Old 10-02-2008, 02:49 AM   #1
ajohnson360
Member#: 169086
2002 Impreza WRX
Maroon
Default 02 WRX engine swap to...
Would this engine "easily" swap into my 02? If not (or even if so) what engines should I look for to make a relatively easy conversion? What else do I need to replace? Tranny?
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
Last edited by ajohnson360; 10-02-2008 at 02:49 AM. Reason: omitted important info.
ajohnson360 is offline   Reply With Quote
Old 10-02-2008, 09:41 AM   #2
Mindravel
Member#: 189540
Dark Blue
That engine will work but you will need the TMIC, ECU, engine harness, dash harness, the hvac controls and boxes under the dash(blower box etc...), and would most likely want to get the Instrument cluster. Plus anything the engine is missing.
Unless you want to just use your ECU and wiring, then all you need is a cam angle sensor from Gruppie-s. The AVCS will not work if you do it that way. And you will have to get a tune before you drive your car.
There are a couple of good threads if you read through them and they will tell you everything you will need and all the differences between the years. If I was you I would look into those threads and see which route you want to go.
Chris
Mindravel is offline   Reply With Quote
MY2003 WRX engine Swap to STi motor. FireSooby Subaru Conversions 4 01-26-2009 05:08 PM
Complete 02 wrx engine swap 8k miles sjrexwagon02 Engine/Power/Exhaust 0 12-20-2007 07:54 AM
no wiring(plug and play) for 02 rs to wrx engine swap? warpspeedwrx Subaru Conversions 3 11-09-2004 07:23 PM
02 wrx engine swap yamaha1995 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-22-2004 05:28 PM
Has anyone done a 02 WRX engine swap into a 93-96 Impreza? Homemade WRX Subaru Conversions 6 11-06-2003 12:14 PM
