Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 10-02-2008, 02:07 AM   #1
x Mr Awesome x
Member#: 180305
2008 WRX
Metallic Grey
Default VF39 Swap in 2008 WRX What do I need?
I want to buy the vf39 from my friends 2008 sti and intercooler, if possible. I know a lot of guys have done this swap. Can anyone just tell me exactly what I need to make this happen? Thanks a million for anyone that helps!
-ben
x Mr Awesome x is offline   Reply With Quote
Old 10-02-2008, 02:22 AM   #2
preacher#1
Top Scoob 022
Member#: 129894
FSTI '04 4EAT Sierra
Gold Metallic 20G-XT, EWG
Lets see...It depends on your current set-up, but assuming you are completely stock...
You will need,
Definitely-
engine management or tune,qualified mechanic,hoses & y-pipe,
Possibly-
gaskets, bpv/bov, fuel injectors, fuel pump
A higher flowing downpipe wouldn't hurtcha....
I'm prolly missing a few things.....GL!
preacher#1 is offline   Reply With Quote
Old 10-02-2008, 04:16 AM   #3
x Mr Awesome x
Member#: 180305
2008 WRX
Metallic Grey
Probably should mention that I have an Invidia catted downpipe, SPT Exhaust, and soon to have Cobb Accessport. Okay. When we were eyeballing the engine bays, particular bolt points were very different making 'swaps' unlikely. Anybody that has done this care to enlighten me?
Old 10-02-2008, 04:23 AM   #4
Makako54
Member#: 110013
2006 Impreza WRX
I think your gonna need the intake manifold and the throttle body from the 08 or a previous WRX.
Makako54 is offline   Reply With Quote
Old 10-02-2008, 05:36 AM   #5
x Mr Awesome x
Member#: 180305
2008 WRX
Metallic Grey
So doing some research and noticed the 08 stis run a VF48, not the VF39 that I was told. So this would be the turbo I'd be looking to purchase and swap. I need as much info as I can get!
Thanks again,
-ben
Old 10-02-2008, 11:05 AM   #6
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Larger TMIC or FMIC. Fuel pump. Your injectors will be fine for the VF series turbo. You're correct about the vf48 and not the vf39. You will NOT need a new intake manifold or a new TB. You don't NEED the fuel pump, but it acts like insurance for your car and your new toys and I'd def. recommend it. You might need a new BOV depending on the amount of boost you're wanting to run, but I'm not sure on the 08+. I know on 02-07 WRX, the stock BPV starts leaking around 20+psi. Another thing to think about is a MBC to net higher boost. But I would only recommend that with a protune. Not an OTS map from Cobb.
ThreeEleven is offline   Reply With Quote
Old 10-02-2008, 11:47 AM   #7
Cyni
Member#: 161822
2008 WRX
Dark Grey Metallic
Yes, you DO need to change out the intake manifold.
Our car has a Legacy Style turbocharger, and to use an older style WRX or STi turbo, you'll need to at least do the following:
Intake Manifold/Drive By Wire Throttle Body
Upgraded TMIC
Turbo
Cyni is offline   Reply With Quote
Old 10-02-2008, 12:43 PM   #8
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
he's not using an older style turbo? he's using an 08 sti's vf48
Old 10-02-2008, 12:48 PM   #9
camber
Member#: 128746
-ben
I wait for the tuned numbers of VF-52 from the WRX 265. It's said(and supposdly confirmed by people in the know) to be the same turbo as a VF-48 but with a compressor cover to match the LGT/new WRX style TMIC.
camber is offline   Reply With Quote
Old 10-02-2008, 12:49 PM   #10
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
oh yeah, I forgot the 08 wrx tmic are baby squares. Might be hard to swap out the intercoolers.
Old 10-02-2008, 02:16 PM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
08 sti's still uses the same 'setup' as the older sti.
they did not switch intake manifold.
So in order for the turbo to work, he'll have to upgrade the tmic and intake manifold (dbw)
Nuke209 is offline   Reply With Quote
Old 10-02-2008, 03:41 PM   #12
camber
Member#: 128746
If he goes with a VF39 and wants to retain a TMIC. He has two options.
Do a full STI swap TMIC, Intake manifold and turbo or buy one of these TMICs http://www.tuningalliance.com/produc...c15f8fd45b95fb
with the right elbow to make it work.
Also, you can go FMIC with VF39.....
Although, the most plug and play option would be to get your hands on a VF-52. Which would mean just swapping out the turbo. However, I would wait to see if the tuned results for these turbos, match a tuned VF-39/48 power.
Old 10-02-2008, 04:04 PM   #13
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Ok, so you're saying between an 08 wrx and the 08 sti turbo swap, he'd have to swap his intake manifold as well? Why would you have to do that?
Old 10-02-2008, 04:16 PM   #14
camber
Member#: 128746
If he wants to use an STI style turbo and retain a TMIC the two options are:
1. do the full STI swap to use the STI TMIC(the STI TMIC won't mount up to the new turbo style or intake)
2. buy the Tuning Alliance TMIC and the appropriate elbow.
Old 10-02-2008, 04:21 PM   #15
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
^well stated. I knew the intercoolers were wierd and that the intake manifolds werent the same but I didn't know that the 08 STi's were so much different. I also didn't know that they haven't started making aftermarket TMICs for the 08 WRX.
Old 10-02-2008, 04:39 PM   #16
camber
Member#: 128746
They have been making aftermarket TMIC for the '08 WRX since '05
Just that they happened to be for the Legacy GT
Old 10-02-2008, 04:50 PM   #17
blkwrx06
Member#: 190753
Thanks again,
-ben
Upgraded TMIC
Turbo
These are correct
blkwrx06 is offline   Reply With Quote
Old 10-02-2008, 05:47 PM   #18
Big_Red
Member#: 189497
2008 WRX 5 door
so your saying the new wrx's arent drive by wire?
Big_Red is offline   Reply With Quote
Old 10-03-2008, 12:37 AM   #19
sv sti
Member#: 190802
fuel injectors
sv sti is offline   Reply With Quote
Old 10-03-2008, 02:04 AM   #20
jmun671
Member#: 178919
2008 WRX 5-door
Here's some reference info for you. I found this by searching "STI swap" on legacygt.com only to be led back to NASIOC but a search tip is to use "Search Titles Only" in the advanced features.
Linked from legacygt.com
http://forums.nasioc.com/forums/show....php?t=1184171
Original legacygt.com thread
http://www.legacygt.com/forums/showt...light=sti+swap
These should help you a bit more I hope
J
jmun671 is offline   Reply With Quote
Old 10-03-2008, 11:30 AM   #21
BlackHole
Member#: 85525
05 LGT Wagon 5MT
ABP
Another simple approach is to find a VF40 compressor cover from an 05+ Legacy GT and have it machined to fit the VF39 compressor wheel. No need for an STi swap and you can use Legacy GT TMICs.
BlackHole is offline   Reply With Quote
Old 10-03-2008, 05:47 PM   #22
stealth06wrx
Member#: 131568
2006 WRX to 2015 WRX
OB Swirl / DGM
the 08 wrx has a legacy type turbo and thus it cannot use an sti turbo without swapping the intake manifold which would be a pain i think.
stealth06wrx is offline   Reply With Quote
2.5 RS swap in 02 WRX...What is needed? Tr2laozboi Newbies & FAQs 7 01-02-2010 12:11 AM
Closed Deck EJ20G swap in 02 WRX??? What esle do i need? Wrx_Fan_0717 Built Motor Discussion 13 03-06-2009 06:01 PM
vf39 turbo on 2.0 wrx what do i need for the turbo???? subaruwrx07trmaniac Newbies & FAQs 26 01-07-2009 04:57 PM
Doing an AT fluid swap in a few days...do i NEED to change the filter? kaisersouse Normally Aspirated Powertrain 8 08-30-2005 11:14 PM
WRX/STI Radiator in 2000 RS, what do I need amorton Normally Aspirated Powertrain 1 07-15-2005 07:39 PM
