboy96706
Member#: 296469
2011 wrx sti
wr blue
I'll try continental extreme contact dws tires. Couldn't decide on which winter tires I should get. I have a 2011 WRX sti sedan. I'll post my experience with these tires when the snow hits Colorado springs.
jonboy96706 is offline   Reply With Quote
Old 10-15-2011, 11:21 PM   #2225
evistor
Member#: 228927
2005 Impreza WRX STi
WR Blue
This might been asked before but I couldn't find it.
So I am using stock BBS rims (8" wide) on my 05 STI.
would it be better if I go for narrower snow tires (205/50/17)
or should I just stick with stock size (225/45/17)
I recall hearing that its better to have narrower tires for snow so I just want to make sure before I purchase.
Thanks
evistor is offline   Reply With Quote
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 11:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 12:42 PM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-16-2009 12:34 AM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 12:28 PM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 11:06 PM
