Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-01-2008, 09:10 PM   #1
dlatourette
Member#: 144885
Default VSS - How many pulses per wheel revolution '05 STi Manual
I've checked the archive, googled the known Suby universe, and still not found the definitive answer of how many pulses the '05 STi ecu needs per wheel revolution. Anyone have this info? I could sure use it!
dlatourette is offline   Reply With Quote
Old 10-03-2008, 10:29 AM   #2
JJ's Red Wagon
Member#: 155937
1995 Impreza w/EJ255
Red
I don't know what your trying to do, so I dont' know if this helps. I have an MY04 Sti ecu in my car and I am using a hall effect speed sensor setup at the hub for my vss. I am using 10 magnets to get the proper speed reading at the ecu. So I would assume an answer of ten pulses. Now mind you this is with a 215/45/17 tire that I am getting the right speeds + or - 1mph. I would also assume that this would not be any different for MY05 since I have never heard of any issues when people swap trannies from year to year.
JJ's Red Wagon is offline   Reply With Quote
Old 10-03-2008, 02:32 PM   #3
dlatourette
Member#: 144885
STi engine in a Porsche 914. I need to make a trigger wheel to go on the CV joint flange and need the pulse count to know how many teeth or notches to put in the trigger wheel. I've heard 5 pulses per wheel rev and now 10!
Thanks for the info!
Old 10-03-2008, 03:34 PM   #4
Broken Motorsports
Member#: 187514
STI in a 914! awesome setup. Lets see some pics of the project.
been contemplating picking up another 914 just to do this particular swap and keep my original 74 alone. Just passed up one at auction in CT. 74 2.0 car with appearance pkg and gauges, went for $1450 with known mechanical problems.
Broken Motorsports is offline   Reply With Quote
Old 10-03-2008, 09:12 PM   #5
johnny p
Member#: 141232
02 v7sti wagon
signal green
User member quick108 has a picture posted of the trigger wheel he made for his sti project.
johnny p is offline   Reply With Quote
Old 10-03-2008, 09:41 PM   #6
dlatourette
Member#: 144885
Checked it out - thanks. My concern is that he only needed the wheel speed for his speedo. I need it for the ECU so the DBW works properly. I don't really care if the pulses are correct for the speedo! It may not be an issue either way.
Old 10-04-2008, 10:06 PM   #7
JJ's Red Wagon
Member#: 155937
Red
Dlatourette, I think it really is going to depend on the size tire as to how many pulses you need. I can tell you though that I did use only 5 magnets for the longest time and even though it read about the half the actual speed at the ecu it never created any driveablity issues or codes/check engine light.
Old 10-06-2008, 03:48 AM   #8
dlatourette
Member#: 144885
Here are a couple pics of the car. It is a customer's long(er than imagined) term project we've been working on.
http://www.davesport.com/cgi-bin/davesport/sub914.html
Old 10-07-2008, 09:05 PM   #9
johnny p
Member#: 141232
02 v7sti wagon
signal green
smallcarperformance has a Hall effect sensor kit with 5 pulse ,that will mount up to the CV's
You could just add 5 mag's if needed.
Old 10-23-2008, 04:40 AM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
What size tires will you use on the rear wheels of the Porsche?
Old 03-30-2009, 09:20 PM   #11
icanfly
Member#: 176929
2005 STI Powered Dub
Carbon Black
pics anyone?
icanfly is offline   Reply With Quote
Old 04-02-2009, 04:28 PM   #12
tbox56
Member#: 199784
I checked at small car a while ago for my own conversion project, and their speed sensor does not mount directly to our axels... spacing is all off...I had heard that 5 pulses comes close to replicating the subaru sensor, but i wouldn't trust it for the spedometor...
Thomas
tbox56 is offline   Reply With Quote
Old 04-07-2009, 10:22 AM   #13
icanfly
Member#: 176929
Carbon Black
I would also like to hear more from someone that has this setup and working. Quick108 seems to be MIA? Anyway anyone up and running with this solution please post details, photos of install part numbers ect... anyone?
Old 04-07-2009, 05:53 PM   #14
johnny p
Member#: 141232
02 v7sti wagon
signal green
Some have used a screw in VDO hall effect sensor with mechanical speedo's
I know someone who has also used a vanagon speedo cable inserted into a Subaru VSS sending unit .
Old 04-07-2009, 10:32 PM   #15
icanfly
Member#: 176929
Carbon Black
johnny can you get more info on that vanagon rigging? I have "cable-out" on my Porsche trans and that sounds like an interesting setup.
STi owners: how many miles per tank? (stock STi's only) avatarr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 61 03-19-2004 03:29 PM
how many miles per tank are you guys getting? newb General Community 46 01-30-2004 07:12 PM
Mach III Turbo Users: How many shaves per blade? WHTWRX Off-Topic 25 05-15-2003 07:19 PM
How many pulses per km? d00f Transmission (AT/MT) & Driveline 1 07-15-2002 04:02 PM
how many miles per tank are you getting STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-09-2002 11:54 PM
