Old 10-02-2008, 01:45 AM   #1
shinji666
Member#: 152450
2001 Impreza 2.5RS
Default STI block/Turbo in the future Question
Bad day for me as my engine (EJ251) seems to have some issue (huge sound from internal, barely run). My friend told me the engine seems to be gone. I'm thinkin of getting STI block first and planning to turbo it in the future (need to save $$ for turbo, proper EMU, etc). Can i run 2.5RS stock head/ecu on STI block w/o turbo? I know the CR will be much lower w/ the STI block. But i'm not sure if the car will still run w/ only STI block and other stock RS parts (head,ecu).
PS - i can't swap STI beacuse it will cost me way too much here in Canada (12K for STI).
sorry if i sound stupid im pt new to subaru. My car is 2001 impreza 2.5RS (EJ251)
shinji666 is offline   Reply With Quote
Old 10-02-2008, 10:52 AM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
The car will run, but it'll be slower than stock even, especially in the higher rpms!
jey is offline   Reply With Quote
Old 10-02-2008, 05:19 PM   #3
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Check out crawford performance's blocks- they have good stuff overall.
u2_m4r1n3 is offline   Reply With Quote
Old 10-06-2008, 01:22 PM   #4
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
You can get used EJ251 longblock for pretty cheap.
Dont go EJ257 unless you are going turbo. Timing will be way off from a 10:1 to an 8.4:1.
maxiav is offline   Reply With Quote
Old 10-07-2008, 02:33 AM   #5
VIsubi
Member#: 187834
06 2.5i impreza
Red
what about an 06 2.5i with SOHC heads and an EJ257 block running stock ECU plus say AVO turbo kit...this is an easy solution seeing as the SOHC heads flow better than that of the DOHC heads..is it possible..I won't be running just with out turbo its so I can have a beefy block to hold boost really..plus imjectors aswell too.
VIsubi is offline   Reply With Quote
Old 10-07-2008, 09:15 AM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
I am currently running a fully sleeved, balanced and blueprinted cobb block on my (sort of) stock heads....no turbo. about an 8.0-1 CR currently....
does it run well? Yes...
is it slow as ****? yes
an sti block swap will be a great way to avoid wiring, and be a MUCH easier install. BUT I only went this route due to having to pass emissions... if I where going to use a Full stand alone ECU, I would DEFINATLY have just done a full STI (us or JDM) swap.
IllNastyImpreza is offline   Reply With Quote
fs: factory 2007 sti vf43 turbo in the box swift2fly SCIC Private Classifieds 10 09-16-2008 12:09 PM
Will there be a clutch less manual for the US STI in the future? Darkstar News & Rumors 2 01-07-2003 01:43 AM
Possible turbo in the future for MY2001 2.5RS. Which kit is recommended? jay25RS Normally Aspirated with bolt-on Forced Induction Powertrain 3 11-25-2002 12:30 PM
