Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Vendor Classifieds
Closed Thread
Old 10-02-2008, 02:03 PM   #1
Defiant Autospeed
Vendor
Vendor Sales Rating: (29)
Member#: 155450
2007 FXT
Default Free Overnight shipping on Accessports and UTECs
We are now offering, yup you guessed it. Free overnight shipping on ALL Accessports.
Order by 2pm central Monday through Thursday, have it in your hands the very next day.
Order it after 2pm or on a Friday/Saturday/Sunday and you will receive it Tuesday
08 WRX AND STI ACCESSPORTS IN STOCK READY TO GO!
02-07 WRX AND STI ACCESSPORTS IN STOCK
LEGACY GT ACCESSPORTS IN STOCK!
We also carry the TurboXS UTEC Delta if you are looking for yet another options.
What is the UTEC Delta?
Its a very powerful piggyback plug and play engine management system that plug in right along with your factory ECU. Do not make the mistake of thinking piggyback means its not capable or advanced. This is NOT a piggyback like you would normally think of one. This is closer to a standalone than it is to a normal piggyback.
Check out what it offers.
PLUG & PLAY: Installs in minutes on top of the factory computer using all the factory connections.
ADDITIONAL FEATURES: Drag racing launch control (secondary rev limit used during launch). All UTEC software downloads and upgrades are free and available from Turbo XS's website.
5 MAP MEMORY: 5 maps can be stored at a time, and using the remote map selector, you can quickly switch into valet mode, stock mode, nitrous, or race fuel maps with the click of a switch.
ON-BOARD DATA LOGGING: Displays all necessary data required for tuning, including wideband AFR when used in conjunction with the Turbo XS Tuner.
COMPLETE IGNITION TIMING CONTROL: No need to worry about the factory ECU pulling timing anymore; be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map
FUEL CONTROL: Controlled via MAF sensor signal offset, tune stock and larger than stock injectors; pre-set injector correction (just type in the size!).
LOAD REFERENCE: MAP (manifold pressure)
CLOSED LOOP BOOST CONTROL: Programmable via throttle Position and RPM. No more re-adjusting the boost controller due to changes in temperature or altitude. Keeps boost low while in closed loop fuel mode for reliability.
KNOCK CONTROL: Automatically retards timing when the knock is detected safeguarding against engine damage. Adjustable knock threshold, timing correction, and duration.
END-USER PROGRAMMABLE: Fine tune maps via a laptop equipped with a serial cable and Hyperterminal.
FUEL, TIMING, AND BOOST ARE USER-PROGRAMMABLE: in 250rpm increments up to 9000rpm over 10 load sites.
BUILT-IN PROGRAMMABLE SOLENOID CONTROLLER: Control nitrous, water injection, intercooler water spray or any other solenoid device.
PRE-PROGRAMMED BASE MAPS: Standardized maps are available for common setups (i.e. turboback exhaust, upgraded intercooler, bigger turbo & injectors, etc.) Maps can be uploaded and downloaded easily
The UTEC is also currently the only non standalone engine management system that offers the ability to run true Speed Density based fueling! This allows a smoother and wider powerband, which will make the car not only faster, but more enjoyable to drive! You can also run the loudest BOV you can get your hands on, with no fear of the rich condition when it vent! PSSSSSSSSSSSSHHHHHHHHH!
Want to do your own tuning? You will need a wideband Air fuel setup regardless of what Engine management solution you choose. We offer the TurboXS Tuner, which is their wideband gauge that seemlessly integrates into the UTEC datalogging without needing to use 2 cables to your computer/laptop. As well as a few other options.
Package deals with downpipes and full turboback exhaust systems available to make it a one stop shopping experience to get you that Stage 2 setup goodness
If you are local, The free shipping still applies as these come from my distrobution center. However PM me and we can work something out for those picking up direct from me.
Of course I do offer more than just Accessports and UTECs. I carry all your favorite brands From APS, Perrin, You name it. I can help you plan out a mod path for any budget or goal, from a mild day to day setup, to an all out trackday warrior.
Now offering Brake upgrade packages with Powerslot/Stoptech rotors, Hawk, Axxis and Ferodo pads, as well as Technofit and Goodridge lines. With the Best brake fluid out there, Motul RBF600!Suspension upgrades from Perrin, Cobb, Cusco and Whiteline!
Gauge package specials from Defi, Autometer and AEM!
Sickening TurboXS specials!
As always, advice is always free, even for those of you who arent (or arent yet ) customers. I like helping the community out.
*at the moment, no Kartboy or Samco, but I very soon that will change *
Defiant Autospeed is offline
Old 10-09-2008, 02:48 PM   #2
YourMother'sLover
Member Sales Rating: (33)
Member#: 76565
CLXX Stricta Parata
Neci!
dave can you get me a pep mil eliminator for a 02 WRX? Let me know how much.
YourMother'sLover is offline
Old 10-09-2008, 06:47 PM   #3
Davenow
Member Sales Rating: (21)
Member#: 23676
PM'd ya
Davenow is offline
Old 11-10-2008, 10:48 PM   #4
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Bump for end of year porting specials New thread coming soon.
Old 12-02-2008, 12:44 PM   #5
Butterz
Member Sales Rating: (25)
Member#: 21205
2004 WRX Wagon
Brown
Can you PM me a price on the UTEC Delta. Just curious, thanks!
Butterz is offline
Old 12-13-2008, 01:45 AM   #6
TJ
Member Sales Rating: (9)
Member#: 41735
I'm on your lawn
do something about it
I need some Brake fluid. PM me please
TJ is offline
Old 12-14-2008, 05:42 PM   #7
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Blinker or non blinker?
Old 12-14-2008, 08:20 PM   #8
TJ
Member#: 41735
I'm on your lawn
surprise me
but more ATE super blue
TJ is offline
Old 12-18-2008, 06:24 PM   #9
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
I have a part number for some muffler bearings, if I get that for you, how much will shipping be to 77003?
samagon is offline
Old 12-26-2008, 03:59 PM   #10
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Bump because the sale prices end VERY soon!
625.50 shipped till Jan 1, OVERNIGHT!
Old 12-28-2008, 04:42 AM   #11
Javwrx
Member Sales Rating: (31)
Member#: 38875
dave well since i cant get what i want on the sti,its going to be put aside and built for a new route.
TurboXS RFL
need the race pipe/dp for 44mm ewg setup, so price on a turboxs rotated turbo kit, perfer GT35rish or bigger
header
aps 525 fmic, with blow thru
injectors 850ish range.
alky kit
take your time tho, on getting back to me, as i will be taking my time on this new route.
Javwrx is offline
Old 01-04-2009, 05:35 AM   #12
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
TurboXS RFL
header
alky kit
Phone has been acting up on me today. Worse than yours yesterday
Ill call you and we can hammer out some ideas.
Old 01-19-2009, 05:08 PM   #13
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Cobb sale is over (since Jan 1) but I still do the free overnight shipping, and will make special deals on Combos like an AP and Invidia/TurboXS whathaveyou downpipe or turboback!
Old 01-23-2009, 03:57 PM   #14
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Bump for another satisfied customer
Old 01-23-2009, 04:47 PM   #15
Punctual
Member Sales Rating: (10)
Member#: 167098
2010 F-150 Raptor
2011 Ducati 1198
Satisfy me dave. :wink:
Punctual is offline
Old 02-06-2009, 06:27 AM   #16
odepaj
Member Sales Rating: (1)
Member#: 94835
1995 SVX
2008 spec.B
Got a fix for us 3.3 liter folks?
(Yes it's still in the SVX).
odepaj is offline
Old 02-06-2009, 12:48 PM   #17
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Hmm let me make some calls. There HAS to be something for you weirdos
SVX=125 shot and call it a day They actually hold up to it very well from what I have heard.
Old 02-06-2009, 06:21 PM   #18
odepaj
Member#: 94835
1995 SVX
2008 spec.B
Haha, they like it enough to do a 13.2 1/4 mile on a completely stock FWD SVX
odepaj is offline
Old 02-07-2009, 03:07 PM   #19
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Awesome.
How is it getting food at a driveup window in one of those things?
"Um, can I have 3 small cokes, the large doesnt fit through my window"
Old 02-10-2009, 12:44 AM   #20
odepaj
Member#: 94835
1995 SVX
2008 spec.B
Awesome.
They fit!
Just gotta tip it sideways alittle!
odepaj is offline
Old 02-12-2009, 04:26 PM   #21
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Update* Sorry man I just cant find anything for EM on the SVX
E-manage maybe?
Old 02-16-2009, 02:41 AM   #22
Zspectrum
Member Sales Rating: (3)
Member#: 152933
CT9A
TB
what turbo inlet do you recommend?
Zspectrum is offline
Old 02-16-2009, 08:41 PM   #23
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
The new Perrin is absolutely bulletproof. The APS is nice but a bit overpriced, Agency power, as much as I dont like the owners, is the same thing, a bit cheaper.
Old 02-16-2009, 09:16 PM   #24
Punctual
Member#: 167098
2010 F-150 Raptor
2011 Ducati 1198
give me price quotes, bastard!
Punctual is offline
Old 02-16-2009, 09:18 PM   #25
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Working on it
Closed Thread
$595 FREE OVERNIGHT SHIPPING On Cobb AccessPorts All Years Instock--TurboXS UTEC! Spun Autosports Engine Management 171 02-27-2010 08:51 PM
FREE OVERNIGHT SHIPPING ON COBB ACCESSPORTS!! TurboXS UTEC on Sale Dont Miss Out!! Spun Autosports Gauges & Electronics 88 07-17-2008 08:17 AM
Free Overnight Shipping on Cobb Access Ports! TurboXS UTEC Clearance! DTEC Products!! Spun Autosports Gauges & Electronics 32 01-28-2008 07:34 AM
Free Overnight Shipping on All COBB Accessports in the Mid Atlantic!!! Spun Autosports MAIC Vendor Classifieds 10 03-31-2007 11:23 AM
FREE OVERNIGHT SHIPPING!! On All Cobb Access Ports! All years in Stock! Spun Autosports MAIC Vendor Classifieds 2 09-06-2006 12:41 PM
